Topic: X-Life public beta-5 090216 (Win & Mac)
-----What New?---------------------------------------->
Beta 5 090216 (actual)
+ improve Radar/Map
+ add/fixed Import/Export functions at Fpln panel
+ improve ATC panel autohide
+ Improve markers drawing
Beta 4 010216 (old)
+ add GoAround ATC pattern
+ add Screen-side menu
+ possibility to turn traffic Off with side-menu
+ improve aircraft markers info
+ improve ATC panel auto-hide
Beta 3 (old)
+ Add ATIS info for Departure/Arrival airports to ATC panel
+ Add ability to start descend when pilot ready (ATC phrase)
+ Tune climb angles (takeoff phase) for AI aircrafts
+ Add cruise flight level checking by ATC (0-180-360 rules)
+ Add dark map background
+ SQUACK code by ATC fixed
+ Add transponder mode ATC check (when you on runway / leave runway)
+ Follow Me car route fixed (stop FMCar before runway)
+ add screen warning messages for different situations
+ add ATC voice (need improve, but work now). Can be turned On/Off via X-Plane menu
+ add data checking after entered at FlightPlan panel
+ add visual indication of runway vacation direction after landing
+ add lights for AI aircrafts
+ add more sceneries/airports
+ improve ATC voice phraseology
Beta 2 030116 (old)
+ add Windows version
+ unlock airports for beta-tests
+ panels "out of screen" fixed
+ perfomance improve
FUTURE TASKS:
Requested features (not released jet)
- Add ATC requests what ATC not get readback from pilot
- rework towing/engine start phase for AI aircrafts
- add Alt/FL ATC clearance with constrains (take in account)
- add true radio freq from reallife
- increase airtraffic generation density
- add crossing RW for user
- separate/mark runways for departure/arrival when need
- ATC vectoring along flightplan
Serial for Windows users: XL-BETA-090216-WIN
Serial for Mac OSX users: XL-BETA-090216-MAC
You can use this version with airports what are always have custom ATC-routed description. Please use this map https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a link for this sceneries.
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Please use this guide for details http://jardesign.org/forum/viewtopic.php?id=1670
-------X-Life DOWNLOAD LINK-------------------------->
MAC/WIN preview beta Download link -
www.jardesign.org/x-life/download/xlife_090216b5.zip
-------HOW TO USE / Example flight ------------------------>
If you use FMCar, please update your version - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.4r1 MAC OS / Windows - http://jardesign.org/forum/viewtopic.php?id=1633
2 (edited by captbullett 2016-02-09 16:07:15)
Re: X-Life public beta-5 090216 (Win & Mac)
everyone I am back testing and feeling good, the improvements are very good so the first flight is, EGLL/EDDL and it was a txt from the flight plan file.
3 (edited by ivota 2016-02-10 12:19:59)
I just tested.
Great an idea, great plugin, good job.
Thanks JAR.
Here is full test flight (on poor english):
LOWW-EDDM (with GO).
http://www.twitch.tv/ivota_hr/v/43081251
to improve plugin in future, maybe fix or add:
- only read x-plane weather
- ATC voice was too low
- no switch atc from APPR to CENTER (shoud be when passed TL)
- readback had no voice  option
- automatic switching ATC sequence
Beautiful! Only thing is that some planes do not appear...only squares with the ID and flight info. I have the required scenery mentioned (OpenSceneryX) in the read me, and as far as I know, it's updated.  Are there any other static airplane scenery files I should know about/download other than that? (I do have the three American ones)
Thanks, and this plugin got even better! Love the new radar
Tje new beta is still better smile
Wonderful plugins
Would it be possible in upcoming betas to have :
-Hot Spot clearance (when crossing runway on taxiway)
-More airports ready to this plugin (Paris : LFPG or LFPO; Madrid, Barcelona, Palma LEPA
Thanks for all your beautiful work
All good ideals, the last is the part that we are suppose to be working on as 'Developers' this plugin is not really for the everyday flyer yet, and this is why the airport list is short.
your friend,
B.
