226
iQQator wrote:
So strange bug (or not bug, but not feature):
I fly in the IVAO from ULLI to UUDD.
I prepare my plane, my FMGS, insert fly plan, clean not functional lines after set departure, and approach.
Push back, start engines (use check list for confirm my actions), taxi, take/off, climb, cruise, prepare for descent and now!
After Descent procedure started i want look what speed need for flaps mode, and my FMGS clean my flight plan and autopilot switch off.. WAT ?
Today i try find log of my plane and append it here.
Had the same issue here also.
227
J.A.Romanov, are you planning update of current version for X-Plane 10 or version 2.7r1 is last?
228
Greetings to all
For the post I have already read, I understand that now to have a new update, we must pay for it, to what I wonder ,,, For those who do not have x plane 11 we must also pay for that new update?
229
what is the serial number please help please
230
When you bought JAR A320 you should have received a mail with the serial number to be entered when you start Aircraft .
Dear JARDesign Team,
First thanks a lot for the A320 which looks very realistic.
I work on the REAL A320 and A330 since EIS in 1988, meaning I know it quite well.
On the latest version 2.7R1 and before, I noticed that APPR PHASE ACTIVATION made via the MCDU PERF page that, according to the FCOM is recommended to activate manually at 15NM from landing, does not activate systematically if navigating via radar vector using selected mode (HEADING mode).
The other way if all the approach is performed in managed (NAV) mode is the activation is automatic passing the D (Decel magenta pseudo waypoint).
It always says " APPROACH PHASE ACTIVATED" but does not activate every time.
In the REAL aircraft (A320 and A330), as long as the ATHR is engaged (which means Thrust Lever in CL notch, ATHR B/P middle of FCU is illuminated), whatever the altitude or speed, whatever managed or selected speed, the fact to "ACTIVATE APPR PHASE via MCDU PERF page", lead the speed target to become and to decrease to green dot speed (means best glide speed).
My comment is for the designer to take it into account for the next version.
Thank you.
BIRDIE1
232
Thanks for your sharing. Hope you can contribute more quality posts to this page. Thank you!
    lucky patcher
233
Hello guys.
I hope you can help me. I bought the latest airac cycle 1711 on navigraph and wanted to update it in my Jardesign a320. I don't know why, but somehow I do not have an active database. The Navigraph FMS Data Manager says the airac is up to date in the JD a320. I really hope you can help me. Maybe you know the problem too. THANKS !!!
234
lucasio wrote:
Hello guys.
You need to install GNS430 (with last AIRAC) in your XP11 custom data folder .
I ordered the Update of a A320Neo for X-Plane 11. It is paid, but I'm still waiting for a new serial-key. Normally the new key should be available at least after 24 hours, but now I'm waiting 4 days.
I wrote to your support-team but no answer. Is there any help from your site.
236
How do you get the Serial Key?
237
Usually you get after some minutes a mail with your serial, so look also in your spam mail maybe it landed there..
238
You should write the store support and look first into your shop download history and downloads
X-Life Deluxe
GHD
FMCAR
JD320
239
Great Job for the new Updates.
But having some trouble with lights. Baro indicator and AP console not showing any info.http://jardesign.org/forum/img/m/5512/t/p1cvcpo8tpg9cl0s2bm7h7a8p4.png
240
Fixed smile
241
How you fixed that.
I have the same problem.
242
mumax wrote:
How you fixed that.
You must turn a button light under Altitude, AP , HDG ecc
