J.A.Romanov wrote:captbullett wrote:Good day,
the X-Life latest version on my Mac will not run so this is what we have been looking for to De-bug the issue I just hope it can be re-produced.
data to follow...
the aircraft was on the taxi and then the CTD the last CTD was on the same Flight Pattern and was just two min in the air when the CTD happened.
the next step is to see if they happens on another route as I think this is a route issue and not an X-Life issue.
the route is the control route EHAM/EDDH ; EDDH/EHAM and I do not think it will work so a new rout is needed that will not cause a CTD.
Note#1 Yes this is a Route based CTD and not a X-Life CTD the next flight EGLL/EHAM is working so far will keep posted on any issues but no CTD at first so is EHAM or EDDH scenery pack causing issue when you use as departing airport.
Thanks! Apple crashreport + log.txt = useful a lot!
Most welcome I also have the EGLL/EHAM flight right after this flight to compare since, I think this is more than X-Life no.
B
Note#1
This route was good until I was close to the runway under 600 feet I do believe and i was told to go-around I did not see any traffic nor, did I get a warning.
2) I had an issue with the view locking into an abnormal view so I could not see what I was trying to do.
3) I had a conflict and was told to land after all I do believe the log will have to be gone through line by line.
4) Because of the issues I did not do the go-around but landed and closed the XP app and now sending the data.
5) I need to test some more as I also just up-dated the Nav-data to cycle 1603.
6) I think this covers everything so just incase I missed something anyone can point to the issue and Post the data.
thank-you for your help JAR and the rest of the Beta testers.