Wonderful plugins
The last Flight with the Beta #5 up date was the one that was most enjoyable so, far and the flight planning widget is working good but I need more experience with it first before, I can say anything about it. Today I have two appointments so, it will be a down day for me as far as testing. See everyone tomorrow.
8 (edited by laohu314 2016-02-10 17:21:39)
Just completed LOWW-EDDM. Went really well with some pilot error on final approach (had a bit of an issue capturing the G/S).
Notice in the replay that the stairs were dragged with the AC for the entire flight (LOL). Could this be interference with the GroundHandling plugin?
Also, I am not sure if this is correct but the approach vector looks a bit odd. The deceleration waypoints seem a bit off  forcing a sharp turn onto final. I am also not sure if the MUN waypoint should be in the route. It makes the approach crooked.
Also notice in the log this line:
[SASL ERROR] Error updating avionics: [string "/Applications/X-Plane 10/Aircraft/Heavy Metal..."]:0: attempt to perform arithmetic on a string value
Not sure what that means but I always have it.
http://jardesign.org/forum/img/m/1944/t/p1ab6263e910a7aruv5m18glf403.png
Log and replay attached
9 (edited by captbullett 2016-02-10 18:14:12)
when you have a //*String Error it means that the flight plan is not right and the string the the flight plan should be forming is not right, and there is an error in it somewhere./// (At least this is where I have had my issues when I have had the string error message.)
Note:
//* This string might be because, of a communication issue between XL and your --->>> FlyWithLua Info: ** A320 Neo Script a320neoV2_Xsaitekpanels.lua Ver 1.6 MODIFIED BY H.W. **
A: FlyWithLua Info: The DataRef "sim/operation/misc/frame_rate_period" is already handled in variable "LOD_xp_framerate", you want to use it with "frame_per".
FlyWithLua Info: As long as only one variable wants writable access to the DataRef, it is okay (but you loose performance).
Really nice plugin, makes fun :-)
For this version:
1) I again have a plane which is not drawn. Only the labels.
2) What is the trick with the FollowMe car ?
    I can request a FollowMe Car, the result is "expect followme car in 1 minute", but then nothing happens.
    Do I need the JAR FollowMe Car for this to work ?
3) I have some Errors with OpenSceneryX in the log:
Failed to open D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
Failed to open D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj: the file cannot be opened.
Failed to open D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/b767-300/jal/object.obj: the file cannot be opened.
But my installation is complete, the OpenSceneryX installer reports "installation complete".
Any other  Addons needed for this to work ??
Yes, you need have FollowMe Car installed. ATC will sent your ground route to FMCar (From one plugin to another) and FMCar will escort you.
Please check are you have file on your harddrive? fot example this -
that may be one of "empty" (not readed well) object.
Thanks for the answer.
You are right,
does not exist.
But the OpenSceneryX installer says that I have the latest version and the installation is complete...
Hmm, I found an "object.obj", it's in "...corporate\citation_x\object.obj". Will copy it to unlit and try again.
Yes, you need have FollowMe Car installed. ATC will sent your ground route to FMCar and FMCar will escort you.
If users dont have followme car, it would be correct to make option without followme car. ( hide buttons, dont show it)
Or make x-life and followme car as one addon(plugin).
15 (edited by Acei 2016-02-10 23:14:23)
Flight from LOWI to EGLL.  The flight plan generated by XL was incorrect as it seemed to double back on itself and increase the distance significantly.  I created a flight plan in EFASS and imported it into the FMS and then into XL.  This worked really well.
The only other issue I saw was that there was a plane in front of me at the holding point in LOWI.  However, I was given the instruction to line up so had to taxi through it.  This is the third time this has happened.  Twice in LOWI and once in LOWS.
The XL derived plane also didn't look right.  It seemed to have a box drawn around it on the ground.  See picture attached.
Could I also suggest that there be more arrows added to indicate the taxi route and one at the gate when taxiing after landing?  This could be an option as not everyone would want it.
http://jardesign.org/forum/img/m/683/t/p1ab6ne92tm2h1i4ev5i1fh6hdg3.png
The ATC has a button that does call the FollowMeCar when you have done the steps in the right order.
