Topic: FMCar v2.1r1 For Win 7/8 MAC OS (X-Plane 10.40 ready)
Now you can add your own custom airport description file like apt.dat file. To do this, Please use
"Airports" folder in your ...X-PLANE 10/Resources/plugins/FM/ and put your custom apt.dat file there with NAME.dat filename. As example, you can download EDDL.dat (file for Dusseldorf airport) and put it to ...X-PLANE 10/Resources/plugins/FM/Airports/ folder
If you own an old version of FMCar and not have serial key, please contact support email and just send a copy of conformation email from shop where you get it.
http://jardesign.org/forum/img/m/22/t/p19t5ttqp917af7a5185518i32f23.png
Download here:
www.jardesign.org/fmcar/download/FMCar_2.1r1.zip
Re: FMCar v2.1r1 For Win 7/8 MAC OS (X-Plane 10.40 ready)
Hmm.. I just made Custom EDDH.dat and put it to airports folder. Seems work well. I attach it. Lets try!
http://jardesign.org/forum/img/m/22/t/p19to8504b1tgu6mavogkl113et3.jpg
EDDH doesn't work either. Airports.txt still contain only EDDL.dat and FMCar is not available in EDDH.
Airports that are read from normal locations (Custom Scenery folder) do work, however.
J.'
Does not matter what contain Airports.txt file in this case.
So.. I want be sure what you use more fresh version first, also what your Scenery ans plugins files are always at the same drive what X-Plane.exe,.. and next - need check some in direct support mode - Please contact skype j.a.romanov
Hi.
I bought FM Car from the Org Store last April and no serial was given (or needed on the old version).
I am therefore unable to activate this new version.
Please let me know what the next step is.
Many thanks.
deetee wrote:
Hi.
Many thanks.
http://jardesign.org/forum/viewtopic.php?pid=5619#p5619
Thank you, I have sent my email.
EDDH do not work in the "Airports" folder... IMac and V2.1r1
JPB
9 (edited by k922365 2015-09-10 03:34:54)
Why VHXX map can not be displayed, you can use other software to display
FM Car: not available in vhxx airport
http://jardesign.org/forum/img/m/1346/t/p19uqenv9i2bj13dhil71p5s2tv3.png
Airport-Navigator
http://jardesign.org/forum/img/m/1346/t/p19uqkuru21eoq1fjhd3l1f5b1of73.png
May be - no taxiroutes in this Airport.
Can't get the custom apt.dat's working. I have copied several apt.dat's to the Airports folder and renamed them correctly, FMCar just ignores them, rewrites the Airports.txt file and adds only the default LEBL.dat.
Hola
Buenas tardes
FMCar v2.1r1
No funciona con ningún aeropuerto
Solo funciona con el aeropuerto de demostración KSEA
Gracias
How do I get my activation code? I tried the support ticket and so far haven't received an email form that area. I also submitted the documentation you requested. I purchased the Tugmaster and the Follow Me Car at the same time from x-plane.org. I really would like to have the follow me car operational. If iv'e submitted the wrong documentation please email me so I can get it corrected.
AMD FX9590,Asrock performance fatality 970, crucial ballistix elite 32GB DDR3, Asus ROG 1080 8GB, Asus essence stx sound card with Burson Audio opamps, Thermaltake 1000w RGB powersupply, Thermaltake water 3.0 watercooler, Logitech Z906 speakers, Thrustmaster Warthog HOTAS, and MFG Crosswinds rudder pedals.
As usual, i contact for 100% users in support system. may be answer in spambox. Anyway - please contact direct skype j.a.romanov - i will send you serial.
Thank you very much. I'll check my spam box and contact you via Skype. Have a good day
Is there a way to zoom in the map?
Some airport maps are too small.
no Zoom, just one scale.
When i'm at an airport that accepts the FM car. I choose the route provided by the FM car map list. I see the car within the map however, I can't see the car on the external view of the aircraft. I'm using the 777-300 Worldliner. Also x-plane 10.42r1. Could you please help me?
Hmm.. Please try to build route by "Select on Map" first time.
Out of frustration I removed the FM car from the plugins folder. Then I reinstalled it and now it works. Thank you for your help. Have a stress free day.
Hi, I'm spending a lot of time building taxi route networks into the airports I use in the UK, with great success smile
All works well. I don't understand the benefit (or why I should use) the Airports.txt file?
My FM Car works just fine in all the airports I've built taxi routes in. Why would I need to alter the Airports.txt file?
I'm on a MAC with El Capitan 10.11.5 with X-Plane 10.45r2 Logitech Extreme 3DPRO joystick.
No, Airports.txt file is a file for autoupdate system. It downloaded from server, not edit by user.
So, We prepare a number Custom build ATC routes for some payware (Included great Aerosoft EDDL, EDDH, LFBO) and freeware airports for Follow Me Car plugin. User may download and install it from official board http://jardesign.org/forum/viewforum.php?id=33 or plugin may download and install it in auto mode.
If someone done own .dat files and ready to share it for other users - welcome http://jardesign.org/forum/viewforum.php?id=33
Hello my English is not so good.
FM Car works only in customy Scenery folder apt.dat
In Plugin FM / Airports Directory it is not working.
The Auto Download feature downloads the xxxx.dat airports. But it is not working.
are you install v.2.1r1?
Yes i have FMCar 2.1r1
I have a Mac with OSX 10.11.2
