301
Re: X-Life ver 1.1 (r1, ++)
Zeke*Earl wrote:
Dear All, i just purchased X-Life and i have a couple of questions:
1) How can i fix X-life aircraft overlapping with static aircraft?
2) Is there anyway to confirm that X-life is using Bluebell XL instead of OpensceneryX?
thank you & regards.
@1) There are, at least, two possibilities. You can "hide" the static aircraft in the scenery using WED (this doesn't work for every scenery, depending on how exactly is was generated) or you can make a new dsf file, also in WED, in which you create exclusion zones on top of every static a/c you want to remove and then load this scenery (perhaps named "ICAO - non-static", before loading the actual airport scenery.
The latter is a cleaner way of temporarily removing static a/c that can also be shared with others but it is more work.
@2) The Bluebell a/c look a lot better and come with proper lights on and off at the correct times. I'm afraid that's all I know about Bluebell a/c...
302
Thank you for your reply laohu314.
Regarding the static aircraft problem, I've found an easier way and that is to download the nostatic.zip file of the relevant airport.
e.g   http://jardesign.org/forum/viewtopic.php?id=1978
303
Well, of course, that's what you do when the author provides one. If not, you have to do it yourself...
304
Question:
In the X-Life settings panel, it gives us the option of Selected Aircraft with the buttons Select and Unselect. I tried selecting C172 and it still gives all the other types of planes. Is the C172 an option?
305 (edited by ilankrt 2016-08-07 22:06:09)
skydiverbiker wrote:
I think the ATIS problem is a server problem this has to be solved by JAR
This is what the txt in \Resources\plugins\X-Life\Metar looks like ,off my last flight .There is sommething moved on the server and X-life refers to the old reference.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://tgftp.nws.noaa.gov/data/observations/metar/decoded/LICC.TXT">here</a>.</p>
<hr>
<address>Apache Server at weather.noaa.gov Port 80</address>
</body></html>
If you go to the http adress you get the data.
Can anybody look at his latest flights to confirm this.
Is JAR on holiday?
I don't know where can I check it...
But I looked inside XL at the METAR folder LTAI.txt file (I was starting from this airport)
http://jardesign.org/forum/img/m/1591/t/p1apjgabqk1kf91ju646g1ctc1jl23.jpg
Then I clicked on here and got this that file:
http://jardesign.org/forum/img/m/1591/t/p1apjgdje31bcq16bv1mit1qo415si5.jpg
looking at my older version of X-Plane 10.45 at the same file:
http://jardesign.org/forum/img/m/1591/t/p1apjgh2ffm868fe1b47v36987.jpg
Do you or any other use know what that means?
Why has the METAR file been moved?
306
now I remember that because on my last flight I didn't get METAR data, I dialed the radio to ATIS freq and got Data from X-Plane (text and voice) . On the A320 weather data screen the actual data (dep and arr) was shown correctly.....
307 (edited by mruane 2016-08-08 09:50:34)
<html><head>
</head><body>
<h1>Found</h1>
<hr>
</body></html>
Is JAR on holiday?
Yep you are correct. That is what I found in the METAR txt file. Looks like it will require an update from JAR.  I think that X-Plane is also affected by this change and may require an update.
Cheers Mike
308
I've still lost all the ATIS info apart from the take off and landing runways for the departure and arrival airports. I'm running X Life v1.1r3 in X-Plane v10.50r1, the problem occurred in v 10.50b7, so the update had no effect. Everything else in X Life appears to be working correctly. I've tried both the Jar A320 and A330, the same in both.
I've re-downloaded X Life and then re-installed it into X-Plane and it remains the same, no idea what has caused this as I have made no changes to my computer or my X-Plane set-up.
Any ideas would be gratefully received.
309
Based on the discussion earlier it looks like a server address (http://tgftp.nws.noaa.gov/) has changed which causes a failure to get the ATIS data.
Cheers Mike
310
Yesterday I bought X-Life Deluxe for 20€, thats why I watched some Tutorials. But everyone in the Videos and the official X-Life pictures shows a little symbol on the left side, which is ordering the Airport vehicles. I dont have that symbol. Please can anyone tell me what I'm doing wrong.
