276 (edited by Watauga 2016-07-17 02:05:08)
Re: X-Life ver 1.1 (r1, ++)
CTD while flying from EDDL to EDDH in X-Plane 10.50b7.  I am using X-Life 1.1r3.
277 (edited by ilankrt 2016-07-18 11:22:49)
Test flight EETN - ULLI , latest versions of XL, FM car, A330, on iMac27 using X-Plane 1050b7
No Crash
Notice: The two airports (and other ones of the tested east european airport sceneries) are loaded with a warning that LIB or other files are missing. After enhancing the Buildings number to "Tons" this and the other sceneries appears although X-Plane warning said they will not be installed.  This is very wired and I discovered it only randomly.
Also the scenery quality adjustment in X-Plane 10.50 disappeared !....
278
Sorry if this is in the wrong place, but I can't create a new forum post...
I'm working on a custom scenery project. X-Plane's AI behaves badly if I connect taxi routes to the ramps (planes do a u-turn at the ramp and hit all the objects). I tried creating a version of the scenery with the taxi routes connected to the ramps, generated the X-Life TXT and DAT files, and then go back to the dis-connected taxi route / ramp version of the scenery. However, now the X-Life traffic doesn't load.
Is this because X-Life is trying to pull data from the dis-connected version of the scenery I now have loaded up? I figured the DAT and TXT files would have everything X-Life needs, so it wouldn't matter even if I completely deleted all the taxi routes from the scenery. Is this incorrect? Is there a work-around?
I'd like to ship this scenery with X-Life support, but I also don't want the X-Plane AI to be broken.
279
Test flight ESSA - ENGM, A320, XL and FM car last version, X-Plane 10.50b7
No Crash
A320: For unknown reason (I didn't find out why) during take-off no announcement  of 100 kn  and rotate and no sign on PFD speed tape !
Airports: Wonderful design, correct taxi ways and XL traffic works perfectly!
Note: I used to fly nearly every day on short distances between tested airports. I will not report about all of them since there are not problems concerning X-Life and if some  occurs they refer to aircraft function failure....  And of course we are waiting impatiently to hear from JAR about new XL improvements...
280
I have the domes of red and blue lights around the front of aircraft moving around the airport. I've seen in earlier entries on this forum the same problem, only these lights were green. Obviously only happens at night or when light levels fall. I'm running X Life 1.1r3 in X Plane 10.50b7, no other problems.
I'm sure the issue is being worked on for a future update. X Life is a great add-on for X Plane 10
281
I had blue lights showing at the front of the X-Life default AI planes whilst on the ground. Since installing the Bluebell AI aircraft I do not see this problem any longer. All AI aircraft depict standard white landing lights with Red and Green nav lights and look as you would expect. Same for other static lights. All appear normal.
Cheers Mike
282
Cheers Mike, I'll give that a try.
283
CTD while flying from LZIB to LOWK with X-Plane 10.50b7.  I have the LZIB dat and txt file in X-Life's airport folder.  I noticed this unusual line in the log.txt.  I received the same message in X-Plane 10.45.
XL: 14 : MessageWhite: LZIB airport is not X-Life verified! Please use menu and check verified airports Map!
XL: 14 : JARDesign plugin: F:\Test X-Plane 10.50b7\Resources\plugins\X-Life\Metar/LZIB.TXT file updated.
The CTD occurred as I was approaching LOWK and I clicked on the ATIS tab.  This same thing occurred with X-Pane 10.45.
P.S. I no longer have the log.txt from the X-Plane 10.45 LZIB to LOWK  CTD.
284
For the first time I tested other aircraft models than the A series of JAR:
B748 inter works perfect with  XL, traffic and ATC. I had to synchronize data for the two sources the B748 FMC and XL flight plan.
Carenado B1900D HD works also with XL but the synchronization between the GNS530 and XL flight plan is not so simple especially planing STAR on APPR. Also during landing manually the change from APPR to TOWER with incorrect level advices is disturbing.....
Airport traffic in both test flight and also FM car are functioning without any problem.
285
Hi Jar,
Is something going on  in the next weeks?
286
For some reason I'm not getting full ATIS info, only the landing and takeoff runways of the departure and arrival airports. Two flights ago it was working fine all info showing. I'm running X Life v1.1r3 in X-Plane 10.50b7. I have made no alterations to set up, it just seems to have happened, other than that all is working fine.
