I have created Taxi routes for three airports approx. 80 kms apart and installed the three xxxx.dat files in the airports folder of X-Life. Started X-Plane, started X-Life, agreed to the license and started the plugin. Edited the start locations for the aircraft type etc. and saved the created xxxx.txt also in the airports folder. All looks okay. some aircraft appear at the locations specfied.
I can file a Flight Plan for myself and fly to one of the three airports and that works fine, right up to the gate.
All the sliders in the settings selection are set to mid range. I left it running for over an hour and never did an aircraft leave the stand location where it appeared at startup. One aircraft arrived ( don't know from where ) and went to a gate as I would have expected. But I did expect that over a hour span there would have been some aircraft leave the airport and some more arrive.
Is this a bug you are still working on or is there some way to make it more active. I have tried setting the sliders for more activity but its the same no matter where they are set.
I am running the latest beta version on a Mac