Next the FollowMeCar pulls up and will take you to the gate after landing.
your friend,
17 (edited by captbullett 2016-02-11 14:47:13)
which Nav Data cycle are 'We' as a group working with I am using 1602
Note# 1
I also did some more investigating and found  a route error when generating a route it did work though I will post data when I am done with the route ...
Note# 2
The route did work very well and the one waypoint I did have in Question I am posting a screenshot below so everyone can see the way it was listed on the MCDU and the way it displayed on the FD, (and I hope I have the acronyms right for the displays.)
the way point reads a //* string of numbers :FD110GIGIX1504/// and this worked with no issues I am making note of this so, if anyone runs across this know that this does work.
Attachment icon Screen Shot 2016-02-10 at 8.16.27 PM.png 364.11 kb, 170 downloads since 2016-02-11
Regarding the other planes on the ground, I have them too, but they look fine (no boxes)
Also, I usually wait until they move, which can take aa few minutes, but I have never had to taxi through one of them.
Yesterday, I have a flight from UMMS to EYVI, pressure in UMMS was Q0999 in EYVI Q0995. X-Life ATC shouting that pressure settings is wrong and requres Q1013 (standard pressure) below TA.
Can you add support of external weatcher addons like XP_NOAAWeather or EFASS?
Note# 1
Hi, using 1602 also.
21 (edited by captbullett 2016-02-11 14:58:27)
Yes, your in luck you will download Real Weather, NOAA, and SMPv3 also, is working well with X-Life weather system the only thing you have to do is turn on Real Weather.
When, you do have a glitch there, is a (Click Box that you can pause, [on the Real Weather page] the download cycle of the Real Weather click on this and let it stay in this position for a while, then un-check and resume, the download of the Real Weather cycle. Nevertheless, this will help to re-boot the real Weather cycle).
Note 1
I have not used EFASS so, I would like your feed back friend ...
22 (edited by TKurzweg 2016-02-11 15:08:07)
AI traffic Folder: it is possible or planned in the future to revise the OpenSceneryX aircrafts? too many old paints or wrong aircraft types! For example: I have the A320 Air Berlin, where a new paint from the OpenSceneryX and now it flies in the correct paint with X-Life!
23 (edited by Acei 2016-02-11 18:07:09)
Flight from EGLL to EDDM.  No issues except for QNH at EGLL.  XP had the QNH at 1013 which was incorrect.  XL ATIS was showing 1005 which was correct.  However, when I requested clearance, I was told that 1005 was incorrect and that it should be 1013.
You can see both XP and XP QNH in the picture below.  This is the first time I've seen XP with the incorrect QNH.  I'm using standard XP real weather with no other plugins.  I also refreshed the weather, but it was still incorrect.
http://jardesign.org/forum/img/m/683/t/p1ab8o1cau1g6usmnhm140d1kof4.jpg
CDT: Flight from EDDL to EDDH.
Wrong ATIS information for some times, could not get byond this, then CDT.
