1 (edited by MasterTRL 2016-05-19 10:25:51)
Topic: [SOLVED]No straight line from HP to runway / Turn before takeoff
Hi Guys,
i´m working on routs for LESB at the moment. I have the general layout down and it works so far except for two things.
Please have a look at these two bictures of either end of the runway:
http://jardesign.org/forum/img/m/2594/t/p1aj2m6tlq1qcr1ofe1gef2r5dr83.png
On rwy 06 the runway extends a good portion farther out from the taxyway. Obviously i´m trying to set the whole thing up so that the aircraft would taxy out over the numbers, then turn and come back and then take off. I have tried several tricks with the route layout but the planes just turn left at the entrance and take off directly.
http://jardesign.org/forum/img/m/2594/t/p1aj2m73l7179p177m5e0v41pgt6.png
Here we have the situation that the entry for rwy 24 doesn´t lead onto the actual runway. The aircraft will go around that bend towards the numbers and take off after that. Obviously i want to emulate just that. As i have learned though, i can´t have an additional taxy way node between the holding point and the runway because that node would be the holding point then which would be wrong. Also i can´t just extend the runway rout out to that point because X-Life would not recognize it as runway any more and the plane will take off from the taxyway C2 paralel to the runway (yes, i have tried this).
[SOLUTION] Thanks to vatech for helping me out. Please look at the pictures he has posted below to see how he solved the two problems. I also uploaded the finished files incl. no static in a separate thread with this solution already applied.
So you see where i got stuck with the LESB runway there. It would be so cool if any of you veterans could have a look and tell me what i can do. Or even if it is not possible at all so that i can finaly find peace ;-)
I atached the .dat and .txt in case someone wants to try something. The airport itself is part of this scenery:
http://www.helgo11335.de/  (Mallorca 9.1)
2 (edited by vatech 2016-05-19 07:29:55)
Re: [SOLVED]No straight line from HP to runway / Turn before takeoff
MasterTRL wrote:
Hi Guys,
To work properly you RWY 06 must looks like this
http://jardesign.org/forum/img/m/2234/t/p1aj3ulsus1nvauav3qtso1ebu3.jpg
I edit this a little.
Hi vatech,
thank you very much for your effort. I tested your file immediately but i have to tell you that departing planes still turn left as soon as they enter the runway instead of first turning right and then doing a turn at the very end of the runway.
Could this have something to do with the size of the plane though? Like how a small plane does not need the whole runway and X-Life recognizes this?
Cheers
Chris
4 (edited by vatech 2016-05-19 08:37:56)
MasterTRL wrote:
Hi vatech,
Cheers
Chris
This is the 'shift takeof' small planes can take off from the center of the runway if lengh is anouth for that. X-life determines by itself the lengh for shift takeoff for each type of plane.
And one more mistake I found and edit.
http://jardesign.org/forum/img/m/2234/t/p1aj42j5q64o81k3j1jojmbb10jc3.jpg
Ok, i see. Wasn´t aware that X-Life takes that into account.
Ah i see what you did there. I had it like this first but then the planes wouldn´t take off from the runway at all. But unlike you, i extended the runway in a single line to the entrance. I see that you put an additional node on the actual start of the runway, which seems to do the trick.
Thank you very much for your help! I will create the no static mod now and then i will publish the files in a new thred.
Cheers
Chris