Sorry for my bad english, I'm german.
311
Du musst es getrennt kaufen. Es ist nicht ein Teil von X-Life
http://jardesign.org/followme-car-for-x-plane-10/
312
Sozusagen bekomme ich das Symbol wenn ich das Followmecar Plugin kaufe. Kann ich das Flugzeug beladen und etc. auch mit Flugzeugen machen die nicht von Jardesign sind?
Danke schonmal im vorraus.
313
Hello all! Was a busy last 2 weeks, sorry. So, we just post release 4 of ver 1.1
As you know may be, NOAA weather servers change metar data internet location - new r4 take this in account. If you use 1.1 r1..r3, you need take new .xpl files only.
Distributive is here: http://www.jardesign.org/x-life/download/xlife.zip
314
FL car bedeutet dass Du ein Begleitfahrzeug aufrufen kannst, dass dich auf den Taxiwegen begleitet. Dies gilt fuer jedes Flugzeug.
Willst Du auch den Bodenservice haben (den Du automatisch mit dem Kauf des  JAR A330 nur fuer diesem Flugzeug bekommst) , dan musst Du es zusätzlich erwerben.
315
Wenn ich aber das Ground Handling Paket kaufe, dann funktioniert die Versorgung durch beispielsweise das Catering doch aucg mit Flugzeugen die nicht von jardesign sind.
316
Re my post at 308, I've since loaded X Life v1.1r4 and ATIS appears with all info again. Thanks Mike for the quick reply, all is good again, hopefully it stays that way.
317
Ja, aber Du musst Position und Höhe von jedem Versorgunsgeraet an das entsprechende Flugzeug selbst anpassen. Es gibt videos von JAR wie man es tut. Ausserdem findest Du in X-Plane.org Forum schon vorfabrizierte files fuer diverse Flugzeugtypen
Du musst nur suchen in der download sparte von X-Plane.org
318
JAR provided a correction an hour before (new XPL file) !!!!
Thanks JAR
319
Please, can someone tell me how to use the Ground  Handling, which I got with the A330. I only know how to use the pushback.
320 (edited by mruane 2016-08-09 10:10:26)
Select the Plugins / GroundHandling / Control Panel menu, From there you can select all/any of the available ground services. Click on the + button to add the service and the - button to send them away. The H button hides the respective service (so you don't taxi over it). In addition to this, you can build Control Sets but that can get a bit complicated and is beyond what I can help with. Others may be able to assist with that.
Cheers Mike
321
thanks
322
If I open my JARDesign A330, and wan`t to take off, it does nothing. After taking the park break off, some screens (Navigation Display, FCU Flight Control Unit) change to blackscreen.
Please can somebody tell me how I can solve the problem.
Sorry for my bad english , I`m german.
323 (edited by Joss 2016-08-09 22:29:43)
Didn't fixed CPU usage problem
http://jardesign.org/forum/viewtopic.ph … 537#p12537
http://jardesign.org/forum/viewtopic.ph … 579#p12579
324
Hi to JAR,
flying from LOWL to LZIB -> CTD while approaching (with newest XL beta)
greetings Mike
325
The newest version of X life 1.4 seems to working fine with the latest version of X-plane 10.50 which I think is now out of beta, but not officially released. After couple of test flights from KBWI to KJFK and one from KSEA to KLAX all works great and no issues with the ATIS weather info or ATC. I'm hoping that in the future the ATC will further be developed. My wish list: 1.Communication between ATC and other X Life aircraft during a flight and on the ground. (Maybe this could be done using a separate window on top of the screen?)    2. ATC to give headings to fly during a flight. For example, "United 123 fly heading 240"    3. To be able to choose an approach type. For example at KJFK, "Request runway 13L VOR approach." or "Request runway 22R ILS approach"   4. To be able to file a flight plan during a flight or change a flight plan. Hats off to JAR and team bringing X-Life so far in a short amount of time! Lots of hard work and time has gone into X-Life. Looking forward to further improvements whatever they may be and a big thanks to all the testers and team JAR. Happy flying!
