326
Then what aircraft are you using to fly in X-Life?
and then you need to send the Log.txt in full not just part of it.
and do you not read other post and see how others are doing things
come on man !
I do not have time to hold your hand.
PM1970 wrote:
Thanks for the info. I don't have neither of these 2 aircraft...
it is in the  //* Main aircraft folder/A320Nev2/bbox
or the //* Main aircraft folder/A330/bbox.txt
and you will find it right below the airfoil folder if your file system is in order .
thank-you for your help,
So much,
PM1970 wrote:
Where do I get the file bbox ?!
327 (edited by captbullett 2016-03-03 14:37:56)
Now on to the pressing matters I have now set-up a control route but ComCast was down last night and I could not send any data.
so here is a CTD using the new CTD catching HotFix.
this is the control route but it was generated by the widget because the route that was generated by the online flight planner had issues and I need to check out why now. this CTD happened just 5-10 min. into the flight and there was no apparent reason for a CTD to happen, so the CTD De-buger should have some data.
328
pic wrote:
Hi..just use the same destination for that. So, if you go from LIRF to LFMN, just use LFMN again for your alternate airport.
why ATC don't work on flightplans where the airports don't have ATC routes ??? ATC need the ATCroutes of airports for work ?????
When i try to make a flightplan with a destination who don't have ATCroutes, X-L say "the alternate airport is wrong".
Thank you. It's exactly what i do. That don't work.
ATC just match with airports where there are ATC routes. 27 airports in the world .... TOP !
And like i say in my other posts... But nobody answer... We can't try to make ATCroutes 'cause the airports must be validate.
How can we learn to create if we can't test.
Perhaps i will know a day in the future if someone would answer me...
No problem to answer you, but what is your quest? And sure - i am online at skype j.a.romanov to be fast.
329
you have to run your permissions as an Administrator and then you need to up-date you OpenSceneryX  PC's you permissions need to be set right or you will have these kinds of issues.
B.
Metallist wrote:
In the file log.txt errors have been found associated with objects from the OpenSceneryX library. The contents of one of the folders in the screenshot. The OpenSceneryX library updated.
"Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj"
http://jardesign.org/forum/img/m/2023/t/p1actoliiptoosg4bh1gp81a053.png
330
I don't understand your post, I fly with B777, I think that nothing is saying in the plugin to fly with A320 or A330 !!!!
But no problem at all, I see what is going on, just will wait until a final version will get out...
Thanks wink
come on man !
So much,
this is information based we need to work together and if you did not understand something then please ask I am the first to try to answer you question but when you see that other are sending log.txt and bbox.txt and this sight is for JAR A320Ne and A330 mainly and after testing then the other aircraft can be used I have tried to beta test the MD-80 also and it was not ready for X-Life so I cannot say this is your issue without your log.txt but this si why I was maybe too strong language I am apologizing for that but I have very many people i like to help and it take several mins. to type each response because I give the details I do not want you to go I just want the log.txt so we can de-bug the issues.
thank-for your time,
Thanks wink
come on man !
332
That's not correct. I also have these issues, and OpensceneryX is correctly installed and the latest version.
if you copy D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/object.obj" to D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj"
the OpensceneryX installer will even remove this file.
B.
good day,
good to know so how do we fix I have had this same issue also, on the Mac is, this a reason for the CTD's that people are experiencing ? this is the type of data and feed back I and JAR need and this communication is great!
thank-you much,
B.
basically both files are available in E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x
but not in the subfolders "unlit" and "lit".. So I manually copied them there and no further issues in the log.
335
Crash nr.3 and nr.4.
336
And the next OpenSceneryX update removes the files.
And, if you do so, you will get a plane like this:
http://jardesign.org/forum/img/m/552/t/p1acuo6ipkfk3bmlif1ubt1jb43.jpg
better fix this in a proper manner.
B.
Good evening. OpensceneryX is correctly installed and the latest version. All run and updated with permissions as an Administrator.
338
thank-you for the information.
339
What to do with citation_x I understand, and what to do with error A320?
340
Crash as soon as I get airborne from EFTP with latest X-Life with Carenado C90 and Carenado PC-12. See log...
341
this is your first issue;
0:01:33.733 E/SYS: | There was a problem loading the scenery package:
0:01:33.733 E/SYS: | Custom Scenery/EFHE - Helsinki Hernesaari Heliport and Landmarks/
0:01:33.733 E/SYS: | The scenery may not look correct.
0:01:33.733 E/SYS: | Please see the log.txt file for detailed error information.
0:01:33.733 E/SYS: | (io_dsf.cpp:694)
0:01:33.733 E/SYS: +-------------------------------------------------------------------------------
so something is not loaded like a library ? for the scenery pack and you might have to re-install a library as they can get corrupted.
so, just look at what you have loaded in the way of libraries and they can look fine but this is why you are getting error message ...
