Re: v.1.3b1 distributive (Windows 7/8, MAC OS)
joni80 wrote:
joni80 wrote:
Also what I found was that I could not enter a cruising altitude, as every altitude was rejected with the reason of being too high, although I even entered an altitude of only 5000 feet, but it was rejected.
Not altitude, but FL. 5000 should be 50 as FL.
Yes, that could work, but I also tried to enter 300 for 30000 ft and it also gave me the error of the altitude being too high, it was for every altitude I was trying to enter.
That is your flightplan length? May be it is too short for this altitude?
Acei wrote:
I find it hard to believe that this is a Steam issue.  The previous version worked and still works when I reinstall it.  All other a/c also work fine.  I think Eugeny needs to take a look.  It would be interesting to know if anyone else with the Steam version has had this issue.
Sure, you can contact me direct via skype j.a.romanov
Franz007 wrote:
Thanks but the APU still doesn't burn fuel and there is still no Flaps-2 take off calculated in the MCDU. How long do we have to wait before you fix some minor issues that have been reported a long time ago?
What calculation did you mean for Flaps-2? V1-VR?? It is a pilot task!
APU eat fuel, but very slow.
Got a-floor status at lows while taxiing. Then tried to reprogram flight and mcdu went crazy.
30
You mean the v1/vr/v2-speeds will be calculated autoamtically with flpas 1 but the pilot has to enter it manually for Flaps-2 take offs? Do you know where we can find those v-speeds according to the weight?
On my test flight the APU didn't burned anything after 5-6 minutes running, no kilogramm at all...i guess that's not possible ;-)
TDPlane wrote:
So is the new version v.1.3b1 distributive (Windows 7/8, MAC OS) OK to download?
I'm confused ...
it works but it's beta so a few issues in the nav area I noticed can be worked through though.
everything else ok from what I can tell
i never found them but the aircraft data comes from smartcockpit.com so if there is any data it would be there.
33 (edited by Franz007 2016-05-18 08:35:21)
I made some research and it seems that they are very rare or impossible to find. I downloaded now the take off performance Calculator 1.6. That are the speeds for the MS Flightsimulator but anyway, i am trying to use them for the Jar 330 ;-)
please send data and a link to calculator 1.6
thank-you very much you can PM me using the JAR PM ...
Please read and this is not joke. When I look at traffic at some airports, i saw what rare some traffic aircrafts gone under ground. That mean what scenery mesh have breaked surface. If so, a330 may detect RA as big and speed slow. Result - TOGA LOCK.
36
No, V1-VR should be calculated by pilot anyway. Yes, we done "help calculation", but it is not what real airbus done.
37
Ok, I will check APU fuelflow. Thank you!
Ok, thanks J.A. for your feedback to both points. Yes, the fuel flow of the APU ist here but really seems too low, thanks for taking a look at it. And i understand the strategy now about entering the v-speeds. The only problem ist that it is quite difficult to find the values who will fit to the plane, since values aren't available in the Internet. Or do you have a source where to find them? Where do you fill them from when you are flying?
@Captbullet: in fact you just enter "take off performance Calculator 1.6" in Google and should easily find it, thats what i made ;-) But as i said it was adaptet to work with the Airbusses for FSX. So i still dont know if they can be used with the Jar 330.
What happened with the custom failure implementation? I feel that this is a huge feature and looking forward to using it.
http://jardesign.org/forum/img/m/1256/t/p1ajbe4i2q1ugm1bf18rsme616nr5.png
http://jardesign.org/forum/img/m/1256/t/p1abdltcmujtb286vr2ve41dk73.png
40 (edited by Mad Mat 2016-05-25 10:14:40)
I found that when changing a STAR and a runway (I did it at JFK) the FMC maintained the wrong Missed Approach procedure and the wrong ILS frequency. I had to tune it manually.
41
Hi!
Lighting issue, i think.
http://jardesign.org/forum/img/m/1123/t/p1ak96dq5o5se11fbbjrilubgo3.png
Hy for this bug i have open a long time ago a tread in Aerosoft Forum. The Problem is that LOWS hit zwo Geographic tiles.
No one can help me for that.
Dirk
Regards / Grüße
Dirk
The plane has problem following LNAV in FMC. I have Navigraph datas. I planned LFRN-LIPE, t/o rwy 10 SID TABI2T. The aircraft seems to not recognizing the rwy waypoint in FMC and did not followed the next points in the route.
44
Closed, cause ver 1.3r1 posted. If you use b1, you not need install r1. Thanks for all your comments - will take it in account for ver.1.4 development.
