So, I just signed up for the data on the sight that you provided.
now to look into how to implement it into something useful,
I could use some navigational tips on the website on the dat I need to be looking for.Ps, the system for pulling the Data out is quite difficult even for me and I will need someone to give me some instructions on the data and how to gleem the right data we need.
The data base is quite complex and one wrong move and we will have a mess before we start so it has to be done in a precise order and one country at a time so let make a list country, city, airport, or if some one else has a better Ideal I have two ears ...
Thank-you,
B.And the list needs to be of the X-Life Airports and that will make a starting point to the project easer ...
Note#1 if we are going to pull this off it will take the JAR Beta team to do this ...
There is another alternative, XCSoar, which I think is more better. And it is more open.
https://www.xcsoar.org/download/data.html
It has two formats which can be used:
* Openair format (http://www.winpilot.com/UsersGuide/UserAirspace.asp) (not to be mixed with openaip!)
* Tim Newport-Peace format (http://soaringweb.org/TP/sua.html)
The openaip format seems to have some type of license which I do not like:
* Exported on: 22.04.2016
* This data is owned by Butterfly Avionics GmbH and licensed under the CC BY-NC-SA,
* not to be used for commercial purposes. For more information on commercial licensing visit
* http://www.openaip.net/commercial-licensing
* openAIP data is not certified and must not be used for primary navigation or flight planning.
* NEVER RELY ON OPENAIP DATA. openAIP data contains errors. Using openAIP data may
* result in serious injury or death, use at your own risk!
* OPENAIP OFFERS THE WORK AS-IS AND MAKES NO REPRESENTATIONS OR WARRANTIES OF ANY KIND
* CONCERNING THE WORK, EXPRESS, IMPLIED, STATUTORY OR OTHERWISE, INCLUDING, WITHOUT LIMITATION,
* WARRANTIES OF TITLE, MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, NONINFRINGEMENT, OR
* THE ABSENCE OF LATENT OR OTHER DEFECTS, ACCURACY, OR THE PRESENCE OF ABSENCE OF ERRORS,
* WHETHER OR NOT DISCOVERABLE. SOME JURISDICTIONS DO NOT ALLOW THE EXCLUSION OF IMPLIED
* WARRANTIES, SO THIS EXCLUSION MAY NOT APPLY TO YOU.
* EXCEPT TO THE EXTENT REQUIRED BY APPLICABLE LAW, IN NO EVENT WILL OPENAIP BE LIABLE TO YOU ON
* ANY LEGAL THEORY FOR ANY SPECIAL, INCIDENTAL, CONSEQUENTIAL, PUNITIVE OR EXEMPLARY DAMAGES
* ARISING OUT OF THIS LICENSE OR THE USE OF THE WORK, EVEN IF OPENAIP HAS BEEN ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGES.
