176
Fregatidae wrote:
BSS Soundpack not working
X-Plane 11 pb6, A330 v2.0b3, BSS A330 RR V2.01
Symptoms:
No engine sounds, no air pack sounds, no button/lever clicking sounds.
APU, FO voice and aircraft alarm & alert sounds still work (audible when changing sound levels in MCDU menu)
Please help, thanks.
The problem is BSS use some datarefs in their config files wich not exist yet in XP11.
So...
Open folder: BSS/custom/cockpit
edit the sound.cfg with a text editor
On first line,
you have: mastervolume_dataref=sim/custom/xap/snd/coc_vol_01
Replace with: mastervolume_name=COCKPIT
BSS/custom/engines
Replace with: mastervolume_name=ENGINE
BSS/custom/flctrl
Replace with: mastervolume_name=FLCTRL
BSS/custom/gpu
Replace with: mastervolume_name=GPU
Others folders are good.
Now you can copy custom folder in: 330_JARDesign v2.0b3\plugins\sound3d\
You will have all the faders in sound menu for set the a330
Adjust volume like you want
Thank you for the fix. Works.
Should not have to change the sound config file, is there a fix in the A330.
Sound configurations and adjustment parameters are missing or all wrong. hope there is a better solution in the future.
177 (edited by pic 2017-01-18 07:22:18)
Thanks! Gonna give er a try!
EDIT:
Works great! Thanks again..oh, one thing. When I look up (at the overhead) or down (at radios, etc), the sounds are more apparent. When looking straight ahead, hardly any engine sounds. Is there a way to change this behavior while in the Captains seat? I notice this happens in ALL planes and I have no idea why.
As far as the new beta 330 is concerned, did a short flight around LFMN and had no problems (except below) and the diamonds mentioned earlier were operating well.
--------> OH! One thing. Tried the push-back truck and it just circled and circled.  I'll attach my log if that helps smile
Symptoms:
So...
On first line,
BSS/custom/engines
BSS/custom/flctrl
BSS/custom/gpu
178 (edited by thomas_99 2017-01-18 07:27:41)
Sorry but it's not the ILS diamond. It's the G/S diamond.
So...
Have you active LS(OK) + APP ???
I say that because if you just active LS, it's not a bug. It's normal.
G/S is captured if APP is active and Approach Phase activate in FMS Perf Page
Ok, you are right, It's the G/S diamond.
I've just activated LS (shown in one of the images), but:
- It's just the vertical diamond which is not working. I would expect both working or both not working, but not one working and the other not working.
Ok, I should call the bug "vertical G/S diamond not working"
enrigolan79 wrote:
Hi Eugeny,
i have an issue with SASL each flight.
A big message say contact JAR and give log.txt
So, i do...
Hello Eugeny,
Bss a330 sound pack work well now.
But I have same issue now than Sloboda !!
Hello Enrigolan,
the problem is the navdata.
Remove navdata in Customs and just use original _navdata in the a330 folder.
Test it.
Thank you Sloboda
I will try....
It is strange this problem appear only with bss sound pack !!!
180
IronCondor wrote:
How do we update new beta versions? Do we back up the old folder and then install the new version and re-enter the serial key?
exactly this procedure...
Eugeny wrote on this first topic page ;-)
181
So...
Hello Thomas,
I can see on your 4ème image APPR mode is not engage !!!
normal that your plane not capture ils target (loc and glide slop) !!
It's not a bug
Sloboda say you "G/S is captured if APP is active and Approach Phase activate in FMS Perf Page"
I add: you must have "speed nav and alt managed by fms" to perfom automatic ils landing...
I will try to put image from me soon.
Henri
182 (edited by thomas_99 2017-01-18 10:53:23)
Hi Henri,
So...
Hello Thomas,
It's not a bug
Henri
I did not want to do an automatic ILS landing. I did not expect that the plane does anything automatic.
I want to do a full manual landing, but just want to switch on the G/S diamonds for a little bit help.
So I just tuned in ILS frequency in nav1 and switched on LD.
The expectation was that the diamonds show the correct flight path. Only one of them worked as expected. The other was displayed, but did not move.
(ok, switched on A/THR and AP1 to make some screenshots :-) )
183 (edited by vschwarz504 2017-01-20 20:55:06)
good evening, little, issue with beta 3 at my system xp11 beta 6 and now 7, after replaymode, the engines went on full power and didnt go to idle. I could only help me with cut off, to stop the engines.
regards
Volker
184
my key dont work how to get updated key?
185
http://jardesign.org/a330-jd-x-plane-11-update/
186
Perhaps if at this moment you are under G/S, it's normal G/S diamond stay up ?
187
We get XP11 beta 7&8 today and I just update a330 to pb4 with a number of fixes. Sadly LR nor fix ISL/GS diamond indication. Sure, I calculate horizontal diamond DOT myself, but cant do the same for G/S diamond (no datarefs exist for this). I always send report to LR and skype to Ben personality about this. Whe thiplem is - no ILS/GS native DOT indication while acf follow NAV path.