342 (edited by Metallist 2016-03-03 23:29:28)
Don't forget to update to the latest version 8 with HotFix 2, You use HotFix 1
343
good day,
1603 up date on the Nav cycle so please up-date so we are all on the same cycle.
I will do this in the AM thank-you for your help.
Hi Metallist, If I'm not mistaken, D:\Games\X-Plane 10 is a system owned file structure. I'm told that this is not good for xplane. I was told to put the complete xplane file on the desktop, non system owned.  Maybe this is the problem. Hope that helps!
ciao
di Luigi
345
ciao
di Luigi
Hi, Pic, D:\Games\X-Plane 10 are not system partition and a separate drive for software installation. The problem is that the liveries from the Opensceneryx library have the following structure "Model airplane/livery/livery file.obj", and the livery of the A320/frontier has an additional 4 options and is as follows "aircraft Model/livery/variant/livery file.obj".
346
Thanks wink
come on man !
I don't have the Airbuses.
The following aircraft worked perfectly.
Rotate MD80 (latest update)
FJS Q400
I have quite a few other aircraft (all pay ware) that I intend to try out.
PS! I had only 2 problems so far, both of which was resolved.
1) Real time anti virus prevented X-Life to write to hard drive.
2) No TOD call (Latest Beta addressed it).
Perhaps we can Start a thread of its own where we post successful flights so others can see what works.
1) Aircraft used
2) Route + Airac cycle
3) Airports used
This method can set benchmarks, and problems might be easier to identify.
347 (edited by pic 2016-03-04 11:08:26)
Thanks wink
FJS Q400
1) Aircraft used
3) Airports used
Thats a good idea, post successful flights and see what works. For grins and giggles, I'll post my last flight.
Excellent flight, Only 2 problems.
1. I first loaded the JAR A320, started everything and entered my flight plan. (LFMN-LIRF) When I wanted to port it over to the FMS, nothing happened. I repeated this and still no flight plan loaded...so, I loaded up the JAR A330 and all worked great..fms loaded, atc, tod, until I got to my final..
2. When I got clearance to land, after reporting my ILS capture I was of course lined up and at 1,00ft agl I took over from the AP..touchdown and rollout..then ATC informed me to do a go-around as I was decelerating to about 70...I ignored and then just went to a terminal.
So, the only MAJOR problem was why it wasn't loading the flight plan into the A320 fms, the A330 problem is fairly minor.
I attached my files (inc the bbc box files...attachment 1 the 320, 2 is the 330, 3 is the log)
FlightPlan: LFMN SID SODRI A3 NORKA A3 SUDAS UL127 CAPCO A3 MIRSA L127 ELB M729 GILIO STAR LIRF
AIRAC cycle is 1602 (changing to 1603 this weekend)
Attachment icon bbox_log.txt 108 b, 309 downloads since 2016-03-04
348
Shouldn't be an issue because I removed the scenery later and it still crashed by X-life.
I must have missed that update. Will download that and retry the scenario... Thank's!
349 (edited by captbullett 2016-03-04 15:01:55)
FJS Q400
1) Aircraft used
3) Airports used
Great work this is the type of Beta report we need and this is how I send an Apple Beta report very complete and full of detail.
So, if JAR wants to put the data for the other aircraft on a new pined topic I think is good. i am a very open minded person since i do not know everything and the best Ideals come from the people one works with.
2) we also need good and bad log.txt while we are running the CTD logging txt this give JAR an example of the good and bad since this CTD is not easy to track and I have not been able to find it either.
#3 I want to thank-you again so much for your work please do not give up its not easy but this is part of Beta testing the paperwork is part of the work.
Your Friend,
350 (edited by captbullett 2016-03-04 18:03:59)
the X-Life latest version on my Mac will not run so this is what we have been looking for to De-bug the issue I just hope it can be re-produced.
data to follow...
the aircraft was on the taxi and then the CTD the last CTD was on the same Flight Pattern and was just two min in the air when the CTD happened.
the next step is to see if they happens on another route as I think this is a route issue and not an X-Life issue.
the route is the control route EHAM/EDDH ; EDDH/EHAM  and I do not think it will work so a new rout is needed that will not cause a CTD.
Note#1 Yes this is a Route based CTD and not a X-Life CTD the next flight EGLL/EHAM is working so far will keep posted on any issues but no CTD at first so is EHAM or EDDH scenery pack causing issue when you use as departing airport.
Attachment icon Apple Problem Report for X-Life March :4:2016.txt 60.71 kb, 360 downloads since 2016-03-04
