Topic: JD330 Airliner ver 2.0r1 WIN/MAC 64 bit (X-Plane 11)
Download link: http://jardesign.org/a330/download/inst … 30XP11.zip
Next:
- be sure, that you use X-Plane 11.00r1
JD330 use NavData from
. if not found there – aircraft will try to read it from
- “JARDesign 330/330 Native format” or (the same in fact)
and put a new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
What new in this version:
+ 3D updated by Slava
+ Systems updated by JAR
Need details? Well..
+ objects and textures was reworked according with new material system of XP11. Reworked.
+ NavData was removed from XP11 by Laminar Research and this was fixed for a330 (add _navdata with old Aerosoft cycle direct to a330 folder). Fixed.
+ a330 soundsystem was broken, cause X-Plane mastervolume datarefs. Now, you can use volume selectors from upper Plugins->Sound3D menu). Reworked.
+ a330 rain system was broken. Reworked.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
+ Perfomance and fuel calculation was broken in XP11. Reworked
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS.
+ Cockpit buttons night lighting was broken. Fixed.
+ rework ND drawing
+ vertical profile calculation reworked
+ Go Around fixed
+ ILS diamonds indication fixed
+ ILS approach fixed
+ Sound Volume page in MCDU MENU fixed
+ APU fuel cons. fixed
+ COM radio freq tuning fixed
+ increase spoilers efficiency
+ Brake indication improved (thanks Lucas)
+ Radio freq settings improved
+ New JARDesign Home livery add
- All users who bought the A330 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A330 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a330 from any shop http://jardesign.org/a330-jd-x-plane-11-update/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a330 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
