Hi Eugeny,
just complete a test flight from LIRF to LFMN, all works like a charm execptfor the departure SID, the delivery not assign any SID.
Do you remember our flight with skype desktop sharing? In that flight i have had the same problem, deliver give the clereance but without SID.
For the rest all works fine
thanks for all
Yes, I remember, BUT seems like this is Navdata issue.. as example -
+We select LIRF RW25 for takeof.
+We find a SID at LIRF.txt proc file - EKLO5R
SID,EKLO5R,25,5
CA,0,248,2,410,0,0,0,0,0,0
DF,RF726,41.79547222,12.21821667,0, ,0.0,0.0,0,0,0,1,210,0,0,1
DF,RF701,41.83262778,12.13183611,2, ,0.0,0.0,2,2800,0,1,240,0,0,1
DF,RF703,41.71315833,12.14123333,0, ,0.0,0.0,2,6000,0,0,0,0,0,0
TF,EKLOS,41.57250000,12.30027778,0, ,0.0,0.0,0,0.00,2,8000,0,0,0,0,0,0
+We take Last SID point and it is EKLOS
+We try to build route to arrival using airways, open ats.txt file and.. and.. and..
THERE is No EKLOS point in the ats.txt That mean what EKLOS point not a part of ANY airroute and it can not be used for routebuilding. OOOOpssss! I am stuck.. ATC too, cause it use my brain logic ![]()
