676
BadiBadu wrote:
Hi JAR,
Thank you for your answer!
Do you know how to get the weather from the NOAA servers into the a320/330??
Best regards,
a320/330 get report from X-Plane file (it is old if you checkoff realweather option)
XL get actual weather direct from NOAA servers, it is always new
X-Plane will do this if you "real weather" X-Plane option turned On.
Also with the x-plane real World Weather option enabled, the weather displayed in x-life is different then the weather displayed in A320 cockpit.
Very annoying!, but I think we are getting off topic....
Best regards,
677
regarding to this text below, I've made some tests with some airports regarding to traffic problems,
here are the results (for those who have problems with ATC routes and no traffic, only 1 time traffic and so on):
1) you need a correct ATC route for the airport, that's clear. but this is not very complicated.
2) If you do not have traffic now, you are running in one of the following problems:
  a) the airport has no SID defined in AIRAC cycle. It's just easy: No SID, NO outgoing traffic.
      ==> Easy to check: Open X-Life flight plan, enter a route and press generate. If you do not get a route
                                      (empty output) you will not have traffic.
      CYXC is a candidate for exactly this problem. You will never get traffic here. We need an updated X-Life.
  b) you have only one runway defined in AIRAC cycle (as APP or FINAL)
      ==> Easy to check: Set weather manually. Set wind speed >20kt, direction parallel to runway in one or
                                      other direction. Example: Runway 16/34, set wind to 160deg and test. Then set wind to 340 deg
                                      and test.
       CYXC is a candidate for this: It has only Runway 16 defined in AIRAC, so if you set this to tailwind, you will not have
                                                    incoming traffic. If you set correct wind, you will have incoming traffic. If you switch on
                                                    real weather, you may or may not have incoming traffic...
At the end, both problems should be resolved to get also smaller airports running.
Bug a) should be resolved fast, because it affects also the A320/A330 FMC which is not working correctly here.
Bug b) can be resolved by enabling tailwind landings on airports which have only 1 runway defined.
Best regards,
Hi Mr. Romanov,     please read this :-)
There is a really big bug in Flight Plan route calculation (in xlife, A320, A330)
- It is NOT POSSIBLE to calculate a route where no SID is defined in AIRAC Cycle in dep. airport
- If there is no SID defined in dep. airport, it is NOT POSSIBLE to get a complete flight plan in A320 + A330
How to reproduce this bug every time (it's NOT the airport CYXC !!):
- install included airport CYXC
- we try to calculate a route from CYXC to KSFO
1) start x-life
2) hotstart A320neo2.6b4
3) open x-life Flight Plan
4) ENTER: dep: CYXC, arr: KSFO, altern: KSFO, Level: 320
5) Press "Generate"
Result: Nothing, empty flight plan. Does not work. You won't be able to generate a route.
6) in FMC A320, enter: CYXC/KSFO in init page (from/to)
7) switch to F-PLAN
8) set departure and arrival SID/STAR, does not matter what you set.
Result: "Flight Plan Dis." which is not removable.
You can not delete the Flight Plan Dis., regardless what you do.
===> This does not work.
9) Install the included modified_navdata_CYXC.txt in "GNS430/navdata/proc/CYXC.txt", but BACK UP the old version
     (because my modifications are NOT real world, just to show what is going wrong)
     (it's a simple modification, I copied the SID from CYYC and corrected the names. This is logically nonsense,
      but technically your generator thinks that there are valid SIDs at the airport).
10) restart x-plane, goto 1) and restart :-)
Result:
a) Flight plan calculation works now.
b) no more "Flight Plan Dis." in A320 which can not be removed. Select any SID and remove the "Flight Plan Dis."
Conclusion:
==> Route calculation needs to be fixed, FMC needs to be fixed (same bug)  :-)
(don't forget to restore the original AIRAC data backed up before....)
Best regards,
678
                                      and test.
Best regards,
1) start x-life
5) Press "Generate"
7) switch to F-PLAN
Result:
Conclusion:
Best regards,
Thanks for the exploring and explanation! So this means, e.g. for LIRJ, a well populated airport during the summertime for tourists, there will never be a chance for ATC? Because, there was, is, and will never be foreseen a SID, it's VFR to (mostly) ELB, and from there IFR.
Cheers, Thomas
679 (edited by captbullett 2016-03-25 13:50:27)
                                      and test.
Best regards,
1) start x-life
5) Press "Generate"
7) switch to F-PLAN
Result:
Conclusion:
Best regards,
So all of this information tells me that people are going into the X-Life plugin and doing to much manipulation of files in X-Life that should not be touched.
Yes, there are files that you need to work with but you need to know what you are doing or else, you run in to issues and then call them "Big Bugs" when they are not 'Big Bugs" they are operators going into files and corrupting the files.
So, to fix you then either need to clear the file or re-install the X-Life plugin to make sure it works right.
A master list needs to be made so people know what file are ok to work with and what files are not to be touched also how to clear a corrupted file and reinstall the file again. for those who have a external Back-up disk its' easy to pull a file from it.
If you don't have a back-up dick then you have to re-download the file.
Where do you read, that there's manipulation of files regarding to X-Life?!
681
This is a useless discussion.  CYXC ist not on the JAR list for approved airports.
https://www.google.com/maps/d/viewer?mi … ecn3NB3GZ8
So, if you want to fly under XL use only this airports.
Remember this is a beta test version......
682
You're absolutely true, when saying, it's Beta. Or also useless on some points. And on the other side I think, Ramzzess expectations to himself are, to make a really good working plugin. So therefore you have the Beta, to figure out ALL circumstances.
