Topic: JD330 Airliner ver 2.0r1 WIN/MAC 64 bit (X-Plane 11)
http://jardesign.org/forum/img/m/22/t/p1b40vf5371b5910fg1col19db9hj3.jpg
Download link: http://jardesign.org/a330/download/inst … 30XP11.zip
Next:
  - be sure, that you use X-Plane 11.00r1
JD330 use NavData from
. if not found there – aircraft will try to read it from
- “JARDesign 330/330 Native format” or (the same in fact)
and put a new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
What new in this version:
+ 3D updated by Slava
+ Systems updated by JAR
Need details? Well..
+ objects and textures was reworked according with new material system of XP11. Reworked.
+ NavData was removed from XP11 by Laminar Research and this was fixed for a330 (add _navdata with old Aerosoft cycle direct to a330 folder). Fixed.
+ a330 soundsystem was broken, cause X-Plane mastervolume datarefs. Now, you can use volume selectors from upper Plugins->Sound3D menu). Reworked.
+ a330 rain system was broken. Reworked.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
+ Perfomance and fuel calculation was broken in XP11. Reworked
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS.
+ Cockpit buttons night lighting was broken. Fixed.
+ rework ND drawing
+ vertical profile calculation reworked
+ Go Around fixed
+ ILS diamonds indication fixed
+ ILS approach fixed
+ Sound Volume page in MCDU MENU fixed
+ APU fuel cons. fixed
+ COM radio freq tuning fixed
+ increase spoilers efficiency
+ Brake indication improved (thanks Lucas)
+ Radio freq settings improved
+ New JARDesign Home livery add
- All users who bought the A330 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A330 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a330 from any shop http://jardesign.org/a330-jd-x-plane-11-update/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a330 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
Re: JD330 Airliner ver 2.0r1 WIN/MAC 64 bit (X-Plane 11)
Woohooo! Awesome!
Thanks, a great job.
Dieter
Hi Euvengy,
on last version A330 2.0r1 speedbrakes DON`T work.
copilot says half / full... - ecam says speed brk, but F/CTL says no speedbrakes and visual the brakes are not out, too. no reducing speed.
it´s very heavy to land the bird with about 200 knots on a short rwy ;-)
please check it
Great! Great! big_smile
What is the path to install airac?
I stay up to date to 2014
Hi Euvengy,
please check it
Tested today, i couldn't see or feel your statement, speedbrakes worked like in previous versions.
Check my short Landing!
https://www.youtube.com/watch?v=DzocNnRHv_o
8 (edited by jesse.industries 2017-04-04 18:49:35)
Greetings!
Thank you, for your work! You are awesome!
Recently (yesterday) discovered that cockpit lighting (overhead as well) very dim even with overhead lighting set to max.
Hi Euvengy,
please check it
I am not have this issue at all my computers. May be you can demonstrate this via skype j.a.romanov for me?
We will determinate where this problems come.. I hope.
It was my headphones, the cabel was broken tongue
11 (edited by Yoss 2017-04-04 21:45:35)
Hi Euvengy,
please check it
I have also reported this issue a few times in the beta section. Happens only after long haul flight. But during long hauls it happens
all the time. I also sent pictures taken from the sim. I attach here as well.
http://jardesign.org/forum/img/m/4190/t/p1bcmvcep31tv11ill1fh6emb1b6j3.jpg
http://jardesign.org/forum/img/m/4190/t/p1bcmvcn3d15ft9rlk1dq011ijm6.jpg
http://jardesign.org/forum/img/m/4190/t/p1bcmvd0l211h913871ovj5r21s4u9.jpg
marcelbrietzke wrote:
Hi Euvengy,
please check it
Give it a try after 2-3000miles of flight. They won't work! During short hauls speedbrakes work for me as well, but I usually fly very long flights like SCEL to Hawaii and speedbrake won't work during descent. It can be reproduced anytime.
13 (edited by coussini 2017-04-05 01:00:45)
UPDATE... Am I right if I put my navdata from navigraph data directly in _navdata folder inside A330.
