1 (edited by wilkur 2016-05-31 21:49:13)
Topic: ATC Routes - EDLN-Moenchengladbach Test
Hello X-Life Friends,
I try to learn how to create atc routes. Now it is not realy complicated but would you please test my atc routes for EDNL-Moenchengladbach.
The airport is origin from the X-Plane gateway.
Some things are not realy real, could be better, but it is a try -  and it works.
It is only traffic for show without atc test - but now I will test a flight from EDNL-Moenchengladbah to EDDL-Dusseldorf.
Please let my know whats wrong.
Willi
P.S.: I'd like to make some airports for this amazing tool and I would like realy more describe my action in X-Life, but my english is realy not sufficient - sorry.
2 (edited by marvel_master 2016-06-01 20:55:44)
Re: ATC Routes - EDLN-Moenchengladbach Test
i have take a look at your edln.dat file. One rule is, that ramp has only 2 words. You have 3. Exampel: Main Ramp 33
Check attachment for more errors. I stoped after error 4.
Error 5: Your taxiroute dont follow the gateway airport. I tested your files with the gatway EDLN airport:
https://gateway.x-plane.com/scenery/page/EDLN
ID 797.
You should first reimplement your apt file.
Maybe you should read the following links and look the video.
http://jardesign.org/forum/viewtopic.php?id=1670
http://jardesign.org/forum/viewtopic.php?id=1941
https://www.youtube.com/watch?v=SMslHitMEYc
The most important airports from germany are implemented in x-life. Check this:
https://www.google.com/maps/d/viewer?mi … tAA_7MfME4
From other users are implemented the following airports from germany:
http://jardesign.org/forum/viewtopic.php?id=1999
At this moment, the following airports are not implemented in germany.
Berlin-Schönefeld    SXF    EDDB
Leipzig/Halle    LEJ    EDDP    ( i am still working on this airport )
Dortmund    DTM    EDLW
Karlsruhe/Baden-Baden    FKB    EDSB
Memmingen    FMM    EDJA
Paderborn/Lippstadt    PAD    EDLP
Small Airports
Friedrichshafen    FDH    EDNY
Saarbrücken    SCN    EDDR
Erfurt-Weimar    ERF    EDDE
Hello 'marvel_master',
many thanks for your test and reply and also thank you for your tips and hints. Now I can revise the airport and correct the errors.
Willi
