Topic: X-Life ver 2.0 R1, R2, R3, R4, R5
http://jardesign.org/forum/img/m/2/t/p1bjn0u8u1ds8fq3tkflo1ecv3.jpg
Topic "Plan for Future" is very useful. Sure, I am understand well what airports coverage depend of users what send us taxiroutes for checking and publishing. We should care about users who create it. Yes, WED is some special software and not easy to use. Yes, be better to create own instant taxiroutes editor. And yes, it is Done now.
What new in ver.2.X:
R1:
+ add instant taxiroutes Editor
+ add new .xlf (one file format) for taxiroutes
+ old .dat + .txt support is continue
+ Insert point action fixed
+ Unluck verification as ARR/Alt airport fixed
+ Export/Import flightplan procedure fixed
+ Runway Dep/Arr settings not saved fixed
+ Sea-level airport crash fixed
+ add airport drawing check
     - if two points very close but not connect
     - if not connected end of the line not have gate/stand
     - if gate too far from nearest taxiline point
     - if there is no holdshort marked lines exist between runway and taxiways
+ fix some bugs and CTDs
R2:
+ fix "hold short" issue
(when aircrafts place wrong hold short position)
R3:
+ traffic freeze issue fixed (for airports with old format)
R4:
+ FREQ (override with default values) issue fixed
Permanent link to actual version
Installation:
If you use ver.2.X, you need update .xpl files only (attached)
If you use ver.1.X, you need delete old and install new FULL plugin from ZIP, please not mix any
How Airport Editor work
For initial understanding we prepare airports data in new .xlf files format
(you may open it with next editor also):
EFHK http://simliveries.com/index.php/2017/0 … life-beta/
UAAA http://simliveries.com/index.php/2017/0 … life-beta/
Sure, you can find this EFHK.xlf and UAAA.xlf in your /X-life/Airports/ folder
Load your aircraft in some airport, as example EFHK
Not need start traffic before!
Tap: Plugins -> X-Life -> Tools -> Airport Editor to start editor
Tap: on tab (LINES / GATES / RUNWAYS / RADIO) to switch different elements of airport what you want to create/edit
Use LINES tab if you want operate with points/lines as example
Use GATES tab if you want operate with gates/stands
Use RUNWAYS tab if you want to see Runways end points. You can move this points if need.
Select (clicking on Name lable) points, lines, gates (select needed tab
Click action buttons what available after selection
Drag points and gates (UNSELECT them before) by 'tap and hold' left mouse button on it
Rotate gates (SELECT this gate before) by 'tap and hold' left mouse button
Use SAVE button to save your data to, as example EFHK.xlf file
.xlf format include all datas for traffic in this airport
If you want draw some new airport from scratch, for example LDDU:
- please be sure what LDDU scenery folder is exist in your Custom Scenery folder
- please be sure what this scenery folder name include ICAO-code (LDDU in this case)
- please be sure what apt.dat file is exist in /Custom Scenery/LDDU Dubrovnic/Earth nav data/ folder
- please be sure what no files with LDDU name (like LDDU.dat, LDDU.txt, LDDU.xlf) not exist in /X-Life/Airports/ folder
(this file will be use by editor to import initial runways data)
- load your aircraft at LDDu and open Airport Editor Plugins -> X-Life -> Tools -> Airport Editor
- Switch RUNWAYS tab to see runways lines what was imported from that apt.dat
- Draw lines and gates
- Save result to LDDU.xlf file
- Close Editor and start traffic
- Next time when you will run editor, just saved file LDDU.xlf will be loaded from /X-Life/Airports/ folder
*** important note about taxiways MARKing:
Taxilines may be selected (need tap on it name lable) and marked (have visual different colors) as:
- runway (if taxiline is a on runway)
- hold area (if taxiline stay between runway and hold short)
- taxiway (for all other taxilines)
You can check how this done and look at EFHK and UAAA airports as example.
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
FMCar update
All remain the same
Still a problem with traffic not appearing or functioning. This is KMIA after cleared to land by ATC no planes at the airport. Possible bug? Thank for your help!
Hi JAR,
how does "snap to nodes" work, because the snap is something far away and works not well (cannot snap to another node) or i have made a mistakes ?
please reply
Hi Jar,
First I'd like to say, Very nice work you've done for us.
