Re: FMCar v2.1r1 For Win 7/8 MAC OS (X-Plane 10.40 ready)
you may contact me direct via skype j.a.romanov - will see what wrong
JARDesign Group Board → Downloads, Updates. → FMCar v2.1r1 For Win 7/8 MAC OS (X-Plane 10.40 ready)
Okay i contact you via Skype.
The plugin work correctly .
LFMN.dat in Airport Directory works .
Some airports do not go . Is this connected with the Custom Scenery folder . w2xp_Europe_osm -only Scenery installed .
Used the KSFO dat file...renamed it KSFO.DAT and placed it in the airport file and there it is....it works great! All the runways and the FM car awaits to take me to anywhere at the airport.
One Problem.......KSAN.... the airport shows up very very tiny....can not use map its so small. I can choose from runway choices but to see the map is impossible. Only airport that I have to be that way. Tried downloading like I did KSFO dat file...but MAP still remains to tiny to even see.
I did notice another person on here who was requesting is there a ZOOM function. So I assume he too is having the same problem.
Using X-Plane 10.42r1 (64-bit build 104200) with FMCar but clicking on the MAP button does nothing. Have installed LFMN custom scenery from your site. It says wellcome to LFMN and the MAP button appears but nothing else happens after clicking.
hi, i has bouth this fmcar in x-plane.org, the new vertion request serial key, i don´t has one
Please contact support and attach copy of confirmation email from shop where you get it.
http://www.jardesign.org/ticket/kb/index.php
Support will send you a serial.
are you register plugin?
opened a Ticket for sending me the Serial for FMCar. The Copy of the Purchase Mail from X-Plane.org was attached. Nothings happened until now. Will i get a Mail with the Serial or do i have to check out the Ticket System for your Response?
Ok, will send you serial today 100%
Thank you!
