i have take a look at your edln.dat file. One rule is, that ramp has only 2 words. You have 3. Exampel: Main Ramp 33
Check attachment for more errors. I stoped after error 4.
Error 5: Your taxiroute dont follow the gateway airport. I tested your files with the gatway EDLN airport:
https://gateway.x-plane.com/scenery/page/EDLN
ID 797.
You should first reimplement your apt file.
Maybe you should read the following links and look the video.
http://jardesign.org/forum/viewtopic.php?id=1670
http://jardesign.org/forum/viewtopic.php?id=1941
https://www.youtube.com/watch?v=SMslHitMEYc
The most important airports from germany are implemented in x-life. Check this:
https://www.google.com/maps/d/viewer?mi … tAA_7MfME4
From other users are implemented the following airports from germany:
http://jardesign.org/forum/viewtopic.php?id=1999
At this moment, the following airports are not implemented in germany.
Berlin-Schönefeld SXF EDDB
Leipzig/Halle LEJ EDDP ( i am still working on this airport )
Dortmund DTM EDLW
Karlsruhe/Baden-Baden FKB EDSB
Memmingen FMM EDJA
Paderborn/Lippstadt PAD EDLP
Small Airports
Friedrichshafen FDH EDNY
Saarbrücken SCN EDDR
Erfurt-Weimar ERF EDDE
