Re: X-Life public beta-2 030116 (Win & Mac)
seventy2 wrote:
I installed X-Life in Resources/plugins/ on XP 10.45b1 on Windows 10 computer.
Log.txt says "C:\X-Plane10/Resources/plugins/X-Life/win.xpl : Error Code = 126 : Le module spécifié est introuvable."
regards
I think, if plugin installation is correct, you just need install "Microsoft Visual C++ Redistributable 2010" pack
https://www.microsoft.com/en-us/downloa … x?id=14632
I've been playing with the Aerosoft PANC airport scenery and was hoping to edit it to be compatible with Xlife.
I am able to start the plugin and the gates etc. populate with aircraft.  I need to edit the sizes allowed etc.
However, there's in no traffic.  The planes just sit there.  There are taxi routes with this scenery - FMcar works well.
I get the following error when starting xlife "ATC: seems like impossible to build ground route from gate...to rwy...
Scenery problem detected".
Can someone tell me how to solve these problems?  I'd be happy to fix PANC and then post the text file for others.
Thanks!  This plugin will be truly amazing - I'm enjoying it already and think it will really change x-plane for the better!!
53
regards
I try to install this version but Windows 10 seems to be incompatible.
Now c++ redis 2015 is installed but x-life is not charged. Same error code in log.txt
joomie wrote:
geodix wrote:
I installed X-Life on XP 10.42 on Windows 10 computer.
I have the information message and the green message (ATC : scenery jump !!! ) when X-life is ON
But when i go on plugin/flight plan no flight plan windows appears.
Click on "Traffic On" in menu, wait some seconds since x-life will compute stuff, flight plan widget should be available then.
I already Click on Traffic On in menu and waited then the green message (ATC : scenery jump !!! ) appears but when i click on Flight plan on menu Nothing appears
55 (edited by geodix 2016-01-07 20:47:36)
Are you register plugin? Are you start traffic On?
Also, please provide log.txt file just after start x-plane and load any aircraft.
I m not register plugin
I start traffic On
I click on Flight Plan on Menu
and no Windows Flight Plan appears
need c++ redis 2010, not 2015
and.. need be sure what all dlls copied well (may be reinstall full plugin)
I start traffic On
Not registred plugin cant work well.
58
ok now i m registred.
it is ok
sorry for that
thanks
59
All the previous version of c++ is uninstalled.
Only C++ redis 2010 (your link) is installed (Check in win10 parameters, applications)
Restart system, load X-plane but same problem
60 (edited by joomie 2016-01-07 22:28:56)
regards
I beta test X-Life with Win10 and it runs using X-Plane 10.42.
I have far too much old stuff in terms of Microsoft Visual Studio Redist on my machine, but if it's of interest:
http://jardesign.org/forum/img/m/436/t/p1a8f396h51bk910gtj7817rr113f3.png
61
I try to install the same list of c++ redis
62 (edited by captbullett 2016-01-08 02:56:58)
yes, you only need latest version no wonder your computer crashes it does not know which C++ VS to read
you need to get rid of all of them and then do a clean install of VS C++
does any other app use any of the older versions of VS C++ then you might need the older version check first before deleting
63 (edited by joomie 2016-01-08 10:59:44)
Having several 1,000 hours of experience developing software I'm not convinced that this is the case, sorry :-)
My computer has a mixture of different headers and libraries installed and it runs smoothly.
It's just an assumption, but I assume that the cause of your problems is something else.
You probably need at least one (best up to date) installation of Visual Studio Redist.
Fulfilling this condition I propose to do the following:
  • Remove all plugins
  • Install a fresh copy of x-life (latest build), you must have a file with a path X-Plane10/Resources/plugins/X-Life/win.xpl then!
  • Update Win10 via standard Microsoft Updater
  • Ensure that you launch X-Plane 10.42 (no beta!) and select one of the custom scenery airports having an orange or purple star and being listed here: https://www.google.com/maps/d/edit?mid= … sp=sharing
  • Note that you need to have selected custom scenery airport installed and activated (scenery_packs.ini)
  • Register X-Life
  • Try to turn traffic on
64 (edited by pic 2016-01-08 08:32:26)
Excellent work on this plug-in, been enjoying it tremendously.  Here are some issues:
1. FM Car, I updated and replaced old Key file, after filing flight plan and requesting taxi, I called for FM car from x-life, then a CTD
2. On my last flight LFMN-LEBL (LOG Attached) after an ILS landing at LEBL, I reported to x-life ATC that I exited runway (cleared), then a CTD
Otherwise, all is working very good!
