Topic: a320neo JARDesign ver 2.7r1 WIN/MAC 64 bit (X-Plane 10)
ver 2.7 WIN/MAC 64 bit
http://jardesign.org/forum/img/m/22/t/p1av7lhv3a1acm9uvoie396ps33.png
WHAT NEW:
+ MAC OS Sierra compatible
+ New PW1100G Engines 3D model included (need to select by MCDU MENU)
+ Pause at TOD added (MCDU MENU Page 2)
+ Possible to unlock and then to open cockpit door
+ New cabin ("Sky interior") lighting system
+ New cockpit "Dark cockpit" lighting system (please use "Dark cockpit" option by MCDU MENU)
+ New cockpit manipulator system "mouse wheel control" (need to select by MCDU MENU)
+ New ground equipment set, include new lighting system
+ Working sunshields
+ Cockpit textures and details improved
+ Cockpit Integ.light/light system improved
+ New cockpit and cabin windows set
+ Visual Ice detector added, include icing effect
+ Few bugs fixed
+ Some PFD/ND details changes
+ Wipers operation effect and some rain improvements added
+ New cockpit “reflecting” glass effect added
+ New cabin windows textures added and fixed issue with “missing strobe glass” for cabin view
+ Fixed wrong left wiper handle orientation
+ Fixed wrong “Cold & Dark” Ground power and battery voltage indication
+ New controls for door switch and trimmer handle added
+ Possibility to control Flaps and Speed brake lever by mouse added
+ Some issues with wheel mouse control fixed
+ New ground Handling
+ Landing Gear tuned
  - be sure, that you use X-Plane 10.50 or 10.51 (64 bit only, MAC OS Yosemite-to-Sierra or Windows 7-8-10)
FMS NAVDATA Update:
v.2.7 use NavData from ../X-PLANE 10/Custom Data/GNS430/navdata/ folder
DOWNLOAD:
http://jardesign.org/a320/download/install/JD320.zip
New PaintKit (PW engines included):
http://jardesign.org/a320/download/pain … intkit.zip
if you use BSS sound pack, please delete exist sound3d folder and add sound3d folder from BSS. It can be named sound3d-1 or you can rename it to sound3d as you like.
Some fixes here (please apply it you really have this issues):
If two ECAM brightness knobs are inoperate - please download light.sec file and put it to /Custom Avionics/ folder instead of old file.
For the moment I went back to your beta 2.7 b3
-I have the impression that the beautiful glass effect on the ND, PFD and ecam is gone... that was great and make the aircraft more real
-I have also problem with installation of BSS soundpack 3.0
-the digits on the barometric settings are still skipping
I will wait until next updates or corrections
- you may use small clickzone to control mirror effect on PFD/ND
- you may delete sound3D folder and install sound3D folder from BSS
- please explain "-the digits on the barometric settings are still skipping"? What wrong exactly?
It's easy to get around the reading on the barometric pressure skipping.  Eugeny - it's skipping a digit every now and then in hPA when increasing or decreasing.  e.g. skip from 1021 to 1023 - the numbers it skips can be random.
You can change to inHg and adjust there and then switch back to hPA and it should read correctly.  Far from a critical bug.
6 (edited by tinchocba 2016-10-30 18:31:41)
Yes, it's gone. You are right. Now is the old effect.
Still there if you click centre just above the captain's displays.  It was on by default in B3, now off by default as it was previously.
I will check and fix hPa settings issue.
Ok, thanks. I tried but no results sad It's not so clear . Where do I have to click ? On which zone ?
For me personally, on the beta it was great, seing right now the glass effect
For BSS, normally according the instructions we don't have to delete anything. Just copy the folder 3d 1 from BSS in the plugins folders. With the beta 2.7 b3 it's ok
for skipping on the barometric setting we have for example 1004 Hpa and then it goes to 1006 (no 1005) and so on...
Excellent!! Thank you dude.
Top zone between PFD and ND.
https://k60.kn3.net/1/C/5/9/A/4/913.png
Ok, thanks a lot smile
I didn't know that. It's perfect for the glass effect. For me I would like even a little more effect on the PFD and ND but that's personal gust.
But I notice that the two ECAM brightness knobs are inoperating. That's sad.
thanks for all
13 (edited by joomie 2016-10-30 19:26:34)
Same here. BSS sound pack v3 cannot be installed.
man switches, the engines, APU etc. have no sound.
I just copied the folder "sound3d-1" from BSS into "A320/plugins/" as it is described in the manual of BSS.
14 (edited by Homer.Simpson 2016-10-30 21:15:25)
To install the bss sound packed If understand correctly you have to remove the "sound3d" (backup it First) folder from A320/plugins/. Then put the "sound3d-1" from the bss soundpackage into the A320/Plugins folder and after that rename it to "sound3d".
Ok, BSS v3 works now.
Another question. Maybe someone knows a solution. I like the comfort mode (using scroll wheel of mouse to control knobs/ switches) but sometimes I miss the click zone and begin to zoom. Is there a way to disable the zooming via scroll wheel and just use the wheel to control the switches?
16 (edited by laohu314 2016-10-31 05:32:17)
On my first flight with v2.7r1 I noticed that Descent (DES) mode and Open Descent (OP DES) mode seem to be swapped. In DES Mode the aircraft dips down at full speed VVS -3500fpm and more (leading to uncontrollable over speed), while in OP DES Mode the VVS seems more normal.
In previous versions this was reverse, i.e. OP DES Mode generated unrealistically high VVS
17 (edited by laohu314 2016-10-31 06:23:02)
This is slightly confusing. It means that the BSS install instructions are wrong!?!
I'm trusting JAR on this so I'll try it this way...
Wow
thanks for all
If so, please download this file and put it to /Custom Avionics/ folder instead of old file.
Wow
BSS instruction was done on beta stage (too early).
Hi and congratulation for this great plane,
I'v just downloaded A320 V2.7 R1 and I unfortunately the digital numeric keyboard stays inactive.
Therefore I can not easily access to mcdu, etc...
I had not that problem with a320 V2.7 B3.
And the numeric keyboard still works well if I load the a330 V1.3 R3. Strange.
Thanks for help please
jcmic
21 (edited by Homer.Simpson 2016-10-31 12:08:24)
Do you mean the quick views you choose with the numpad of the keyboard?
To restore that option do following steps:
Quit X-Plane
Download v2.7b3 (if you still have that version on your computer you don't need to redownload it)
Find the "a320neo_prefs.txt" in the A320 root folder.
Copy that file
Then replace the file found in the v2.7 folder with the copied one.
Start X-Plane and load the A320 v2.7 and you should have the quick views back.
Ok, thank you very much Homer.
Now it is working fine, and file a320neo_prefs.txt was the actually the problem.
Curious that this file doesn't take into account the numpad in the V2.7 R1 update, and that no one else seems to have faced this problem.
Good fly
jcmic
BSS Sound with 2.7r1
Settings: Sound 3D Volumen
Master internal does not work!
There is no difference between 0 to 100 percent
The engines are too loud in the cockpit.
Activation error when I try to activate.
You may try this: http://www.jardesign.org/ticket/kb/faq.php?cid=1
If that doesn't work use the contact form: http://jardesign.org/ticket/open.php and don't forget to fill in your serial
