151
richardcarter wrote:
I have been flying the A330 over the weekend on 10.51 without any issues, today as soon as I try to load the aircraft I get a CTD. The log file says something about failing to load the scratch pad. I have tried re downloading the latest version, it loads but after activiation I get the same crash. I have attached the log file.
Hope someone can help
Richatrd
The same here, trying to load the aircraft and getting CTD
It is somewhat disappointing that there has been no support with this issue. I have already spent a fair amount of money on addons from JAR and is certainly making me think about upgrading when I get X-Plane 11
OK I posted this issue back in November,
My Steam version of X-Plane just updated to 10.51 and I now have the issue I posted above. I paid good money for this addon which I now cannot use period !!
This is completely unacceptable, can the developer please review this issue and advise a fix. Failing that how do I get a refund
152
another issue... the screens just shut off in the middle of the flight.  any ideas why it might do this? i'm attaching screenshot. thanks.
153
Without the log nobody can help...
154
2. Yes i am sure every time i scroll the map or move it around, the plane flips/rolls over and just loses altitude on its own.
3.  the system warnings get stuck sometimes (example: flaps, terrain, pull up, glide slope).  i need to press the SYS button to disable them and turn them off meanwhile up in the air and the plane is flying properly.
Hmm, strange, I have never had these issues. As always in troubleshooting, it is best to do a clean reinstall of the aircraft, remove all plugins and try again. If the issue arises again upload the log file so people who can help are able to see what is going on.
155
I'm sorry, but where exactly is the log for the A330 itself? I looked within its folder and there is bbox_log. is this the one?
156
Yes it is
and you can also add the log of the main X-Plane folder ...
Yes it is
Sometimes that can happen when you start the airplane by HOT Start, or you don't follow some procedures right. It has happened to me as well, mostly when I do the HOT START.
158 (edited by Sloboda 2017-01-08 13:58:46)
i think it's a bug in fms because i have not this problem with a320:
I choose start LFPG 26 R and want select SID for DIKOL
in A320, i have the SID list for 26R so:
http://jardesign.org/forum/img/m/1506/t/p1b5v5nf1n1gdsqgf1gn76p2emt3.jpg
I select DIK01B, see the map:
http://jardesign.org/forum/img/m/1506/t/p1b5v5p8l81n96ope7m91s7n10e16.jpg
Now in A330, i have all the SID of the airport:
http://jardesign.org/forum/img/m/1506/t/p1b5v5q6rd1sv71r0q16g81b3517s18.jpg
So i can choose DIK01A (and i have 2 DIK01B) so see the MAP:
http://jardesign.org/forum/img/m/1506/t/p1b5v5sefi1o0l7l1m4f86m7t5a.jpg
159
all i want is how to download and install a330 beta version into x p 11    and to buy latest version what i do
160
I don't see where is the problem...
go here and buy:
http://jardesign.org/a330/
So you can place this official version in XP10 and active
go here and download beta version for XP11:
http://jardesign.org/forum/viewtopic.php?id=2623
With the same number, active this beta in XP11
161
where on this forum do i buy a330 beta version for x plane 11 please
162
Best Buy it here
http://store.x-plane.org
163
Do the liveries for the XP10 A330 work in the XP11 version?
164
Yes they do
165
so I loaded the fuel with groundhandling on the A330 for a route and it turns out it wasn't enough, so the plane shut off the MCDU and screens in the middle of the flight. now i'm flying without the GPS. how do you get the GPS turned on again? i tried turning off the entire aircraft in the middle of the flight and turning it back on to see if i could get the screens back, but nothing. do the screens normally do this in the real A330? i'm attaching a screenshot of the situation.  the system warning also get stuck and i need to turn them off to quiet the voice down by pressing the SYS button.
166
When is the fading of the ND going to be fixed? i already applied the patch or "update" and it's still fading as you can see on the screenshot.  It only happens during night and when i restart the aircraft.  The plane is very buggy.
167
ND doesn't need anything because it's your PFD that's hinky, but it seems to work for everybody else, including me. So it doesn't need to be fixed either. What does seem to be needing a fix is either your installation or your procedures. Since you are not sharing your log.txt it is highly unlikely that anyone can actually help in trying to fix that.
168
Hi guys, can anyone explain to me why I can not activate? When I put the key and click on next nothing happens. I have the A350 FFactor and activated normally. All systems and firewall are right and ms 2010 as well.
tnkxx!
xp 10. last updated
169 (edited by MikeyOT 2017-01-26 11:56:51)
A330: Running Version 1.3r3 in 10.51.  Name plate on console says 1.3r3 but FMC reports 1.3r2!
170 (edited by r3m1x 2017-02-02 02:23:11)
Alright, so i give up.  I was updating the MCDU adding a flight route from sacramento int. to seattle int. airport.  as i was editing the flight route sids and stars, the MCDU just went blank and the log tells me that "[SASL ERROR] Error updating avionics: not enough memory"  i have 18 gigs of ram on this and i should have enough. not sure why it's telling me this, so i give up and finally attaching my xplane log along with an image of the mcdu going blank under the flight plan.  can you guys tell me what's going on please? thanks.
171
Hello everyone, I encountered the same problem at the start of the 26R of Roissy Charles de Gaulle, Sloboda as tu une idée ? Thank-you
172
Beta pilots
I mentioned it again and again
If you want a relevant discussion about your issue, open your "Profile" (above in the blue line) and in "Signature" give in all information about your hardware configuration and software version, further X-Plane, X-Life, A320, A330 versions and add-ons you are using like FM and GH...
Without this information nobody can discuss, help or give hints - neither JAR
173
Test flight EGLL-LFPO XP11v.b9, A330v.2b5 no crash but some bugs:
1 DOME light - cannot turn light on/regulate light.
2 ICAS no blue announcement during engine power preparations.
3 Touch down:Activated thrust reversers didn't function (engine reversers stays close).
4 Speed brakes didn't deployed automatically after touch down although SB in armed position.
5 Chosen livery didn't appear (original livery remain)
6 FM (latest version) stuttering while driving in front of aircraft.
I made a short video of my landing on LFPO to show the engine and speedbrakes position after touch down:  https://youtu.be/DmPKRxChKQI
174 (edited by ilankrt 2017-02-09 23:23:12)
Another Test flight LFPO-LFMO XP11v.b9, A330v.2b6 no crash but most same bugs in v.2b5:
2 Auto brakes set before take-off to max didn't disengage after airborne.
7 There was Audio warning about collision danger, but on PFD screen there was no other aircraft position signature, nor ATC warning (go-arround advice for example)
The following short video includes the nearly collision situation during approach... (no alarm in the cockpit):
https://youtu.be/3litrlLCqEU
175 (edited by captbullett 2017-02-10 04:48:37)
tnkxx!
xp 10. last updated
Good day, do you have everything updated like Visiual basics
check with the developer for the right version and check
the manual the should be in the main file
Happy Flying,
