Re: X-Life public beta-4 010216 (Win & Mac)
So.. last 2 days I male a number of improvements, include workon airmap for beta 5
http://jardesign.org/forum/img/m/22/t/p1ab124a4e507dci1tf719o9oqi3.jpg
also:
+ add Import/Export flightplan from/to file functions
+ ATC panel not hide while mouse over it
+ tune Aircrafts markers
52 (edited by joomie 2016-02-08 20:30:28)
Need replace .dsf file at .../X-PLANE 10/Custom Scenery/LOWI Demo Area/Earth nav data/+40+010/
Sure, X-Life ATC not so clever to work with mountains airports as LOWI.
I recommend to better edit the scenery_packs.ini and disable above scenery pack.
The map of X-Life enabled airports lists a download link for LOWI. Use that one instead of the demo one.
53 (edited by captbullett 2016-02-08 23:17:55)
I changed the LOWI V1.01 which is a free download I do believe it also has Orthophoto and Road and Ground Traffic Plugins that come with the package.
Nevertheless, I see no bad effects from the change on the .dsf file so far and will test at a later time as I have flown from LOWI and had no issues.
But, the taxi lines and layout of airport is clean and sharp! and three aircraft that I need to remove from the scenery to work with XL after the aircraft population.
54 (edited by laohu314 2016-02-09 00:19:31)
Just completed EDDM to LOWW. All went well with a few minor glitches.
The descent speed was exorbitant at close to 6000ft/min initially. I guess due to the fact that my FL (310) might have been a tad high but I obtained clearance for descent at TC because I was getting to 110nm from LOWW.
After getting the runway and STAR info there was no T/D in the flight plan anymore.
Also, when descending to final approach altitude, again, I had to use full spoilers to keep speed in check.
ATIS was still telling me information from the previous airport (KEWR).
One final thing, the FM car never found me after I had just turned from the runway and I had to taxi to the assigned stand (C41) using the map. I saw the FM car marker zig zag all over the map, by the way. At one point after asking for it a few times, the marker showed up at the touch down spot.
Could it be that I didn't wait long enough? Normally, it shows up pretty fast.
I really LOVE this plugin. I can't wait to use to it on all my flights in the US as well.
http://jardesign.org/forum/img/m/1944/t/p1ab1llr651ia0sov1dcr1phimnsf.png
http://jardesign.org/forum/img/m/1944/t/p1ab1llhbv1jmp1gvg6te19t914kj3.png
Your T/D was changed when you contact APPROACH it will give you the runway # and STAR to use in you Approach(Flight Plan) then you will be handed off to the Tower for the final. Since, you do not add the STAR to the flight plan until it is given to you by the  APPROACH you will have two different T/D's in this system for it to work so far...
B
Yes, that's how it used to work for me too, but not this time. No T/D ever showed up in this flight before nor  after I obtained rwy and STAR for LOWW from ATC
Hi Mr JAR! I noticed ATC says "Read you five",(5) instead of read you f.i.n.e. (without the periods of course wink
Just a little annoyance for me, but this plugin is beautiful!
also:
58
also:
Wow, looks great! When will that be uploaded? Today? :-)
59
need 1-2 days
