Topic: [SOLVED]No straight line from HP to runway / Turn before takeoff
Hi Guys,
i´m working on routs for LESB at the moment. I have the general layout down and it works so far except for two things.
Please have a look at these two bictures of either end of the runway:
On rwy 06 the runway extends a good portion farther out from the taxyway. Obviously i´m trying to set the whole thing up so that the aircraft would taxy out over the numbers, then turn and come back and then take off. I have tried several tricks with the route layout but the planes just turn left at the entrance and take off directly.
Here we have the situation that the entry for rwy 24 doesn´t lead onto the actual runway. The aircraft will go around that bend towards the numbers and take off after that. Obviously i want to emulate just that. As i have learned though, i can´t have an additional taxy way node between the holding point and the runway because that node would be the holding point then which would be wrong. Also i can´t just extend the runway rout out to that point because X-Life would not recognize it as runway any more and the plane will take off from the taxyway C2 paralel to the runway (yes, i have tried this).
[SOLUTION] Thanks to vatech for helping me out. Please look at the pictures he has posted below to see how he solved the two problems. I also uploaded the finished files incl. no static in a separate thread with this solution already applied.
So you see where i got stuck with the LESB runway there. It would be so cool if any of you veterans could have a look and tell me what i can do. Or even if it is not possible at all so that i can finaly find peace ;-)
I atached the .dat and .txt in case someone wants to try something. The airport itself is part of this scenery:
http://www.helgo11335.de/ (Mallorca 9.1)
