Topic: JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
http://jardesign.org/forum/img/m/22/t/p1bckck0mj1qcgg3n1ge4vd26er3.png
Download link: http://jardesign.org/a320/download/inst … 20XP11.zip
  - be sure, that you use X-Plane 11.00-11.01
  - please visit www.simliveries.com to get 130+ free liveries
and put new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
You may switch default/custom installed navdata via MCDU.
Default cycle (Aerosoft, old) always included to _navdata folder.
What new in this version:
+ flightplan part fixed (some arrival was not reading well)
+ FADEC (engine control system) was tuned
+ 11.01 light issues fixed
+ some improvement to make 320 ready for new incoming BSS sound pack (not included, separate product by BSS)
- All users who bought the A320 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A320 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a320 from any shop http://jardesign.org/a320-serial-update-step-13/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a320 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
Re: JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
Brilliant news smile Looking forward to testing this, especially with the new BSS sound pack v4.
Fantastic! Thank you!
Hey JAR,
you might want to add a notice in the description, that existing customers need to "update" their serials for X-Plane 11. You had that information in the betas but not in this release thread. Not every customer reads the (closed) beta thread, so you might to write that here too, because I already found a customer who didn't knew that he had to update his code.
By the way, whats the status of the BSS sound pack? I know you are not the main developer of the pack, but do existing customers get a free update to the new version?
When I start the number 2 engine first it spools up to TOGA power and I endup having to shut it down and start with engine 1. Any ideas?
Best Regards,
G
Same here, I ended up going around in circles with no control over the engine. I did notice that with dual throttles that they were independent which I think is new, may be wrong.
7 (edited by FsCaptain 2017-05-04 13:08:24)
yep, I´m having the exact same problem. First time it appeared I restarted the sim and tried again but no luck still same issue with No2.
Yep, Same problem here also. They re-tuned the throttles and added a bug.
Hello, I tried this new version
When on climb, changing the cost index makes the NAV mode loosing the track. Then it is not possible to go back to Flight Plan track even with Direct To (By the way, on the real A320, when on heading mode and press Direct to WPT, the NAv is engaged automotically,  the aircraft flies directly to the waypoint, no need to push to Nav on FCU).
When in climb and cruise, VLS, VFE and associated strips are not realistics. (they for example disappear while heavy at FL360, it should be stronly present at hight weight and high Altitude)
The V/S knob shouldn't be graduated one ft/min by one ft/min but 100 ft/min by 100 ft/min
I tried engine 1 first, then 2 and all appeared OK. I did think independent throttle levers controlled individual engines, but that's not the case. The blue dot moves but engines seem to be controlled by left throttle lever. ( Which may be the issue when starting 2 first.)
A problem I had was after a successful flight, went to replay mode and watched the landing. ( Which was better than my usual. ) When replay was over I switched off replay and both engines went to full power, even with auto throttle off, and crashed me into the concrete.
Which XP11 Release Xp11.00, Xp11.01 ?
I have read strange engine spool ups for FF aircrafts, too
X-Life Deluxe
GHD
FMCAR
JD320
Killerofwar wrote:
Hey JAR,
JARDesign not develop BSS sounds, but sometimes BSS ask me to change/add/improve some custom datarefs to make sounds more advanced. I do. I am not affect their update policy, sales, prices, etc. This is a separate business.
Best Regards,
G
I will check this. Thanks!
..sadly yes. Will post fix today/tomorrow. Sorry.
Until fix - need start eng1 first.
Best Regards,
G
Thanks for prompt action
15 (edited by obadvw 2017-05-04 17:11:35)
Regarding the new FADEC , it's Awesome but i have a comment , when reaching Cruize Altitude , its spools down to less than 50 n1% then spools up again reaching 103%n1 then settle down around 78% n1.
i suppose it should transit from climb thrust to cruise thrust"MACH" smoothly
thanks
During descend ,suddenly airplane moved to airport E46 on ground, cold and dark
this issue was never before happening to A320 R3 , but i reported it before on A330
but now it's happening in A320 R3.1 as well
find attached Log.txt for inspection
17 (edited by 45073849 2017-05-04 17:37:09)
When I started xplane11 in the Mac, select the A320, there is a mandatory exit game problem, no matter how I restart can not read A320, other aircraft can be used normally, please help me find out the problem of the game, because I can't update my A320
check video link below illustrating the same thing happend with komrad1983 , BSS developer during his live stream on youtube
https://youtu.be/BEjqhI4aejg?list=LLGR0 … mp;t=10028
I get only V 3.0R6 with this link sad
I tried 3 dif. browsers.
jo12341 maybe it was temporary replaced with an old "stable" version?
Ok, i just test it with new fadec - no issue happen if i start eng2 first. Please put it to Custom Avionics folder. Whole aircraft published as r2 (only one file changed)
That fixed it for me.  Thanks for the quick turnaround.
JAR, what about sudden movement to E46 airport?
I'm honestly afraid to fly now, knowing this bug may occur.
What should I do exactly to get this bug on my side? How can i reply this bug?
25 (edited by dimkzr 2017-05-04 21:08:17)
I don't know, maybe ask guys above who experienced this bug and posted their logs, ask Vasiliy?
Or do you think it's a pure X-Plane bug?