If i understand well... I have to put manually my data. I can not use the FMS data nanager because the folder from navigraph is navdata and not _navdata
Please let me know if I'M right
Just to say that the following date is ok now
WHY the Active database date is not update in Jardesign A330 ?
I use the last Navigraph data for Jardesign, X-plane 11 and X-plane GNS430...
Why it not reflect ???
http://img4.hostingpics.net/pics/205016ActiveDatabase.jpg
http://img4.hostingpics.net/pics/275164AddonList.jpg
Sometimes the weather radar does not work for me here in X11 real world weather.
I tried to set a manual weather with a storm and I saw the ND displaying the wx graph.
However if I set in the XP11 weather menu the weather to real world , even with the storm nothing is showing.
Is it a known limitation ?
15 (edited by GridiroN 2017-04-05 02:26:13)
Hi Euvengy,
please check it
This may be a unique issue for you and some others. I just took the A330 out for a test flight and the spoilers worked perfectly, albeit the physical modelling appears that the spoilers are quite low and not maximally flared.
The only obvious bugs I can still find with the plane are that it's wheels do not turn on push-back, and it's nose wheel spins the opposite way on taxi.
No, there is no limitation. For me it's working with "real world" weather. Meanwhile I'm using "ventura sky" with
XPGFS NOAA weather plug-in and it's also working very well.
No problems here. And i didn´t anything changed. I think you use a wrong folder...
Dieter
Hi Euvengy,
please check it
I did a flight yesterday close to 1000nm, speedbrakes worked just fine. Video on My channel though. Frankfurt to Madrid!
> https://www.youtube.com/watch?v=BVWyfbLsaLc
Well, I didn't see speedbrakes deployed after touchdown ! (although armed)
BTW:
If you take your captain view two steps backward you'll see that your buttocks are half on pedestal  :-)
As sim pilot you should reprogram your MCDU during flight if you get information about head wind at landing..
(Pilots used to check weather conditions all the way long)
Finally, where LEMD Madrid has disappeared?
Test flight LOWL - EDDN
1. both sceneries are defective !! Gras and gravel on taxiways better to use with a SUV 4x4. I hope that the authors will update them sooooon
2. As I push throttle on taxi a bit too high your I got a warning (inhibit TO) and then after TO I lost engine power at low altitude and couldn't avoid crash. During a second TO I had to push THR to TO/GA and then back to FLX/MCT, then I had another problem to set THR to climb. Has anyone same problem?  On the third flight (without XL) I had no problem to set THR to FLX/MCT
Maybe someone can tell us something about the corporation of XP11 + XL + A330.
21 (edited by marcelbrietzke 2017-04-05 17:53:56)
BTW:
Hmm, i dont know what you have seen, but the spoilers are deployed after touchdown.
And they worked just fine for me, that was the issue we were discussing here, and not what a Pilot needs to check during flight etc. I am not a Pilot just a hobbiest. If you had followed the whole video, you had seen i was checking weather the whole time.
Anyway if people have issues with the spoilers, then it should be investigated, i am just happy with the Plane!
Cheers.
BTW:
Cheers.
Look. When some people complain about not working speedbrakes, it won't help anyone if you send in post saying yours are working. And AGAIN speedbrakes won't work only after a LONG HAUL FLIGHT. If you flew a 1000 miles, speedbrakes will probably work during descent, but try to fly a longer then 4000nm and THEN check them. If they still work then it has something to do with this issue, as mine won't work after a this long flight. Never. On short hauls they work. ALWAYS. Period.
BTW:
Cheers.
The log.txt from such a long haul flight where speed brakes don't work would be needed to start  investigating the issue
24 (edited by ilankrt 2017-04-06 13:54:26)
Last test flight yesterday XL +3r1  - speedbrakes working (Flight over 300nm)
http://jardesign.org/forum/img/m/1591/t/p1bd1okscf1q1q3tfolj1hg91s9g5.jpg
Congratulations and thanks.  The only problem (not a real biggie as far as flying... just annoying and not reaslistic) is the barometer setting has to stay at STD throughout the flight to clear the checklists.
