251
MichaelMaar wrote:
There has been a lot of unconfirmed issues the last 2 months. I decided to make a video "cold and dark to cold and dark" (done with latest X-Plane 11.01RC1, Xenviro 1.0.6, JAR-A320 3.0RC6 and Ortho4XP Scenery) to show that the JAR-A320 is perfectly flyable.
I tried to go slowly through everything (I do not talk, only video with sound) and I think I covered everything (also the question about air brakes that would not deploy or did not work).
And as you see, there is no SASL errors any time.
And I also do a "clear discontinuity" because the arriving airport does not have STAR.
I have to say that I'm not a real life pilot and everything I know about the Airbus A320 I got from books and the internet!
You can see the video here: https://youtu.be/IDY1Pdm6iLs
I actually did see a glitch on takeoff. It did not call out "V" speeds. That is the first time I saw this.
Enjoy the flight...
/Michael
Thanks for the nice video Michael!
One question tho: 10* pitch, N1 at 90%, takeoff thrust (you forgot to put levers to CLB) and yet aircraft is somehow managing to keep 250kts limit - WTF?
252
Is it possible to assign keyboard keys to operate the MCDU buttons? I tried to assign keys from keyboard settings, but it does not work. With any default plane FMS it works.
253 (edited by Killerofwar 2017-04-29 20:25:25)
Autopilot level change/climb mode pitches up to maintain selected or managed speed value. If the thrust stays at FLEX/TOGA, the flight director just commands more pitch up to maintain speed, resulting in (very) high V/S rates, but else it's just the same as climbing with climb thrust. It's not a standard procedure (and not recommended by Airbus) to stay at FLEX or TOGA above thrust reduction altitude, but it is possible and not a problem for the autopilots/flight directors.
Only exception is that TOGA thrust is limited to 10 minutes (as per FCTM) to prevent engine over-stressing.
254 (edited by john82088 2017-04-29 22:46:22)
First, let me say I love this plane! I am experiencing one issue though with xplane 11 and the A320. It has very constant slight stutters. I am not experiencing this in any of my other high end planes that I have purchased from other companies using identical specs and locations. Is anyone else experiencing this and if so, how can I alleviate this. My computer is very capable of handling this plane. Even turning down specs does not alleviate the problem. I am using NVidia graphics card on a windows 10 machine.
Also, my FPS are in the 30's.
255
John,
I started out with X-Plane 11 Beta and just downloaded the JarDesign 320 Airliner from X-Plane.Org. The version on the front panel of the plane is Jar V2.7R1. Should I download the version 3.0 R1-6 file that you recommended? You mentioned that when downloading that you should not mix the new download files with the existing files. Should I completely delete the folder that I downloaded or will the files overwrite the existing files in the folder? Thanks.
256 (edited by jlpetri 2017-04-30 18:29:05)
Hi everyone,
I´m problem with PFD central, during the day works too dark but at night it´s not work. Any idea ?
Tk's.
257
That looks good to me.
Artificial light is never going to be as good as natural light, unless you jammed in a fair few more bulbs, so if you can see your controls, you should be OK.
258
I am not able to update current AIRAC... I use the correct data from Navigraph but in FMC I see data from 2014
259
The nav data, under the a320 folder, will get overwritten every time you update the a320 software, so you will need to install the later data under the main xp11 custom data folder.  I think it should be in a folder with "430" in the name,but there should be a few xp11 threads with the detail.
260
Hi, It seems that The FMC does not let me CLR the continuity error when I am going between ariports that have no sid or stars
Trying to fly between  SMJP to SBBE. with 320V3.0 R1.6
Am I doing something wrong?
I am using:
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
mac os 10.12.4
Xplane 11RC1 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
261
Hello All,
Just wanted to report a bug with plan maker for XP11. I tried to modify the door position to be better aligned with Autogate plugin but when I do that with plane maker XP11 and then save it it give me an SASL plugin error and I'm forced to go back to the old acf file. So no way to save in PLane maker in XP11 badly. Or maybe I'm doing someting wrong.
Thanks for your help.
Best
262 (edited by basilem84 2017-05-02 21:04:51)
You need to create a folder named GNS430 in Custom data folder and then put your updated Navdata folder in it. it will then work.
263
Ah, i've just noticed that the opening post in this thread contains some instructions on doing what you are trying to do, so just click on page 1 and that should get you there.
264
obadvw wrote:
Is it true that you are working on new FADEC for the next release?
It seems that way. I was watching a live stream from the guys who makes the BSS sound packs and he said that he was just waiting for the updated FADEC from Jardesign. He mentioned it was almost done and that a new version (r7 I assume) was due in a few days, by which time his team would release the version 4 of the sound pack for A320neo / X-plane 11.
Link to the video: https://youtu.be/BEjqhI4aejg?t=4432
Definitely getting this sound pack when it ships! smile
265
it's just strange that the admins here are in complete silence about such update , i've seen a video today with the new FADEC from BSS , its Awesome
i would have love to hear news about upcoming improvements from Jardesign him self.
now the BSS v4 is ready and the new FADEC is ready , what are they waiting for to release it to people , i don't really know
266
Ok.. we switch to new version http://jardesign.org/forum/viewtopic.php?id=3007 (XP11.01 compatible)
