Topic: X-Life public beta-4 010216 (Win & Mac)
-----What New?---------------------------------------->
Beta 4 010216 (actual)
+ add GoAround ATC pattern
+ add Screen-side menu
+ possibility to turn traffic Off with side-menu
+ improve aircraft markers info
+ improve ATC panel auto-hide
Beta 3 (old)
+ Add ATIS info for Departure/Arrival airports to ATC panel
+ Add ability to start descend when pilot ready (ATC phrase)
+ Tune climb angles (takeoff phase) for AI aircrafts
+ Add cruise flight level checking by ATC (0-180-360 rules)
+ Add dark map background
+ SQUACK code by ATC fixed
+ Add transponder mode ATC check (when you on runway / leave runway)
+ Follow Me car route fixed (stop FMCar before runway)
+ add screen warning messages for different situations
+ add ATC voice (need improve, but work now). Can be turned On/Off via X-Plane menu
+ add data checking after entered at FlightPlan panel
+ add visual indication of runway vacation direction after landing
+ add lights for AI aircrafts
+ add more sceneries/airports
+ improve ATC voice phraseology
Beta 2 030116 (old)
+ add Windows version
+ unlock airports for beta-tests
+ panels "out of screen" fixed
+ perfomance improve
FUTURE TASKS:
Requested features (not released jet)
- Add ATC requests what ATC not get readback from pilot
- rework map
- rework towing/engine start phase for AI aircrafts
- add Alt/FL ATC clearance with constrains (take in account)
- add true radio freq from reallife
- add export route to file option
- increase airtraffic generation density
- add crossing RW for user
- separate/mark runways for departure/arrival when need
- ATC vectoring along flightplan
Serial for Windows users: XL-BETA-010216-WIN
Serial for Mac OSX users: XL-BETA-010216-MAC
You can use this version with airports what are always have custom ATC-routed description. Please use this map https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a link for this sceneries.
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Please use this guide for details http://jardesign.org/forum/viewtopic.php?id=1670
If you use FMCar, please update your version - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.4r1 MAC OS / Windows - http://jardesign.org/forum/viewtopic.php?id=1633
-------X-Life DOWNLOAD LINK-------------------------->
MAC/WIN preview beta Download link -
www.jardesign.org/x-life/download/xlife_010216b4.zip
Just after installation, please install actual hotfix for this beta, based on CTD reports. Please delete old .xpl files from X-Life folder and install new from this pack. No additional registration should be.
www.jardesign.org/x-life/download/b4hf3.zip
-------HOW TO / Example flight ------------------------>
-------FAQ------------------------------------------------>
I see issues! Should I post here? - Mostly - Yes. If you are scenery developer, your way - contact direct via skype to discuss some. If you are regular X-Plane user - you can post, i will read, BUT for many-many your issues, please be sure what I have the same issues this time and know about this, cause plugin is incomplete and not for comfort using now. This is some another, earlier stage of development.
ScreenSide Menu:
http://jardesign.org/forum/img/m/22/t/p1aaek2p941rtr66h1ndv1ql51jrd3.jpg
2 (edited by laohu314 2016-02-01 22:28:23)
Re: X-Life public beta-4 010216 (Win & Mac)
I inadvertently moved the XL on screen menu on top of the A320 screen menu button and now I cant move the XL menu anymore because when I click on the top button of the XL menu only the A320 button is activated.
How can I correct that? Please help
many thanks!
http://jardesign.org/forum/img/m/1944/t/p1aaf8bkmm15432sv188g78f3if3.png
OK, got it. Switched to another aircraft, moved the menu. Sorry to bother. Should have figured that one out faster!
Hotfix 1 for beta 4. Avoid traffic aircrafts block on runway whan you GoAround.
many thanks!
Also, you may move menu to the right side.
5 (edited by TKurzweg 2016-02-02 07:34:34)
Testing the newest beta on my home airport EDDT...30 minutes "spotting" and everything works good ! No go around for the traffic but than, after landing of a B727...this aircraft use a gate with another aircraft (see my image) !
As I see, first aircraft was "static" ATTR. You should remove all static aircrafts from scenery or mark this gate as "static" wit Gate Editor
Few quetions about future of X-Life.
Are engine sounds for aircrafts in plan?
Are aircrafts going to use voice (text-to-speech) ATC, like we do?
I want to have AI aircrafts sounds. Will think about this in future, but not have plan to play ATC-AI_aircrafts text/voice dialogs.
9 (edited by laohu314 2016-02-02 21:56:40)
Just completed LOWWEDDM. Went without CTD first time in a while.
Some issues:
The instruction for Approach to EDDM was off (see screenshot). Not only does the given approach not exist in AIRAC 1601 the runway is also pretty messed up.
I chose another Approach and RW26L and landed without incident but ATC was quiet from decent onwards.
Also, how does one get rid of static aircraft? I don't seem to be able to do it in Gate Editor (btw. are there any instructions somewhere how to use it?)
http://jardesign.org/forum/img/m/1944/t/p1aahv4jrd1c9m1h8n1jm01mp39qk3.png
Logs attached
Many thanks! XL is coming along very nicely - it is a GREAT plugin!
Must have :-)
Nice to have :-)))
All static aircrafts are in .dsf files
If need delete them - need change .dsf file (use another one or use WED to import/edit/export exist .dsf)
Editing .dsf file only can be done with Overlayeditor.
With WED it's like described above and therefore a bit more complicated if one has no experience with the tool.
serial number for this
In the first post above.  When you enter the serial, you're asked for an email.  The final code is then emailed to you.
I've added 16GB or RAM so now have 24GB.  Bad news is that I'm still getting CTD when trying to create a flight plan.  Tried EGLL to EDDM with LOWS as the ALTN.  Will try other combinations shortly.
Love the menu on the side of the screen.  I've noticed that every option I select also opens the settings window for XL?
Attachment icon bbox_log.txt 125 b, 329 downloads since 2016-02-03
Same problem with LOWS to EDDM with LOWI as ALTN.  Problem with settings windows for XL popping up every time I used the menu wasn't happening this time.
Are you install hotfix? http://jardesign.org/forum/viewtopic.php?pid=8874#p8874
Yes, hotfix installed.
I just started x-life on EDDH and looked around with the free camera....
http://jardesign.org/forum/img/m/552/t/p1aakg4ojk127c1tad1bm21rb817i43.jpg
So I have one plane I can not see, and another plane which is moving but has no label....
Trying and.. Ok
http://jardesign.org/forum/img/m/22/t/p1aakk330h1fao1349f3cqsc179h3.jpg
Need solve a little task - understand what a difference..
If acf far from camera, lables not draw. this is normal.
hided aircraft - not normal. thanks for report.
Trying and.. Ok
Let me remove all other plugins tomorrow and see if it makes any difference.
Need check, also, are you have all 3 that sceneries installed - EGLL, EDDM and LOWS at Custom Sceneries folder.
And NavData installed to .../X-PLANE 10/Custom Data/GNS430/
Will do.  Doing a clean install of XP at the moment.
Still getting a CTD.  Did a clean install of XP.  Added sceneries for EGLL, EDDM, LOWS and LOWI.  XL is the only plugin installed.
CTD every time I try to calculate a flight plan no matter what the combination of destinations.
Attachment icon bbox_log.txt 101 b, 343 downloads since 2016-02-04
