TEST FLIGHT KDEN - KSAN, A330, XL 1.8b
Crash
SkyMaxx Pro: Found new METAR.rwx file
SkyMaxx Pro: Parsing METAR data
--=={This application has crashed because of the plugin: SkyMaxx Pro}==--
I want to discuss a problem that occurs during my last 3 flights.
DELIVERY advices RWY but not SID.
In case of KDEN/KSAN the XL flight plan gives me RWY 17R KDEN - SID(?) - DVV ...
This might be a bug, because as you can see on the next images DVV is located in opposite direction at north-east from RWY 17R ! The wrong alight advice happens now for the third time.
The result is that take-off RWY 17R - SID CONNE3 - DBL (my choice after studying SID charts 1606) as given in "Online Flight Planner" (see image) brings me fine of course but then FMC turns course back to DVV and I must delete all the mess that happened.
Questions: who feeds XL Flight Plan? Why XL is not giving SID and how can it happened that The first point after undeclared SID is located at a total wrong direction? I think that this problem began at XL 1.7b. In earlier beta versions DELIVERY gave me SID correctly and the Flight Plan was accordantly correct.
It is important to know if anybody else has same problems.....
Online Flight Planner:
SID to DBL as it should be:
Wrong XL advice after undeclared SID to DVV
X-Plane 11.30r3 | iMac27 OSX Mojave 14.10.4, | Samsung ultra-wide screen 49-inch | Saitek equipment | MFG pedals |Gladiator Joystick | Plugins: GndHandling, RWC, SMP, SoundM, X-Life, BetterPushback, AutoGate, SoundMaxx, X-ATC-chatter, X-Camera | iPad 12.9, iPad Air 9.7 | Airliner: JAR A320/A330, FF A350XWB, FF B767, SSG B747-8 inter, Epic1000 new, TBM900
http://ilankrt1.blogspot.co.il
