726
ThommiTechnik wrote:
And the next one: EDDM - X-Life initializes OK, I'm typing in route, going to load .txt for route -> CTD. ReStart of XPL, same airport, same route into Garmin 530, trying to take generated route from plugin -> CTD
XPL 10.45, MacOS X 10.11.4
your main issue is this;
ERROR: language file line 'www.X-Plane.com for tech support contact info!==== Besuchen Sie bei Problemen www.X-Plane.com!' does not have the same leading spaces.
then you need to remove your  ;
Airport-Navigator v1.3.1
As this plugin is not needed for the X-Life plugin to work and takes to lone to load also has been known to cause CTD's
after your check on the above error messages see what happens.
Thanks Brian, I'll check and will report later!
728
i installed the last x-life plugin. In this version, i am missing the side menu where i can show the map with the other aircrafts or the other menue points.
Or it is only hiding?
729 (edited by ilankrt 2016-03-27 22:42:45)
Second Test Flight UMMS - UUEE, A330 XL v.09.3 on iMac
Again no crash
This time I captured the flight and I  will publish soon a video on my blog.
UUEE: there is one ATC failure advising landing on 7L instead of 06L (according to Navigraph charts from 12.2015).
I don't know if log.txt of a successful flight should be attached? ...
730 (edited by SirOTheOne 2016-03-28 08:02:49)
Flying from LOWI to LIMC via LIPZ (short stop) -> CTD -> see logs
one small bug: in LIPZ - ATIS and ATC datas are from INNSBRUCK (LOWI) and NOT from LIPZ (Venice)
731 (edited by pic 2016-03-28 08:45:50)
I believe if you go to the xplane plugin pull down menu and click on x-life you'll get a sub menu to show you the  option to choose deluxe, then you should be ready to go, if you have the deluxe that is.
732
Don't think, that this causes problems - if this would be the case, X-Life would have a bug, because there are some more languages in XPL than English wink
After the removal, EDDM worked fine. Thanks! Don't know, why I still had this in plugins, removed also other old corpses.
So, will report more on other airports., traffics, and so on.
Cheers, Thomas
733
For next version will be available to mark/unmark Runways for Departure and Arrival like this
http://jardesign.org/forum/img/m/22/t/p1aeugacbvubl19hvck210mg185i3.jpg
734
Excellent!
735
Hi JAR
I would like to understand this renewal .
Concerning runways it may help in two particular cases:
1. selection of ILS  runways at simulation begin, to avoid false APPR advice to land on GNSS RWY etc.
2. avoid airliner landing on too short runways.
This means preparation work before simulation, reading charts ....
Concerning gates how may it work? As I open X-Plane at airport XXXX, my aircraft model is places in a pre-selected
parking place. Now if I choose  with XL other parking excluding the momentan parking, what happens?
Does XL install my aircraft for new automatically on one of my chosen parking?
Or is it only a pre-instalation for the next time I use this airport?
736
Great news!! Excellent!!!!!!!
737
Normal, daily life, or?! wink
738
Hi JAR
If you need make one/any of runway disable for arrival or departure - this tool will be useful.
739 (edited by ThommiTechnik 2016-03-28 15:05:15)
OK, short trip from KDFW to KSFO
Good news:
• no more CTD
Things I would like to see to improve:
• TOD has to be come from ATC, not by me (or let's say both)
• takeover from center to next center
• I had in a radius of 100km only two planes, mostly behind me, and overtime the same (one Northwest, one LaudaAir), nothing else during flight (settings: traffic density 100%, stands busy 40%, runway operation 2min)
• possibilty to make FL-changes with permission from ATC
• and again: don't let me cross runways without short holdings. At KDFW I had to cross 17R/35L and 17C/35C, no ATC yelled at me, what the hell I'm doing
• and VFR routing smile
Cheers Thomas
740 (edited by ThommiTechnik 2016-03-28 15:16:18)
Oh, one more thing:
routing was (on actual METAR): KDFW SID TXO J72 BLD J86 FUZZY J110 CZQ STAR KSFO
And ATC wants to give me BDEGA2 as STAR. Impossible! If CZQ is last waypoint, I have to fly STAR CZQ.LOCKE1
Cheers Thomas
BTW: detour of 230nm
741
Good news:
• no more CTD
Cheers Thomas
well if you want the changes you better start learning how to write code ... as each takes time to process and set up in the plugin...
Cheers,
Ps, are you a real pilot and or what are you qualifications for flying?
742
Good news:
• no more CTD
Cheers Thomas
Need a time to coding all this.
743 (edited by ilankrt 2016-03-28 22:19:59)
Well at least I am used to made this preparations every time I am flying an airliner which or without LX.