188
Every time there is a new A330-beta I search for about an hour trying to find the download location. Unfortunately this time I can't find it. Does anyone have the link for me? I'll forward it to others who can't find it either. Thanks!
189
@Axel111
It is ALWAYS on page 1 of this thread
Lawrence
190
That's it, I forgot. Thanks!
191 (edited by ashley24uk 2017-01-21 12:26:08)
I found this issue with the engine fan blades they are transparent as seen in the pictures
http://jardesign.org/forum/img/m/1424/t/p1b70fqoeh14jri8i1tfe1pdp1c4e3.png
http://jardesign.org/forum/img/m/1424/t/p1b70fnu3u624brp6jc1clt15n7b.png
192
This is livery issue. Slava will fix it, if you about Aeroflot.
193 (edited by kebs 2017-01-21 13:03:39)
hi
same problem, empty engines, no livery loaded
X11b8, A330 b4, OSX Sierra
http://jardesign.org/forum/img/m/1294/t/p1b70houdf3d84f694jpc794q3.png
194 (edited by ilankrt 2017-01-21 13:27:44)
Test flight EDDM/EDDT XP11 b6 and A330 last version (not the new one from today 21.Jan)
Using: iMac27 El Capitan. SkyMaxxPro 4.1,  RWC 1.1. X-Life 1.1 r6 and GHD last version.
flight 1 crash
(I think the cause was after I clicked in the ATC window on "Readback" button twice that cause a jump to the over next procedure !) see log.txt and debug file
Flight 2 everything was functioning well like my flights with XP10.5.
But the reaction of mouse and clicking on FMC has a remark delay! It may be a result of the very low FPS
(XP10.50 average  28 FPS  and XP11 12 FPS)
To JAR: please write in the info frame of every new version  or in the folder name  its number (like 330_JARDesign b2...... I am getting every time confused.
Generally spoken, is it not better to wait until XP developers will finally offer a stable version instead of running after the bugs and constantly make corrections? (that I say after we reached a perfect A330 version without bugs under XP10.51)
I had also problem using the BSS ad-on (JAR A330 BSS TRENT 700 Main Pack ver. 2-2.01) . I downloaded it for new and will try after new installation how it works. (The advice for installation is also very confusing..)
And to all those hyper fans of XP11 I must say that I do't understand this enthusiasm !  OK the sky line of cities are now very realistic but after landing in Berlin in a "haze" scenery I was glad to recognize the runway on the last 300ft !
I made a comparison between XS10.50 and XP11 flying over Norway fjords. Guess who was the clear winner!
(more about:http://ilankrt1.blogspot.co.il/2017/01/x-plane-11-2017-comparison-between-xp10.html
Mostly disappointed I am about the graphic engine. I can have 6 cores for drawing sceneries but XP11 uses only one of them, so I am stuck helpless with my new iMac27...
195 (edited by kebs 2017-01-21 16:26:16)
I find this strange issue
autopilot Heading 174, plane go straight to 240
Plane is retreating on EFIS screen and turn around.http://jardesign.org/forum/img/m/1294/t/p1b70t7hl4mnk1td51hookuu1jsp3.png
X plane 11 b8; A330  b4, osx Sierra
196 (edited by jcdp 2017-01-21 18:51:34)
Report:
Using XP11 b8 and A330 v2b4 I noticed that climb/crz/desc   profile has disapeared when trying to get it on screen .
In flight plan generated with x-life there is no more altitude ...(could be the reason ...)
Attached log.txt
PS:so of course no TC nor TOD in flight plan .
Thanks for the update... working well today for a flight from CYYZ to CYUL. Better all the time. Looking forward to the A320. Great job.
198
Hi J.A.Romanov - ignore my submission I clicked on this link and thought it was to get new serial for latest beta - should have used activation web page I used in past as I did buy the XP11 version
This was the link I used posted above - oops  http://jardesign.org/a330-jd-x-plane-11-update/
Now I  do have a quick question AP keeps disconnecting for no reason also noticed sometimes the detents on throttle are not working including the clicks - something I am doing wrong ? thank you
199 (edited by vschwarz504 2017-01-21 22:55:30)
Hi, heres one bug on beta 4 with xp beta 8. It wasnt on beta 7.
After engine start and cooling down the apu, the right engine began, to have more rpm than the left engine. When I switched on the apu again, the right engine goes to the rpm of the left engine. On airborne, when I stopped the apu, theres no issue. only on ground.
regards
Volker
my running system: nvidia latest driver, windows 10 pro
200
Hey there!
I have the same problem as "Pic" stated before. When i look straight ahead in the cockpit i cant hear the engines at all.
When i look somewhere else they are much more apparent. Does anybody have a solution for this?
Also i have the bug with one engine having a higher rpm than the other one. Not always but often and it seems to change side from time to time when i start a new flight.
