226
I have a problem with Navigraph data set 1704, although it's not a SASL error, I went back to data set 1410 which comes with the A320 and everything worked fine. ( See post 203. ) I'm back on data set 1704, but staying away from EGCC runway 23R.
J A R is aware.
227
Hi - Been flying A320 for about 1 month or so and loving every minute of it - This might be me but spend 10 or so minutes setting everything up... taxi down to the runway and JAR then starts saying "Welcome to the arrival airport...blar blar blar!..!! I haven't taken off yet - Why does JAR think I've arrived? - Doesn't spoil much thereafter, I still take off but plane is not now configured for take off and get no call outs etc...
Any ideas or help be much appreciated. Thanks
228
I think you was taxieeng to fast (above 40 knt)! If you do that, then A320 thinks you just landed...
229
Ha! OK - Think you might be right... Something I'll keep an eye on for future but thinking about it now - Im sure your right.
thank you for the reply..
xx
230
Hello Eugeny,
There's a problem with all textures at a place on the a320.
http://jardesign.org/forum/img/m/1506/t/p1begm6qvo159o1mmbf321mrmmbp4.jpg
http://jardesign.org/forum/img/m/1506/t/p1begm7gmvpkoev3m81r7k1aru6.jpg
231
Did anyone manage to solve the SASL issue?  Pretty frustrating that I can't use the A320 at the moment.  Tried to reinstall and reactivate but getting the same error.
232
I read your log.txt. There is a few lines that caught my attention:
[SASL INFO] "panel"    ERROR: NavData source not found
[SASL INFO] including    funcNavData.lua
[SASL INFO] "panel"    false
[SASL INFO] "panel"    Warning: Custom NavData NOT installed at ../X-Plane 11/Custom Data/GNS430/navdata/
[SASL INFO] "panel"    true
[SASL INFO] "panel"    Warning: Custom NavData NOT installed at E:\Program Files (86)\X-Plane 11\Aircraft\320_JARDesign/_navdata/
It seem that you have done something wrong while installing your nav data...
I can say that I have no problem flying the A320 and I have no SASL errors...
/Michael
233
I'll take another look, thanks.  It happened after I updated the Navdata.  I don't think I did anything differenty to what I've done previously.
234
Hello Eugeny,
i have an issue sometimes, not always, a320 ask me THR Climb just after i set throttle on Flex for TakeOff.
Have a good day.
Friendly,
Guillaume
235
Hello All,
iss it normal i can make and hear the firetest sound with batteries off ???
236
/Michael
I do not know if you have reloaded Aircraft after activation (as required) but if not it is normal to get such messages .
Reload the Aircraft and they will disappear .
Did you try going back to nav data set 1410. When you open the A320 and power up you can choose the nav data set on the FMC startup page. I believe nav data set 1410 comes with the A320.
You are given the choice of 1410 or the latest set you may have got from Navigraph.
238
Thanks for the suggestions for my SASL issue which does appear to be Navdata related.
I was using 1704 - updated the XP folder in Custom Data and the A320 _navdata folder.  This is what gave me the issue in the first place.
I then stepped back to 1703 - no change.
I then reinstalled the A320 and left it at the 1410 data.  Now it's working.
Question now - is this a JAR, Navigraph or XP issue?
239
I believe you are not supposed to replace any files in the _navdata folder. If you just update the files in /X-PLANE 11/Custom Data/GNS430/navdata/ with the 1704 cycle everything should work as expected - the _navdata folder is meant as a backup in case the first source is missing. This works just fine for me.
240
I've actually put the 1704 cycle into both /X-PLANE 11/Custom Data/GNS430/navdata/ and the A320 _navdata folder without issues. The FMC correctly shows 1704 for primary and backup navdata so I don't think it's an issue with the A320.....
241
I reinstalled using the Navigraph tool and now everything works fine on 1704.  Previously I was installing manually which was most likely causing the issue.  Will use the Navigraph tool provided going forward.
242 (edited by thomas_99 2017-04-26 16:31:03)
Have a look at the approach, maybe you have some more advices...
http://jardesign.org/forum/img/m/1591/t/p1be39t0bm13q1prb1r0qi2lh3.png
So I had time to watch the 2. half of the video. Here are some remarks:
- you pushed the ILS button way to early, well that does not hurt, but does not bring any useful
   information.
