And the next one: EDDM - X-Life initializes OK, I'm typing in route, going to load .txt for route -> CTD. ReStart of XPL, same airport, same route into Garmin 530, trying to take generated route from plugin -> CTD
XPL 10.45, MacOS X 10.11.4
your main issue is this;
ERROR: language file line 'www.X-Plane.com for tech support contact info!==== Besuchen Sie bei Problemen www.X-Plane.com!' does not have the same leading spaces.
then you need to remove your ;
Airport-Navigator v1.3.1
As this plugin is not needed for the X-Life plugin to work and takes to lone to load also has been known to cause CTD's
after your check on the above error messages see what happens.