I installed your latest ver. and I noticed at all airports I was at, traffic seems to taxi too fast. Previous ver. aircraft taxied normal.
Hi JAR,
please reply
Did you mean Gate? So, if moving position not exact, need just move view closer to this place.
mopar wrote:
Hi Jar,
No changes with this part of plugin was made.
This happen Only with KMIA airport or ANY airport?
9 (edited by SirOTheOne 2017-07-09 08:37:45)
Hi JAR,
another problem: ATC says "You are not approach holding short ....", but i am on holding point (see pics LSZR)
"snap": i mean on nodes in "line-mode" (see pic E1000_3 near A to N)
Hi JAR,
how does "snap to nodes" work, because the snap is sometimes far away and works not well (cannot snap to another node) or i have made a mistakes ?
please reply
Hi JAR,
CTD while flying from LOWS to ESSA (while approaching)
11 (edited by ShaneD 2017-07-09 11:52:21)
Amazing you ave just taken X-Life to the next level for X-Plane, not to have to spend time for every airport in WED before flying is a great improvident.
I have a problem when trying to change one gate to a heli pad, I went to save the Airport (SBJU) and all of a sudden every node and gate had a big red question mark over it, and doesn't let me save the file
http://jardesign.org/forum/img/m/2243/t … g18lj3.jpg
http://jardesign.org/forum/misc.php?act … =2243t3222
It also happened at KSLC but the problem is not constant only on occasion
Have updated to the new X-life Deluxe and need a manual to explain the icons in the right side of the screen.
TalismannDK
Hello, can there be a youtube video explaining what exactly this new version 2.XX does?
Generally speaking I find that planes (generated by xlife)  which rolled on taxiways are too quick; the sames is when turning in or out from the runways
THanks
Hi JAR,
Hi JAR,
please reply
You may be at any holding short, but you are too far from hold short your target runway for takeoff.
Be useful if you can demonstrate me this via skype j.a.romanov, cause i am not understand trouble well!
TalismannDK
Please http://jardesign.org/x-life/www/more-features/
THanks
I just wonder.. cause We are not change any speed parameters from prev versions.
I can confirm that some planes taxi way too fast. Thats on XP 11 for me.
Same for me
With the new airport editor we will need explanation on how to correct issues. I see lots of ?????? on an airport layout but don't know what they mean. An auto correct feature would be nice! Also if possible a top down view of an airport is needed so it's easier to draw lines or make changes. I'm sure a video or manual is coming soon thanks JAR! Also can you allow vectors to non verified airports for future? Again thanks!
23 (edited by Watauga 2017-07-12 03:05:19)
JAR,
I am still using X-Plane 10.51.  Using the new Xlife v2.0 r1 I tried to build an xlf file for tdg's ENGM for X-Plane version 10. http://forums.x-plane.org/index.php?/fi … o-airport/ .  When I opened up Airport Editor the lines, gates and runway information is from the Xlife approved version of ENGM.  I was not able to see the lines, gates and runway information provided by tdg's version of ENGM.  When I remove the ENGM dat and txt file they get reloaded again.  I then disconnected the Ethernet cable and removed the default ENGM dat and txt files.  Then when I opened up Airport editor I could see the lines, gates and runway information provided by tdg's version of ENGM.  I tried clicking on the big RED question marks as instructed on the screen.  Nothing happen.  I then decided to save the lines, gates and runway information as a xlf file.  Upon hitting the save button "CTD".  Attached are the two requested logs.  By the way, it would be easier to draw the lines if we could see the airport from above.
I hope my observations help you as we continue to refine Xlife.
Ron West
KBNA
Edit to add generated ENGM xlf file.
Does version 2.0 rc1 have a Gate Editor? It's missing from the plugin drop down menu. Unless perhaps you make those changes with the Airport editor. I haven't been able to figure that out. Also if I click on light editor nothing happens.
You can create a top down view with standard Xplane functions:
Select View - Change (external) - Circle
Press the RIGHT mouse button, keep it pressed an move the mouse down until you have a top down view
Press CTRL and DOWN key (this refers to Xplane command "Move view backward fast") together several times to zoom out
Press CTRL and UP key (this refers to Xplane command "Move view forward fast") together several times to zoom in.
