Re: X-Life ver 1.1 (r1, ++)
Dear All, i just purchased X-Life and i have a couple of questions:
1) How can i fix X-life aircraft overlapping with static aircraft?
2) Is there anyway to confirm that X-life is using Bluebell XL instead of OpensceneryX?thank you & regards.
@1) There are, at least, two possibilities. You can "hide" the static aircraft in the scenery using WED (this doesn't work for every scenery, depending on how exactly is was generated) or you can make a new dsf file, also in WED, in which you create exclusion zones on top of every static a/c you want to remove and then load this scenery (perhaps named "ICAO - non-static", before loading the actual airport scenery.
The latter is a cleaner way of temporarily removing static a/c that can also be shared with others but it is more work.
@2) The Bluebell a/c look a lot better and come with proper lights on and off at the correct times. I'm afraid that's all I know about Bluebell a/c...