287
This has just happened to me right now ...
LOVE Xlife. But.....still can not grasp the following. Help please.
KSFO to LAX  XLife Atis use SF3 SID  there is not Sf3 sid.
KLAX to KSAN Xlife Atis arrival KSAN indicates use BAYVU4   there is no such option. There is a U3 but no U4. And yes I have downloaded to NEWEST Nav !608.
The other thing is I let Xlife generate a flight plan and load the FMS with it. All the I need to do is listen to ATIS to select the SID. I then choose the runways and the suggested SID (like depart KLAX 25L with a LAXX7 departure). I enter 25L  I enter LAXX7 and it adds it to the flight plan but it duplicates in some cases and in others the SID does not flow properly with the generated ATIS suggestion. What am I doing wrong?
289
You have to give us informations about your aircraft model.
290
Flew from LZIB to LOWK in X-Plane 10.50r1.  X-Life is version 1.1r3
The only ATIS information displayed is departing and arriving runways.  No weather information.  See Eclipse attachment for screen shot.
Log.txt attached.
Even though X-Life make this statement:
XL: 197 : MessageWhite: LZIB airport is not X-Life verified! Please use menu and check verified airports Map!
I have the LZIB dat and txt files installed.
291
Log.txt attached.
I have got same problem flying the Carenado B1900 HD. It seems to be a problem connected to the use of GNS530?
292
Log.txt attached.
I also have the same problem, but I have not upgraded to 10.50 9at least without my knowledge) the loading screen stills says 10.45.
293
Hi to all,
i think jar is on holiday!
no new betas, no feedback, ....
is x-life still alive with 10.50 or are there many issues with 10.50. I have installed 10.50rc1 and i have absolutly no problems.
294
I thinks its a weather server problem, but i don´t know from where xlife gets weather data.
Log.txt attached.
295
Im sorry about that. I fly the Jar A330-274 aircraft. I hope you can assist with suggestions.
296
Test flight LSZA - LSZH (over the Alp Land) X-Plane 10.50r1,  X-Life is version 1.1r3, Carenado B1900 HD FL 160.
No crash and without any problems.
I had only to put the same FP into the FlightFolder of XL and into the output folder for use with the GNS530.
I hope to see JAR soon back at his MAC....
297 (edited by mruane 2016-08-07 11:14:40)
I have the same issue as SirOTheOne, is anyone else experiencing a malformed ATIS display consisting of just a single line containing part of the ATIS for both the Departure and Arrival airports.  The ATIS that displays on the main X-Plane window appears to be the fully ATIS text but the copy that shows on the ATC pop out window is the one that is malformed. It appears like this for every flight now. I do not think the ATIS in the ATC window has actually been updated for a week or more now.
I am using v1.1r3 210616 and there are no errors in the Log file to explain this (see attached).
PS Interestingly I have also noticed a weather issue, which may be related. I frequently operate between NZAA (Auckland NZ) and NFTF (Tonga). As I cross the W180 latitude I have previously experienced the sudden presence of high level winds. Prior to W180 degrees there are no high level winds (I understand this is an X-Plane issue). Of late, there are no high level winds when passing W180 degrees. Something has changed in the weather engine, which might be impacting X-Life as well.
Cheers Mike
298
I think the ATIS problem is a server problem this has to be solved by JAR
This is what the txt in \Resources\plugins\X-Life\Metar looks like ,off my last flight .There is sommething moved on the server and X-life refers to the old reference.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://tgftp.nws.noaa.gov/data/observations/metar/decoded/LICC.TXT">here</a>.</p>
<hr>
<address>Apache Server at weather.noaa.gov Port 80</address>
</body></html>
If you go to the http adress you get the data.
Can anybody look at his latest flights to confirm this.
Is JAR on holiday?
299
Dear All, i just purchased X-Life and i have a couple of questions:
1) How can i fix X-life aircraft overlapping with static aircraft?
2) Is there anyway to confirm that X-life is using Bluebell XL instead of OpensceneryX?
thank you & regards.
300
<html><head>
</head><body>
<h1>Found</h1>
<hr>
</body></html>
Is JAR on holiday?
Confirmed, I get the same thing. You are right. NOAA moved their file and XL has not been updated to find the new location.
