176 (edited by ilankrt 2016-06-17 22:07:10)
Re: X-Life ver 1.1 (r1, ++)
Back to Europe - Test flight GCRR - LEGE A320neo/A330 stable version, XL last beta version on iMAC27 Mavericks
No crash
GCRR traffic and FM functioning well. It is the best taxi ways signposted scenery I ever saw. Clear to read and big enough to see and consequently easy to navigate to terminal and RWY.
I flew first to LEMG but I got en route error massage and beside the RWY there was nothing else. I am in contact with the developer to solve this problem
LEGE is also a very nice scenery with a lot of traffic, but unfortunately FM car didn't appear also not on map, so I went lost on taxi ways at night while other AI aircraft coming on toward me.....
LFMN design need urgent to be recreated. The following images are telling the story... and there are more bugs...
http://jardesign.org/forum/img/m/1591/t/p1alg6bv7gqvk1bn71ocqpc81vrl3.jpg
http://jardesign.org/forum/img/m/1591/t/p1alg6dgev15ee1mme1et87hv9hla.jpg
http://jardesign.org/forum/img/m/1591/t/p1alg6dvsmorg45u4t21lbin6od.jpg
http://jardesign.org/forum/img/m/1591/t/p1alg6cv261reb115un551li39rf7.jpg
Generally seen routes created by XL "Flight Plan" are sometimes correlating with "Online Flight Planner"  and with "SimBrief.com". In other cases I have made myself a route .txt file, place it in the "flightPlan folder" of XL and transfer it into FMC and ATC.  Otherwise I have to made a lot of route SID and STAR changes on FMC.....
Looking at the development of XL until now I must say that with any further flight I am totally thrilled by XL air and taxi traffic.
With XL ATC and the checklists of the A320neo I am fully busy and have the feeling of being in a real cockpit.
Flying the A330 I strongly wish the same checklist system as  in A320 model. (Display is already there but voice check announcements are missing)
177
Hello pilots! Was busy last week - mostly work with LR (check 10.50 prebeta and beta 1 for bugs) and code a lot with C++ to improve airbus systems. Sorry is no answer was. Just read forum now.
178
That are good news !
we are curious and eager to hear from you about the improvements  of the Airbus systems.......
179
mruane wrote:
DEP and ARR Runway change.
According to the release comments in the first post, this version now supports changes to the arrival or departure runway (presumable on request). It is not transparent how to achieve this. As I worked though the departure for my last flight, there was no option presented on the ATC screen to request a different departure runway. How do you request a change to the assigned runway?
Please download more fresh version (1.1r2) from x-life.jardesign.org
I have installed v1.1r2 but I still do not get any opportunity to select an arrival or departure runway. Further X-Life is directing me to a runway that is not suitable given the ATIS for my arrival. In my last case the ATIS reported wind of 230/9 which would require runway 23 but I was vectored to Runway 05 and no option was displayed to request a runway change.
I am not sure what I am doing wrong, perhaps you could advise what tests are made in the code to decide whether to show the optional runway selections or not. That may guide me as to what I am doing wrong.
Best Regards
Cheers Mike
180
Is the real world schedule on the agenda now?
181
Just upload new distributive 1.1r3
The main reason - fix wrong takeoff/landing ATC selection for user aircraft. Also - some kind of CTD fixed. Thanks for your reports and .dmp files.
Permanent link to actual release
If you always have 1.1r1 or r2, need update .xpl files only. Attached.
182
Thank-you for the work JAR this should help out very much.
Happy Flying,
http://jardesign.org/forum/img/m/1591/t/p1alpqce1h16diu1kcurdcp1p0q3.jpg
184
X-Life is excellent, thank you.
I had a problem last day, X-Plane crashed and X-Life seems to be responsible.
I put files with the message to help you to understand what happened.
Thank you,
Goodbye,
Adrien
185
Please attach full log.txt
186
I'm sorry but I don't know what to add.
Everything is there...
I hope you understand what I write, I'm not an english man...
Thank you,
Goodbye,
Adrien
187 (edited by captbullett 2016-06-22 14:48:47)
Thank you,
Goodbye,
Adrien
good day,
can you use Google translator  https://www.google.com/search?client=sa … p;oe=UTF-8
or what you language is...