A function recommendation:
Some kind of menu that's available for all functions instead of constantly pulling down plug-in menu.
Thank you again for this excellent plug-in! Looking forward to final and it going public
The problem may be, what you have LEBL as arrival. LEBL is not on the map and its ATC-taxiroutes not ready to use with X-Life.
66 (edited by captbullett 2016-01-08 18:36:24)
I have not had to remove one plug-in yet and no issue with the X-Life plugin and this for being a Bata build yes some things did not work right and I have had to try a couple of time but this is to be expected when getting use to new software and I did not get any instructions with my copy I am learning as I go..  and the X-Life plug-in works on the Mac to a point as I am not doing some thing right and this is why it has a few issues in timing but the more I use it the better it will work .. EGLL to LFBO looks like it will be the firs route that will work from start to finish and with aircraft taking-off and landing with a good interval in-between flights and any errors were due to my error.
what i see is the registration is missing and must be done.
  • Register X-Life
67
  • Register X-Life
Sorry,
My latest test :
- Win 10 clean install
- c++ redis 2010
- X-Plane clean 10.42 with only X-Life Plugin (i see X-Plane10/Resources/plugins/X-Life/win.xpl)
but... X-life is not charged (same error code 126 in log.txt)
68 (edited by joomie 2016-01-08 23:02:12)
  • Register X-Life
Sorry,
My latest test :
- c++ redis 2010
Win 10 64 bit and launching "X-Plane.exe" not "X-Plane-32bit.exe"?
Firewall exceptions for x-life or better disable firewall to test if it influences x-life.
Sorry,
My latest test :
- c++ redis 2010
Win 10 64 and launching X-Plane.exe (64 bit version), Firewall off but same problem....
Thanks for your help
70 (edited by servlan 2016-01-08 23:51:44)
Hi J,
Excellent plugin however I am getting XP10 crash on generating FPlan even using capitals i.e. EGLL > EGPH.
Log file attached - Mac BETA.
Cheers and keep up the good work.
Paul.
71 (edited by captbullett 2016-01-09 00:17:33)
On the flight from EGLL/LFBO the full flight was run I landed and then the CTD I have the Log.txt and the BBox
so, JAR can have a look See like requested.
The flight Route generated was good the ATC communication was good and the hand-off to the tower at the arrival airport was smooth in the transition.
I can say any CTD is due to probably the operator not doing something right in the system .. or the loading in the compiler was needing to catch-up to the graphics with the number of aircraft being generated now by X-Life.
Attachment icon bbox_log.txt 106 b, 251 downloads since 2016-01-08
72
What the exact moment of flight was when CTD happen? (ask cause bbox is empty/saved after reload aircraft may be)
73 (edited by captbullett 2016-01-09 14:05:11)
just after landing wheels  touched down and it started to freeze up so I went to press the command Key on the Mac this some times stops a CTD but, I was to late.
I am going to run the same route today.
How to import from FlightPlan File:
After loading the Flight plan into the MCDU you open up X-Life then take the next steps to import the flight plan;
I import to the Flight plan widget then export to the ATC widget it gives me the runway, SID and then when I get handed to the Approach they will give you the STAR and the runway I need to complete, the route. the STAR is not entered until you are prompted by Approach at the TD waypoint.
(I wrote this so, others can follow.)
This is a route that X-Life has the two airports on the list  in Orange Stars
EGLL SID MID UL151 SITET UN859 BALAN UL152 MAKOX G36 ESISI STAR LFBO
74 (edited by captbullett 2016-01-09 15:34:05)
Here is the last CTD this happened when I clicked the TD button to land.
the only difference I was on-line. i was using the ethernet line and was allowing the X-Plane app through the Fire wall.
this is the only time I have CTD's.
the route;
BBox.txt is ful this time JAR
thank-you
Thanks for this info, Brian! Will think.
