Re: X-Life public beta-4 010216 (Win & Mac)
Be useful if we can check how it happen direct at your computer. If it possible, please contact me skype j.a.romanov
Hotfix 2 for beta 4.
+ CTD from use lower-case letter
  for ICAO code fixed
+ aircrafts markers reworked
+ sidemenu work improved
28 (edited by laohu314 2016-02-04 19:07:08)
Just completed EDDM to LOWW  until CTD when telling  Vienna GROUND "Runway vacated". Also, ATC asked me to contact MUNICH GOUND just before that. Could the problem be that I first reported "Runway vacated" without tuning to GROUND?
Thanks for the help today Eugeny.  Flew EGLL to EDDM.  Went well up to taxing off runway at EDDM.  Tried to contact ground and got CTD.  This was with hotfix 1.  Will try again with hotfix 2.
30
i will try to check this
OK, thanks. I was also using hotfix 1 and will try again with hotfix 2
Forgot to mention that when I landed in EDDM, there was another aircraft sitting on the runway.
33 (edited by captbullett 2016-02-04 21:06:00)
I do not know if you have herd of this app but it will clean your computer of anything that might cause the CTD.
BUT make sure you know the passwords of your online accounts as you will have to log back into all of you online accounts.
there is a free download and on you can buy so read before clicking.
https://www.piriform.com/ccleaner/download
34 (edited by laohu314 2016-02-04 22:52:08)
Just completed LOWW to EDDM. Was late reporting ILS ESTABLISHED and completely lost ATC and could not get it back. Landed and could not get FM Car either until I arrived at the gate.
It still messes up the location for the APPROACH (it asked to contact Vienna Approach while I was approaching Munich).
Thanks, already use it.  It's very good.
36
LOWS to LOWI.  ATC instructions on decent were not correct.  Flight plan ALT was FL100, was told to descend to FL120.  Told me I had ILS clearance for LOWI.  LOWI only has RNAV.  Again, CTD when trying to contact ground after exiting the runway.
Also routed me to RWY 08.  Not commonly used for LOWI.  Should have been RWY 22 especially for the A320.
37
I have the same problem. Short flight from LOWI to EDDM. It ask contact Innsbruck approach as I was in Munich.
Yes! Exact! This is good idea, thanks!!! Now I can get this CTD. The problem happen when you/I try to say "Runway vacated" to (wrong) Tower, get answer "Contact Ground" and next say "Runway vacated" to Ground again. In this moment ATC try to vacate runway, what was (wrong) just vacated.
I make a fix. Will perform test flight and post this fix.
That makes sense.  I think that's what I did too.
40
Ooook! This is a hotfix 3 for beta 4
+ "Runway Vacated" CTD fixed
+ change "log" part of plugin (all needed info post to log.txt only, not need post bbox_log more)
Thanks all for your reports issue and CTD.
41
Another I experienced with the Worldliner 777.  When I try to export or import a flight plan I get a CTD.
Yes you need to do that then it will tell you to contact ground and when you contact ground it will give you the gate and the taxi ways also the FollowMeCar will display and take you toy your spot. you might have to call it I do not remember at I was in the hospital for the last few days and just getting back to the testing. and yes I am ok now my appendix had to be removed.
your friend,
B.
Welcome back, Brian! I hope your body is Ok!
44
Ah.. I get this too..
Very easy logic for first view and so many cases it should be apply. As result - aircraft behind you on landing. I get it too and work on this. I hope will be Ok. Thanks!
45
Welcome back Brian! Maybe I can lose some weight getting that darn thang removed to lol! Speedy recovery my friend!
your friend,
B.
Hi Jar & all forumers :-)
I have just loaded up X-life B4 along with the HF3 and loaded up EDDL and started at the default gate. When I activate X-life with the standby key it hesitates as it normally does for a few seconds and then says it has loaded. But I DO NOT get any other planes at the gates like I did before or in the skies and also when i click on flightplan, NOTHING happens.
Any ideas?
I re-registered. All working now, sorry to bother you :-)
Great work by the way!!!
48
I still am very weak from the surgery so, maybe tomorrow I will be able to sit at the computer and resume beta testing.
This has been the hardest surgery I have been through, worse than removing the bullet from my neck.
yes I miss everyone.
your friend,
Quick flight today from LOWS to LOWI.  Only issue I encountered was an aircraft sitting at the holding point in front of me at RW 15 in LOWS.  Although it was sitting in front of me, I got clearance to line up.
On approach to LOWI, ATC regularly gives ALT instructions that would result in a collision with a mountain.  Not that unusual as XP can chart a route to LOWI that will result in a mountain collision.
How do I turn off static aircraft in the LOWI scenery?  Annoying when given a gate and there is already a static A/C sitting at it.
50
Need replace .dsf file at .../X-PLANE 10/Custom Scenery/LOWI Demo Area/Earth nav data/+40+010/
Sure, X-Life ATC not so clever to work with mountains airports as LOWI.