As I said earlier, take LIRJ. First VFR, then IFR. Has to be included into the considerations. Otherwise a public beta makes no sense (also when you have to pay in a beta for Deluxe things!), or make a closed beta for some testers.
But come on, it's Good Friday, so we have to be silent wink
683
Cheers, Thomas
Nope, this just means that there is a bug which prevents route generation.
A bugfix would be enough :-)
Nope, it's not useless and this has nothing to do with approved or not approved airports.
Who's the owner of AIRAC ?? You know that ? Where does this info come from ?
If this people decide to remove all SIDs from a "JAR list approved" airport you will see that your
super puper approved airport stops working from one minute to the other.
This "approved list" is a nice feature, you have a "manual check" that these airports will work correct,
but it's not a guarantee, and it should not be taken as an excuse for not solving bugs or even
not seeing bugs.
685 (edited by thomas_99 2016-03-25 17:05:41)
Sorry, but I can not understand you any more.
I don't know what you want to achive here, but what you are doing is really contra-productive.
  1 ) there was no manipulation of files in X-Life or x-plane from me.
       I've manipulated the AIRAC data, which does not belong to X-Life nor X-Plane nor JAR A320/330 products.
       These files are manipulated and touched every month by 3rd. party people.
       This is just done to show where exactly the bug is. It's not in CYXC airport.
  2) If important things are not working as expected, I will call them big bugs.
      Routing generation (doesn't matter if in x-life, A320neo or A330) is an important and central feature.
      This is a big bug in X-life, and I would call it big bug in A320/330, because it prevents you to generate a
      valid flight plan from every airport.
      E.g. the a320/330 joystick init bug (I've reported) is a small one.
686 (edited by TKurzweg 2016-03-25 19:49:06)
This moment I installed Beta 9.3...x-plane is out of order...no more working !
687
Yeah. I have same problem.
Attachment icon 5df388cb-edb6-451a-b67d-249a87dae6f9.dmp 110.62 kb, 443 downloads since 2016-03-25
688
Upload of X-Life Beta 9.3 was corrupted....start a new download for working !!!!
689
not seeing bugs.
The forum situation should be calm and friendly. All users that do should contribute to the development and improvement, cause all users want just a better products. Everything that is not conducive to development - is not welcome, because it is destructively. Since (I see) You do not like to use this product, and it causes you a lot of discomfort (I'm sorry) - please use any another traffic that you like.
Any software presented to the user "as is". It is common practice. At the moment, the developer was able to make the program at the level that you can see now. If you want to improve the program - help and wait. If you do not like the software - select another. Seriously - any developer can offer you only the this plan.
690
Beta 9.3 Uploaded. Main New is sound. I am not sure what soundsamples is great, but thats all what I can make for one week. Sure, users can change samples with own. Sound folder is good for that smile Please inform me about your feelings with sound!
691 (edited by captbullett 2016-03-25 22:26:14)
Thank-you JAR as I see that you are working on sound I am doing an up-grade on lap-top and another issue
the png will explain everything so have a very good Easter Sunday.
and Thank-you,
Attachment icon Screen Shot 2016-03-25 at 2.55.29 PM.png 92.71 kb, 211 downloads since 2016-03-25
692
Thanks JAR, sound is amazing ! have record a movie from GCRR with X-Life Traffic...works great, and the sound.....lovely !
693
Good night.
Thanks for the great plugin. Every day he gets better and better. Today I tried the update with the sounds, the traffic became much more realistic. But in the middle of the file "Sound\JetD\start.wav" voices. I think it's not right. Thanks again for quality products for x-plane.
Доброй ночи. Спасибо за отличный плагин. С каждым днем он становиться лучше и лучше. Сегодня попробовал обновление со звуками, трафик стал намного реалистичнее. Но в середине файла "Sound\JetD\start.wav" слышны голоса. Думаю это не правильно. Еще раз спасибо за качественные продукты для x-plane.
694
Is this here about maybe a good plugin, from the thoughts, or RT?!
695
Great! Gonna DL now and TEST!!! and, well said about that situation. We ARE Beta!!!
696 (edited by captbullett 2016-03-26 03:18:35)
Yes, I agree We have a good team of Beta and I said this over on X-Plane.org that this group of Beta testers is one of the better groups of Beta testers I work with because, We work as a Team and we communicate to solve issues and put out one of the best plugins to come out in a long time. So keep up the good work.
Yes, Thank-you for all the Great Work Everyone did in testing and designing the X-Life Plugin.
captbullett.
697
Hi everyone. Been away on holiday for a week in the African bush.
Could not wait to check out development of XL when I was absent.
Quickly grabbed the newest version.
Thanks Jar. I love the sound. Will be doing a flight today from Aerosoft EGLL to LYBE (MB Sceneries available on org store).
I did some editing on LYBE last week, and want to test it in an actual flight.
Will check back in when done, and upload airport files if it worked properly.
698
EXCELLENT..what a treat!!! This gave X-Life a new dimension...a dimension of sound! Thank you Mr R! And a happy Blessed Easter to you and your family.
and you too Brian!!!!!
699
Don't get me wrong, I don't want to offend, appreciate the work, to make ATC better and better in XPL. At this moment two people are working on it (and I think, Austin too wink ).
Today I will test X-Life under VFR circumstances. Required message points, Altitudes, Restricted airspace's, and so on. Will report later, or tomorrow. Looks like most are testing with aircrafts. But VFR ist the leading activity of ATC, especially on small airports. Here I see the challenge for X-Life.
What I don't like, makes me angry:
• praising, fellowing, when people are also reporting bugs, criticizing. This is also part of tests.
• no reacting from devs (either on bugs/inputs of planes or plug-ins)
Cheers
I'm loving it !
Could watch an airport for hours! :-)
