176
Re: a320neo JARDesign ver 2.7r1 WIN/MAC 64 bit (X-Plane 10)
maxikk wrote:
hdespres wrote:
maxikk wrote:
AP disconnect .
after reaching cruise level, plane is  overspeeding to .84 and AP disconnects ,I can slow down and reengage AP but it would it overspeed again and disconnect all the time.
Any suggestion why ?
I'm thinking your auto throttle is not on...
No, auto throttle was on.
I am not ever sure how can it cruise at .81 or even .84 per  per wikipedia cruise speed is .78.
Hi Sir when you go in overspeed ,authotrottle  doesn't engage. Your control of speed only manual
thrust and engage autopilot for navigation . Than why you go on overspeed?
Control speed when climb and angle of bank.
177
Hello all! I think, that probe/windows heat switch works incorrect. It does not work in auto mode. Only then "on".
178
volvic wrote:
There is no terrain then TERR ON ND on. Where is a problem? XP 10.
http://jardesign.org/forum/img/m/1829/t/p1b470pj151pfj1nm61mk319h0lje3.jpg
What do you expect to see, a grey mouse running under the plane? Start flying and then activate terrain......
It happens, when you press the button twice, with arrow up
179
maxikk wrote:
hdespres wrote:
maxikk wrote:
AP disconnect .
I think your problem is that you have the A/T on, but not on at the same time... what I mean is, that you have to have your Throttle Levers on Climb Mode. If you don't have it in Climb Mode then even if the A/T light says is ON, it's not really on. It's just in Full Throttle. Check on your PFD on top left where the A/T indication is, that it's on SPEED, but if you are climbing it will say CLIMB. Remember this throttle is not like Boeing ones.
I hope I made sense haha..
180
Two questions:
1. Lately, my JAR A320 Autopilot is regularly disconnecting. I can confirm I am flying within speed. Autopilot usually disconnects over a waypoint, but also between waypoints. Very annoying.
2. Does JAR A320 work perfectly with XP11?
Kind Regards,
181
ninuskanna wrote:
Two questions:
Kind Regards,
A320 is totally uncompatible with XP11.
If you want to fly on a JAR's Plane in XP11, you have the a330v2beta2
182
Where we can find A330v2beta2 for XP11 ?
Bonjour,
Où peut-on trouver A330v2beta2 pour XP11 ?
Cordialement.
183
Bonjour,
Cordialement.
A coup sûr... Pas dans le forum A320:
http://jardesign.org/forum/viewtopic.php?id=2623
184
Merci
185
Lately, my JAR A320 Autopilot is regularly disconnecting. I can confirm I am flying within speed. Autopilot usually disconnects over a waypoint, but also between waypoints. Very annoying. Any tips?
Update -- I have got brand new AIRAC 1701 and on a flight from GMMX to EGKK, so disconnect so far. But prior few flights it was always disconnceting.
186
hello, be careful, AIRAC 1701 are fully buggy. Use the navdata from a320 zip origin.
On first page fms, choose the old AIRAC to be the actives airac.
187
Is flight plans file support coordinates format?
(a320neo_manual.pdf  Page 14-15)
188
I can not display the status page.
Is not it implemented?
189
napolioniesf wrote:
Dear J A Romanov PLEASE can you insert the 3d pilots of the 330 in the 320neo?
We, the customers, dont want fly any aircraft with EMPTY cockpit
Well if you can, integrate it. Thank you
Not everybody wants to have dangling doll in the cockpit. So if this option will be implemented it needs to have possibilty to disable it.
190
Had a perfect flight in XP11pb6 in the A320 from KEWR to KBOS. Two minor things:
1) No ECAM memos
2) No ILS capture indicators on the PFD
And then X-Plane CTD'd when I was replaying the landing at the arrival gate sad
191
I expect improvement of FMGS.
192
Airbus FBW prevents overspeed in Auto mode.
That's what JARdesign buses should be doing-preventing overspeed.
Dan
193 (edited by Bruns 2017-01-20 18:31:16)
Noticed that for some reason while I taxi to the runway I hear announcement "Welcome to our destination..". Also looks like MCDU resets after flight is over so just before I was taking off my MCDU reset and I had to reprogram everything.
Also I had some problems engage speed hold. Even I had auto throttle selected, my thrust leavers were on CLMB and I tried to pull speed knob (with "hand" cursor) it did not activate. I tried to move my throttles around and then finally after some trying it did engage. (Might be a bug or just I wasn't clear enough with trust leavers)
Also for some reason I can't see top of descent or any other markers on navigation display?
194
Hi all since i installed 2.7 i am unable to remove the engine covers and chocks?
195
Same for me. If anyone could explain that pls
196
close to beta for the Neo for xp-11?
197
Happened to be when starting from runway. Cold start from ramp allowed me to remove them.
198 (edited by laurent 2017-01-23 17:18:57)
hi
i have x-planes 11 and a320neo JARDesign ver 2.7r1
problem to see on night the screen and button, i s same on a320 and a330 ,
have you a solution?
Laurent
ON WINDOWS 10
Xl ??
199
laurent wrote:
hi
Laurent
Details! Win/Mac version, using XL? ......
200
http://airbus320neo.com/updates/ say the latest A320 is " VER 2.7 release 2 / 04.2016" -- am I correct in assuming it's just a typo?
