ilankrt wrote:cmckjodi wrote:What scenery do you use for KMIA? I tried using 2 from the scenery Gateway and created ATC taxi routes but none of them work. Have also used the included KMIA.dat Planes do not appear nor does flight info window on the lower left screen. It's weird because all of my other airports work perfectly including lots of unverified airports. Very odd problem. Running windows 10 64 bit. Oh well I will try and make Tampa work. Good luck with the test flights, I like KBOS great airport to fly into
If I am not mistaken, 2014 I purchased from X-Plane.org the KMIA airport, but as I looked at the images yesterday it seems to be
now an updated version. Anyway taxi in the air and on ground works perfectly... and I saw KBOS its really great.....I'm in! I will start on that route tomorrow (i'm based at KBOS). I have just set up my new iMac 27" (latest model full options). It is so much better than my MacBook before. Will also use the new A330 version.
First of all congratulations to your new iMac27 isn't it a fully different new world?! I never understood how people are enjoying simulation on a small screen because they are missing most of impotent details and views... Then I am glad about your partnership for our test flight serie and I red that you have similar experience on your first flight. Today I am beginning with my flight preparations from KMCO to KATL. (I am used to start my simulation from COLD and DARK) flying the A330 (best X-Plane airliner until now) So see you on route....
