in attach my error during the registration for delux when enter my email-
thanks in advance
You just enter "46e9-9222" as email. I delete it now. Please try again.
thanks in advance
Perfect, it's works now..
thanks a lot, begin my tests
28 (edited by SirOTheOne 2016-02-17 21:05:18)
Hi to all,
First test flight with beta 6 from LOWS to LOWW without any problems, ATC and all other stuff seems to be correct.
perfect work to Evgeny and the team
29 (edited by laohu314 2016-02-17 21:35:23)
I'm so sad. Beta6 crashes XP on start.
Beta5 worked fine, nothing else changed.
30
Yep, I see what function have crash. Thanks for log. I ask you to full delete current X-Life installation, redownload and reinstall X-Life and run. Please report if Ok. If no luck, please contact me direct via skype j.a.romanov - I will try to build debug version for you to determinate exact place with error.
Hi laohu314,
i had the same problem
now it works: x-plane 10.42 (not 10.45rc1 or rc2 or what else), install beta 6 and register -> and it works
check it out
Thanks SirOTheOne!
Wow. Isn't that a bit retrograde. How do I get 10.42 back?
33 (edited by laohu314 2016-02-17 22:12:13)
Well, 10.42 reinstalled and same thing. CTD on start.
Very disappointing! Maybe it is because I am running OS X 10.11.3
I am not going to downgrade the OS. If new software doesn't run on the latest OS, it's useless IMHO.
Should work with ElCapitan, sure.
Are you reinstall X-Life?
If yes - only way to check this via skype..
Thanks Evgeny!
Yes, I did re-install X-Life as well.
I seem to have other problems now too. After downgrading to 10.42 and upgrading again to 10.45 my X-Plane quits constantly and FlyWithLua seems to be fried as well. So I need to sort out my installation. Maybe a clean new 10.42? Did you try 10.45rc2?
Once I have a stable XP and if XL is still not working I might try to contact you via Skype.
36 (edited by captbullett 2016-02-17 23:31:22)
you might be right on the 10.11.3 since, I have been able to run one flight on the Beta 6 with good results and I am running 10.10.5 so far I also changes the XML that was posted by JAR.
37
Happy to report that I was now able to register b6 and generate a flight plan (XP10.45r2, OS X 10.11.3, and newly downloaded XL). Since I still have Lua issues I didn't go further.
The culprit might have been that I had HDR turned off while I was trying to cope with my dismal FPS situation.
Evgeny, you might want to check if that is true.
XL DOES ROCK!
38 (edited by captbullett 2016-02-18 01:24:18)
Good Day,
Ok, now I have used all Airbuses since, I started testing but the flight I am working on now the DHC-6 is the first 3-Party aircraft i am using why DHC-6 because, it is an aircraft where I know the radios and transponder are easy to use which is a pre-requisite for X-Life since, we have to now set to the right frequencies and the DHC-6 just happens to be very easy to do just that.
For me this is phase 2 of testing to see which other aircraft will be the easiest to work with within XL.
You're welcome, Sir wink
Hello JAR,
with x-plane 10.42 the plugin (beta 6) and the license agreement works.
Thanks to pic, it works
40
Hi Mr. Romanov,
Really nor, but for this development stage it is a way to guarantee what airport is really ready. Else, plugin should check apt.dat to determinate if all needed data present inside. I will fix this for next stage.
I got it working.
Maybe interesting for others who want to add ATC routes:
1) You can use x-plane WED to add ATC routes.
2) assign correct plane types to pads, or you will see an A380 on a 1000m runway
3) export apt.dat, this file belongs to customscenery\XXXX  (e.g. CustomScenery/EDNY/)
This is usually enough for:
- getting FMCar working
- getting X-Life Traffic working
what does not work: X-Life route generation.
4) in xplane, start x-life gate editor.
5) assign plane sizes to gates, define which plane size every gate can handle
    (yes, it's the same what is done in WED editor....)
6) Save it !  This will generate a text file (e.g. EDNY.txt) in x-life/airports/
     This file is important. no XXXX.txt -> no route generation
Now route generation in x-life is working.
Hi, will the tug master can also call by x-life later?
42 (edited by SirOTheOne 2016-02-18 12:21:34)
Hi Evgeny,
small bug:
flying from EDDM to EGLL with short stop in EDDH
-) flying from EDDM to EDDH: everything okay, but departure in EDDH to EGLL wrong Delivery and ATIS (see .png)
Is this really need? cause I can..
44
Hi Evgeny,
small bug:
Not understand what wrong. With ATIS? Please, some details!
45
i've a crash of xp when click on airplane icon on x-life menu, in attacc the log.txt
I try again
thanks in advance
Hello.
Tried this in Nice airport. Works well but I cannot remove the licence box. Clicking read licence just brings me to this forum and I never get an 'agree' option. I have made Internet Explorer my default browser. PC is Windows 10 running 10.45RC2. Does it just not work yet on 10.45? If so I'll wait for an update because I don't want to downgrade.
From a first look this is excellent work (I really like all the JAR add-ons). Works very well without needing to use Python scripts etc. to make the ground routes (unlike World Traffic). I will try to make some WED ATC layouts for more UK airports.
Thanks again JAR.
I assume you will upgrade the AI plane models so the gear retracts, the wheels rotate etc. I guess that is the easy bit once the routings work well. Are you allowed to use the Bluebell aircraft packs on x-plane.org? They work really well in World Traffic.
ahstewart40 wrote:
Hello.
Thanks again JAR.
Please use this hotfix to solve Read license issue
Need just delete old .xpl files from X-Life folder and put new.
48
Oh great idea...would be much appreciate!
49
I just received the error 'X-plane crashed due to plug-in X-life'. I know it's not helpful! But it has crashed 2 times at exactly the point of the flight, about 2-3 seconds after rotation during takeoff. Is this when X-life switches state? For example from a 'user on the ground' state to 'user in the air'. Aircraft was JAR 320 NEO and airport as the LFMN Nice add-on. I'll continue to test and disable other plug-ins but maybe others are having the plug-in crash just after take-off problem too.
The log text immediately before the crash says:
0:20:55.266 I/FLT: Init dat_p0 type:loc_ram apt:KFMN rwy 04R
OpenSceneryXpath find
50
Just complete my flight from Zurich to Heathrow, this is my problem:
-The delivery give me the clearence say "autorized to Zurich" (and not Heatrow)
-All ok for taxy, hold and short, line up ad take off-
-After take off The approach give me the first step for 9000ft and after to climb to fl370 (my cruise altitude), from that moment I not have received any other instructions, i'm arrived to the gate at EGLL in abolute silence from ATC
In the radar I could see the planes in flight but arrived at the airport EGLL was desert. The traffic was on
Attach the log, i hope could be helpful