- you set the speed to "manual" and reducing it way too early. Usually you do not need to do it at all,
   as the plane passes the "220kt" point, it will reduce it automatically. So you can just set flaps, the speed will
   be reduced automatically regarding to flaps position ( after you pass the "220kt" point)
   Wait until the plane goes to "approach mode" automatically. Then only set flaps.
- in x-life you send "ILS established" way before it was established.
- at 1000ft, you switched the AP1 off. Well, I thought you will made an ISL landing (so switch on AP2 additionally)
   but you decided to make a manual landing. ok.
- for the last 1000 ft, you should keep a sinkrate at approx. 700ft. You were too steep,  and afterwards you
   had to correct that and were too high over ground at the beginning of the runway.
- the landing itself was quite hard ! ("Dear passengers, as you certainly have noticed we have already landed")
- after touchdown, you immediately set "reverse thrust", also the plane was not on ground with the bug wheel.
   This causes some wired callouts "go around" "Flaps set", which does not make any sense :-)
That's it :-)
Well, don't take that as critism, take it as some hints to do the next landing even better.... !!
Is it true that you are working on new FADEC for the next release?
244
Aeci, glad you got it working. I have an issue with nav data set 1704. If I leave EGCC on runway 23R with LISTO as the first waypoint, the route shows the wrong heading, it goes off behind the aircraft. It should be runway heading and then a left turn to LISTO. I think it's an A320 problem with 1704 nav data set.
It works correctly with nav data set 1410 loaded.
JAR is aware, hopefully it will be sorted in an update.
245
Hello. Read it plz and try to contact them.
http://www.airbus.com/newsevents/news-e … on-market/
246
THAT WOULD BE AWESOME
247
Is it supposed to completely level off during climb to gain speed? I mean, should it just reduce the climb rate instead of leveling?
248 (edited by yetteh 2017-04-28 18:18:23)
I've found a bug and I'm not sure if its a problem with the SASL Plugin or 124thATC.
If you run the Airbus A320 with 124thATC, when you are approaching and the controller gives you an expected runway, if you click "Other runway" the SASL Plugin crashes with an error!!
24thATC v2.0-a53 20:57:40 : reading acc.dat
124thATC v2.0-a53 20:57:59 : Flight plan STATUS for EASY @343@ (size 11): D268E D150T D150O D150J BCN NOKIN RIBEL TLA NESDI RIMOL Runway 30
124thATC v2.0-a53 20:57:59 : File opened: E:\X-Plane 11\X-Plane 11\Custom Scenery\UK-EGPE-Inverness\Earth nav data\apt.dat
124thATC v2.0-a53 20:57:59 : apt parser: found: 'EGPE'
124thATC v2.0-a53 20:57:59 : apt parser: towerFrequency found: '12260'
124thATC v2.0-a53 20:57:59 : apt parser: approachFrequency found: '12260'
124thATC v2.0-a53 20:57:59 : apt parser: approachFrequency found: '11935'
124thATC v2.0-a53 20:58:01 : Flight plan STATUS for EASY @343@ (size 6): BCN NOKIN RIBEL TLA NESDI RIMOL
124thATC v2.0-a53 20:58:01 : Choose target runway manually...
124thATC v2.0-a53 20:58:01 : Set matching runway...
124thATC v2.0-a53 20:58:01 : Take preferred arrival runway
124thATC v2.0-a53 20:58:01 : Take targetAirport object
124thATC v2.0-a53 20:58:01 : Runway lookup arrival: )
124thATC v2.0-a53 20:58:01 : Runway found 0/8: 05 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 1/8: 23 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 2/8: 12 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 3/8: 30 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 4/8: 01 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 5/8: 19 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 6/8: 13 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Runway found 7/8: 31 (isDeparture: 0)
124thATC v2.0-a53 20:58:01 : Take runway 05.
124thATC v2.0-a53 20:58:01 : Set runway information...
