Topic: X-Life public beta-5 090216 (Win & Mac)
-----What New?---------------------------------------->
Beta 5 090216 (actual)
+ improve Radar/Map
+ add/fixed Import/Export functions at Fpln panel
+ improve ATC panel autohide
+ Improve markers drawing
Beta 4 010216 (old)
+ add GoAround ATC pattern
+ add Screen-side menu
+ possibility to turn traffic Off with side-menu
+ improve aircraft markers info
+ improve ATC panel auto-hide
Beta 3 (old)
+ Add ATIS info for Departure/Arrival airports to ATC panel
+ Add ability to start descend when pilot ready (ATC phrase)
+ Tune climb angles (takeoff phase) for AI aircrafts
+ Add cruise flight level checking by ATC (0-180-360 rules)
+ Add dark map background
+ SQUACK code by ATC fixed
+ Add transponder mode ATC check (when you on runway / leave runway)
+ Follow Me car route fixed (stop FMCar before runway)
+ add screen warning messages for different situations
+ add ATC voice (need improve, but work now). Can be turned On/Off via X-Plane menu
+ add data checking after entered at FlightPlan panel
+ add visual indication of runway vacation direction after landing
+ add lights for AI aircrafts
+ add more sceneries/airports
+ improve ATC voice phraseology
Beta 2 030116 (old)
+ add Windows version
+ unlock airports for beta-tests
+ panels "out of screen" fixed
+ perfomance improve
FUTURE TASKS:
Requested features (not released jet)
- Add ATC requests what ATC not get readback from pilot
- rework towing/engine start phase for AI aircrafts
- add Alt/FL ATC clearance with constrains (take in account)
- add true radio freq from reallife
- increase airtraffic generation density
- add crossing RW for user
- separate/mark runways for departure/arrival when need
- ATC vectoring along flightplan
Serial for Windows users: XL-BETA-090216-WIN
Serial for Mac OSX users: XL-BETA-090216-MAC
-------FOR USERs---------------------------------------->
You can use this version with airports what are always have custom ATC-routed description. Please use this map https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a link for this sceneries.
-------FOR ScENERIES DEVELOPERS-------------------->
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Please use this guide for details http://jardesign.org/forum/viewtopic.php?id=1670
-------X-Life DOWNLOAD LINK-------------------------->
MAC/WIN preview beta Download link -
www.jardesign.org/x-life/download/xlife_090216b5.zip
-------HOW TO INSTALL--------------------------------->
You can find Instruction inside .zip Please Read and Follow it!
-------HOW TO USE / Example flight ------------------------>
example flight https://youtu.be/-PHKHSJLr08?t=1s
-------About FMCar-------------------------------------->
If you use FMCar, please update your version - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.4r1 MAC OS / Windows - http://jardesign.org/forum/viewtopic.php?id=1633