188
Thank you,
Goodbye,
Adrien
If you open attached log yourself - you will see what end of text (most important) cut.
189
Using XL v. 1.1r2, I continued my test flights to the east Mediterranean, flying from LBWN Varna to LTFE Bodrum and from there to LTFJ Ankara. I used to fly with the A330.
X-Life is functioning well but with only 4 AI aircrafts on taxi ways. Maybe I have to change parameters, but I don't won't to adjust to max. ATC is also working good, but as we discussed here in the near past, it needs more development steps. I am not going now to tell JAR what is my wish. He has its own schedule.
Main problem seems for me to be some airport design. If XL is for now restricted to a certain number of airport sceneries, I think that they must be on an appropriate level.
Unfortunately this is not always the case. All three airport sceneries in my test flights were not accurate made. I don't want to get now in detail, but AI aircraft on runway during landing, wrong taxi ways or buildings without a roof, are occurrences that shouldn't happen. I would like to recommend JAR to take a closer look at the XL airport sceneries on the background of our reports.
190
I read full log text and I must say I dont see what is missing ...
here is end of text ...
XL: 4079 : ---+++--- ATC: KZO754665, TOULOUSE Tower, line up runway 32L, and wait
XL: 4138 : X-Life plugin ver.1.1r2 100616 detect crash.
XL: 4138 : Memory dump saved to x-life.dmp file
XL: 4138 : Please send this log.txt file and x-life.dmp file (from X-Plane folder) to support@jardesign.org !
This is what has been done ....
What is missing?
Would you mind explaining please .
191 (edited by ilankrt 2016-06-22 23:33:30)
From time to time, as X-Life development is going forward, I used to record one of my test flights.
Those video got each more then 1300 entries.I am sure that they contributed to spread the XL plugin
This time using XL v.1.r2 I made a video of my flight from LEGE to LFML during the night. (55min, 4.3 giga)
You can watch my video on YouTube:
https://youtu.be/_BPIl0jtpdQ
Factual comments are welcome.......
192 (edited by captbullett 2016-06-23 01:05:20)
Fact; the version "XL v. 1.1r2" you are using is not up to date therefore, it does nothing to help the testing out! the version that is current 1.1r3 ... see post# 184
Happy Flying,
J.A.Romanov,
Should I be using XL version 1.1r3 or 1.2b1 for testing purposes?
194 (edited by captbullett 2016-06-23 04:01:30)
Watauga wrote:
J.A.Romanov,
JAR just posted 1.1r3 today so, you most likely did not see it not to worry. look back at post #181
and it will show you all you need to do is replace the xpl file and you will be good you do not have to replace the whole XL file.
Happy Flying,
Friendship with the boat in the ocean of life is impossible easy, sometimes encounter clouds and storms, and in this case, the friendship should be this or that test after these dark clouds and storms, and then the friendship will more consolidated, true friendship, in any case will shine new light.
______________________________________________
And I love to create friends,Because: Cheap CSGO Skins to be along side friends
invited here: http://www.csgo4skin.com/
196 (edited by captbullett 2016-06-23 08:02:34)
this is a Beta testing site for Jar aircraft and not for what you posted this is not a good start
please refrain from this please. This has nothing to do with being friends or not .
thank-you for your help,
Beta tester
197
This is spam
Beta tester
198
in the menu Tools, Gate Editor work but the others crash XP.
Have an idea ?
199 (edited by captbullett 2016-06-23 13:34:01)
I will post this here and in the two aircraft sites also since it is such important data everyone was wanting check list but no-one seemed t know where to find one.
here; A320ne  http://www.freechecklists.net/aircraftinfo.asp?ID=66
A330  ;  http://www.freechecklists.net/aircraftinfo.asp?ID=67
this has comprehensive and flight sim check list right from Airbus...
Happy Flying,
Attachment icon Screen Shot 2016-06-23 at 9.25.17 AM.png 92.62 kb, 196 downloads since 2016-06-23
200
Watauga wrote:
J.A.Romanov,
1.1r3 is more fresh version. Please use it.