Normal procedure yes, daily life as often as I am sitting in my cockpit armchair ....
http://jardesign.org/forum/img/m/1591/t/p1aevkukuhh4f1p7t10sp4keeft3.jpg
744
Another crash caused by X-Life
I notice also that there are several attempts to load an aircraft which fail. I wonder what I can do to stop this? This happens often.
Failed to open D:\Steam/steamapps/common/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Steam\steamapps\common\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
JARDesign plugin: D:\Steam\steamapps\common\X-Plane 10\Resources\plugins\X-Life\Metar/LFMN.TXT file updated.
SkyMaxx Pro: Changing cloud conditions.
SkyMaxx Pro: Created cirrus layer alt 9000.000000 thickness 0.000000
SkyMaxx Pro: Cloud conditions changed. Current target visibility is 94150.421875
DEF load time: 5366 for water.
0:54:53.088 I/SCN: DSF load time: 72285 for file Custom Scenery/Global Airports/Earth nav data/+40+000/+43+004.dsf (0 tris)
0:54:53.168 I/SCN: DSF load time: 12855 for file Custom Scenery/x_Prefab_Airports_1xp/Earth nav data/+40+000/+43+004.dsf (0 tris)
0:54:53.168 I/SCN: DSF load time: 23482 for file Custom Scenery/x_Prefab_Airports_2xp/Earth nav data/+40+000/+43+004.dsf (0 tris)
0:54:59.334 I/SCN: DSF load time: 6187028 for file Custom Scenery/zzz_hd_global_scenery3/Earth nav data/+40+000/+43+004.dsf (807277 tris)
0:55:01.948 E/SCN: Failed to find resource 'test/AGtrees_test.for', referenced from file 'Resources/default scenery/airport scenery/Vintage_Airports/Control_Towers/'.
0:55:02.060 I/SCN: DSF load time: 165080 for file Custom Scenery/Global Airports/Earth nav data/+40+000/+44+004.dsf (0 tris)
0:55:02.123 I/SCN: DSF load time: 17987 for file Custom Scenery/x_Prefab_Airports_1xp/Earth nav data/+40+000/+44+004.dsf (0 tris)
0:55:02.123 I/SCN: DSF load time: 13441 for file Custom Scenery/x_Prefab_Airports_2xp/Earth nav data/+40+000/+44+004.dsf (0 tris)
0:55:13.499 I/SCN: DSF load time: 11411919 for file Custom Scenery/zzz_hd_global_scenery3/Earth nav data/+40+000/+44+004.dsf (1193106 tris)
SkyMaxx Pro: Location set to lat 43.279200 lon 6.202724 alt 3656.946801
SkyMaxx Pro: Cloud conditions changed. Current target visibility is 76093.898438
0:57:12.140 I/ATC: Airport flow changed at EGLC!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: South
0:57:12.140 I/ATC: Changing EGLC CabState from 0 to 1
0:57:12.140 I/ATC: All departures are done at EGLC. Advancing...
0:57:12.140 I/ATC: Changing EGLC CabState from 1 to 2
0:57:12.140 I/ATC: All arrivals are done at EGLC. Advancing...
0:57:12.140 I/ATC: Changing EGLC CabState from 2 to 0
SkyMaxx Pro: Cloud conditions changed. Current target visibility is 67616.031250
745
Good Day,
lenny,
we need the whole log.txt and not copy and pasted into the window send it the right way please.
746 (edited by ThommiTechnik 2016-03-29 05:49:57)
I can imagine. And don't expect in the next hours to be done wink But I'm so excited, that something is going on, that I would like to see everything wink wink
What I'm wondering about, or let's better say thinking about: you have some good fellows here. Why not building some teams? One is doing the airports, the next one goes on ATC, on one team coding, or so? I think, for one man alone, it's a big To-Do-List.
I see a lot of people working on airports, but not really as much feedback's on routing, procedures, and so on.
Keep up the working smile
Cheers
Cheers,
As I said, maybe team building could help. I'm not programmer, just User wink And yes, I've got CPL, MPL, and TR on A320, A330, B757 and since December B777. Doing it as FO.
Cheers Thomas
748
Nice one...just keeps getting better smile Last flights during holidays were picture perfect. I did notice my tod was different from both aircraft and my xhsi cockpit, of course nothing to do with Xlife
749
Your log remains me about similarity to my crashes in the past.
I de-installed SkyMaxxPro3 and the problems disappeared.
Try it out and report if it works....
750
Cheers
I think that our keep on going test flights are a important help for JAR as developer. Personally I would not like to see
this development also in our (Other) hands, because it is not institutionalized and steady. We need professional development
for the long term perspective, so that XL can grow to main plugin for X-Plane. And once established it will probably be a payware.
(At the end it is a developer business)
As you are I am also exciting  and impatient to see X-Plane becoming through XL alive and I have same expectations. If some of us can do more then test flights (programing etc.) I think that JAR will be thankful for.
