A350Pilot wrote:Hello,
in my X-Plane, X-Life didn't works as expected.
Using Windows 10 Pro x64, X-Plane 10.42 64Bit, JARD A320Neo V2.2.
OpenSceneryX, TugMaster, FMCar and GHDeluxe in the newest Versions
Sitting with A320Neo at EDDM.
Following occurs, when using the Plugin
Click Traffic on -> X-Plane crashes to Desktop
Click Flight Plan -> nothing happens
Click ATC Panel -> Control Panel appears but is totally empty
Click Gates Editor -> nothing happens
Click Settings -> Settings Panel appears
Click Registration -> Dialogue appears and Registration went well. Plugin is activated.
Click Airports Map -> IE opens up with the Map.
Click News -> Nes Dialogue appears.
Any Ideas, what i have to do, to get X-Life running?
Some information from my side being a beta tester:
1)
X-Life works on Airports having a purple or orange star on this map: https://www.google.com/maps/d/viewer?us … ecn3NB3GZ8
One must have one of these airports in the Custom Scenery. Look at the download links being given after a click on one of the stars in the list on the left hand side of that page.
2)
Use the latest beta build of the A320neo to use it with X-Life
3)
Use the latest beta build of the Followme Car to use it with X-Life
4)
Flightplan can be used after setting Traffic on.
5)
A change of settings takes effect after reopening an aircraft or restarting x-plane
6)
Click on CENTER then report TOD (top of descent), otherwise crash to desktop
7)
Enter capital letters for icao codes in flightplan.
8)
Don't set the gates busy setting to a value higher than 75% (recommendation by JARDesign, hope its not outdated)
9)
Don't set the runway operation interval time to a value lower than 2 min (recommendation by JARDesign, hope its not outdated)
10)
To operate X-Life on an airport not listed on the map mentioned above:
Ensure your airport is listed in Custom Scenery and activated via according entry in the file Custom Scenery/scenery_packs.ini
Create ATC network for that airport
Copy the corresponding apt.dat file into the folder plugins/X-Life/Airports
Copy the corresponding apt.dat file into the folder plugins/FM/Airports (if you plan to use the FMCar plugin [latest beta build! together with X-Life])
Use X-Life's Gate Editor (see in the plugins menu) to set the values for the ramp start positions
SYSTEM: X-Plane 11.00pb9, Win 10 (64bit), Intel Core i7 6700K@4.5 GHz, NVIDIA GeForce GTX 1080 8 GB GDDR5X, 32GB RAM, 1.25 TB SSD, SAMSUNG SUHD 55'' TV@3840x2160px, TrackIR5; PLUGINS/ TOOLS: FS Global Real Weather, SkyMaxxPro v4.1, Real Weather Connector, Gnd Handl. Deluxe, X-Camera, NDP Charts, Navigraph AIRAC; A/C: JARDesign: A320neo & A330