---+++--- Pilot: DUSSELDORF  ,hello, JAR123, Radiocheck 999.99
---+++--- ATC: JAR123, DUSSELDORF Delivery, hello, reading you five
---+++--- ATC: JAR123, Contact DUSSELDORF Delivery
---+++--- Pilot: Roger, JAR123
---+++--- Pilot: DUSSELDORF Delivery ,JAR123, Stand V43, A320, with information Alpha, QNH1008, request clearance
inRW=23L
inSidPoint=MEVEL
---+++--- ATC: JAR123, DUSSELDORF Delivery, Wrong ATIS Information
---+++--- Pilot: DUSSELDORF ATIS ,JAR123, Stand V43, A320, with information Xray, QNH1005, request clearance
inRW=23L
inSidPoint=MEVEL
---+++--- ATC: Initial Altitude 7000 feet, Squawk 7444
---+++--- ATC: JAR123, DUSSELDORF Delivery, Cleared to HAMBURG, Runway 23L, via MEVE1T departure,
---+++--- Pilot: DUSSELDORF Delivery ,JAR123, Stand V43, A320, with information Xray, QNH1005, request clearance
inRW=23L
inSidPoint=MEVEL
---+++--- Pilot: Cleared to HAMBURG, Runway 23L, via MEVE1T, Initial Alt 7000, Squawk 7444, JAR123
---+++--- Pilot: DUSSELDORF Delivery ,JAR123, Stand V43, request push-back
---+++--- ATC: JAR123, push-back approved
---+++--- ATC: JAR123, Contact DUSSELDORF Ground
---+++--- Pilot: DUSSELDORF Ground ,JAR123, Stand V43, request push and start
---+++--- ATC: JAR123, push and start approved
---+++--- Pilot: Push and start approved, JAR123
---+++--- Pilot: DUSSELDORF Ground ,JAR123, Stand V43, request taxi
---+++--- ATC: JAR123, DUSSELDORF Ground, taxi to holding short runway 23L, via T,L3,N,M,L1
---+++--- Pilot: Taxi to holding short runway 23L, via T,L3,N,M,L1, JAR123
---+++--- Pilot: DUSSELDORF Ground ,JAR123, Stand V43, request FollowMe car
---+++--- ATC: JAR123, DUSSELDORF Ground, expect FollomMe car 1 minute
---+++--- Pilot: DUSSELDORF Ground ,JAR123, approaching holding short runway 23L
---+++--- ATC: JAR123, DUSSELDORF Tower, line up runway 23L, and wait
---+++--- ATC: JAR123, Contact DUSSELDORF Tower
---+++--- Pilot: DUSSELDORF Tower ,JAR123, approaching holding short runway 23L
---+++--- Pilot: Lining up and wait runway 23L, JAR123
---+++--- ATC: JAR123, runway 23L cleared for take-off
---+++--- Pilot: Cleared for take-off, Runway 23L, JAR123
---+++--- ATC: JAR123, contact DUSSELDORF Approach 124.6
---+++--- Pilot: Contact DUSSELDORF Approach on 124.6, JAR123
---+++--- Pilot: DUSSELDORF Approach ,JAR123, MEVE1T departure, passing 700 feet, climbing to 7000 feet
---+++--- ATC: JAR123, DUSSELDORF Approach, radar contact, climb to FL 70
---+++--- Pilot: Climbing to FL70, JAR123
---+++--- ATC: JAR123, Climb to FL 250
---+++--- Pilot: Climbing to FL250, JAR123
---+++--- Pilot: Ready for Descend, JAR123
---+++--- ATC: JAR123, Maintain FL 145, expect NOLG1A arrival, Runway 23 in use
---+++--- ATC: JAR123, Contact HAMBURG Center
---+++--- ATC: JAR123, Maintain FL 140, expect NOLG1A arrival, Runway 33 in use
---+++--- Pilot: Maintaining FL131, expect NOLG1A arrival, Runway 33, JAR123
---+++--- ATC: JAR123, contact HAMBURG Approach 123,625
---+++--- Pilot: Contact HAMBURG Approach 123,625, JAR123
---+++--- Pilot: HAMBURG Approach ,JAR123, FL127, descending to FL140, information Xray on board
---+++--- ATC: JAR123, HAMBURG Approach, Wrong ATIS Information
1:03:08.358 I/ATC: Airport flow changed at EDDL!
CurFlow: Westerly FlowFlow NewFlow: AUTOGEN: West
1:03:08.358 I/ATC: Changing EDDL CabState from 0 to 1
1:03:08.358 I/ATC: All departures are done at EDDL. Advancing...
1:03:08.358 I/ATC: Changing EDDL CabState from 1 to 2
1:03:08.358 I/ATC: All arrivals are done at EDDL. Advancing...
1:03:08.358 I/ATC: Changing EDDL CabState from 2 to 0
---+++--- Pilot: HAMBURG Approach ,JAR123, FL117, descending to FL140, information Xray on board
Yes, this is a reason why need use (and XL have ability) flightplan from Routefinder
The problem happen if pilot sent report what he reach Holding point, but really - he have a stack behind - 1-2-3 aircrafts infront.
This is not "XL plane" but plane from freeware OpenSceneryX library. I cant do any with this.
If you open settings panel and enter 0 to Selected aircraft - you will get a loooot of arrors what show your groundroute.
