Test flight KBOSKEWR in XP11.00r1, A320v3.0r1
Main issue:
Speed brakes do NOT deploy visually during flight and there is NO drag and no speed reduction, although there is an announcement as well ("spoilers full"). Therefore, overspeed during descent even though I started descent early, below 10000ft, speed remained around 280-300kts so I came in too fast, couldn't deploy flaps and so the turn onto final approach didn't happen and I had to line up manually and land manually which worked surprisingly well.
Log attached.
EDIT: On the ground everything is fine. Speed brakes deploy visually if engines are on or electric pump is on (no engines). When in flight this doesn't happen and ECAM (FCtrl) doesn't show deployment either.
iMac 27” (late 2015), Core i7, OSX 10.12.4 (Build 16E195), 32GB RAM, AMD Radeon R9 M395X 4096 MB VRAM
Saitek X52, Radio, Switch and Multi Panel, TM Cougar, X-Plane 11.00r1 (build 110025 64-bit), A320v3.0r1, XL Ver.1.2 r2, FM v.2.4r1, GndHdg v.200317, SMP4.01, RWC1.1, FlyWithLua v2.5 [X-RAAS(v2.0), 3jFPS-control-1.23, Ventura_Sky_v2.0_b1], PythonInterface 2.73.06, NOAA Weather 2.4.1, Xsaitekpanels ver 2.60, Xchecklist ver. 1.17, XControl v1.01