124thATC v2.0-a53 20:58:01 : Airport found to set runway height: EGPE (pilot EASY @343@, Inverness).
124thATC v2.0-a53 20:58:01 : Height of Runway: 31.001019.
124thATC v2.0-a53 20:58:01 : Runway information set!
124thATC v2.0-a53 20:58:01 : Target runway chosen!
124thATC v2.0-a53 20:58:01 : reading default x-plane navdata from E:\X-Plane 11\X-Plane 11\Resources\default data\CIFP\EGPE.dat
124thATC v2.0-a53 20:58:01 : Delete all FMS entries now...
124thATC v2.0-a53 20:58:01 : Call SetILSPath.
124thATC v2.0-a53 20:58:01 : SetILSPath Enter
124thATC v2.0-a53 20:58:01 : SetILSPath Set path from an entry of: Lat 57.542500 Lon -4.041667
124thATC v2.0-a53 20:58:01 : SetILSPath GetDistance to 05
124thATC v2.0-a53 20:58:01 : TargetRunwayStructName 05 On 57.550945 -4.029172
124thATC v2.0-a53 20:58:01 : SetILSPath Downwind 229
124thATC v2.0-a53 20:58:01 : ProbeTEST: Dry
124thATC v2.0-a53 20:58:01 : ProbeTEST info: 44
124thATC v2.0-a53 20:58:01 : Rwy Lat 57.537411 Lon -4.058863
124thATC v2.0-a53 20:58:01 : SetILSPath ILS entered: Lat 57.407293 Lon -4.341250
124thATC v2.0-a53 20:58:01 : Adding STAR route to FMS at the end of all flight plan entries now...
124thATC v2.0-a53 20:58:01 : Flight plan STATUS for EASY @343@ (size 10): BCN NOKIN RIBEL TLA NESDI RIMOL Approximation 1 Approximation 2 Approximation 3 ILS
124thATC v2.0-a53 20:58:01 : Flight plan STATUS for EASY @343@ (size 11): BCN NOKIN RIBEL TLA NESDI RIMOL Approximation 1 Approximation 2 Approximation 3 ILS Runway 05
124thATC v2.0-a53 20:58:01 : ILS Path set to RWY 05.
124thATC v2.0-a53 20:58:01 : Take arrival runway 05
[SASL INFO] "mcdu_fpln"    --> Set active WPT to 27 for APT_DEP/DEP_RWY reason
[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
124thATC v2.0-a53 20:58:01 : Waypoint switch cause: lost fix. Old navigation point 8 Approximation 3
124thATC v2.0-a53 20:58:01 : Speed: 166, headingDifferenceNext: 13.65
124thATC v2.0-a53 20:58:01 : Next navigation point: 9 ILS ... Lat: 57.407291 Lon: -4.341249
249 (edited by Bruns 2017-04-29 07:54:03)
http://i.imgur.com/B3zJ3Ie.png
Seems like logo lights are coming through vertical stabilizer.
- Thrust setting to 50% still overshoots to near 60% until stabilizing to 50%.
- Have to use SID (?!) otherwise can't remove discontunity.
- IRS align timer on ECAM still wrong (shows 4-5min when IRS is aligned)
Also why one of conditioner switches is not at auto and ND is not set completely to bright. I'd also love to see that when in cold and dark, all screens are turned off rather than on.
250
There has been a lot of unconfirmed issues the last 2 months. I decided to make a video "cold and dark to cold and dark" (done with latest X-Plane 11.01RC1, Xenviro 1.0.6, JAR-A320 3.0RC6 and Ortho4XP Scenery) to show that the JAR-A320 is perfectly flyable.
I tried to go slowly through everything (I do not talk, only video with sound) and I think I covered everything (also the question about air brakes that would not deploy or did not work).
And as you see, there is no SASL errors any time.
And I also do a "clear discontinuity" because the arriving airport does not have STAR.
I have to say that I'm not a real life pilot and everything I know about the Airbus A320 I got from books and the internet!
You can see the video here: https://youtu.be/IDY1Pdm6iLs
I actually did see a glitch on takeoff. It did not call out "V" speeds. That is the first time I saw this.
Enjoy the flight...
/Michael
