Re: ver 2.6 beta 3 WIN/MAC 64 bit
hades.esp72 wrote:
Hi!
After activate B3, close sim and reopen; it worked for me.
zippy77777 wrote:
A few things in b3. My baro shows 0000 and I can't change it. Airports not found in fmc and sound pack does not work.
not for me, baro is a real problem
27 (edited by captbullett 2015-12-18 17:05:24)
yes it is not the exact route you wanted but it is not you or JAR it is the onlineflightplanner and the route and how it is set-up just because of the "DCT" it tells me what is going on and can you now fly the route from point A to point B with the main part of the route using the original route you wanted to use ? this is why i like the JAR we can fix a rout when it does not work! and then we can fly it it might not be exact but it is very close it has to do with the //*string value /// in the computer and the MCDU and how it computes the values. I can tell you the MD-80 is working just like the JAR aircraft and I really like it some thing are still needed but for the base it is the same.
  EDDF SID ANEKI Y163 NEKLO Y171 INKAM T725 LAMGO T721 SUL T732 GARMO STAR EDNY so this si the same route as the http://onlineflightplanner.org so I must do some more data search!
This is the way the route should read you need to replace the waypoints  where I have put dct with (DCT) and it will be a good route ! then no STAR No VIA on the EDNY just RW06 OK and you will have the route you were looking for ...
//* EDDF SID ANEKI DCT NEKLO DCT INKAM DCT LAMGO DCT SUL DCT GARMO STAR EDNY //
Ok, I tested your route. I changed the route and replaced with "DCT" as you suggested.
Result: No change. It's broken again.
The only thing that helps a little bit is to ignore all, star, trans, just set runway. The result is:
http://jardesign.org/forum/img/m/552/t/p1a6oh7cske7qkqok6alc81kcf3.jpg
Then, of course, from GARMO direct to ARGEV to ILS06. That is OK for what I have entered,
But that's not what it should be...
zippy77777 wrote:
hades.esp72 wrote:
Hi!
Fixed sound and my baro and fmc problems were due to a corrupted navdata folder
Hi guys, when it's ready a version A320 with a cockpit in HD?
Flight LFML to LFST :
following remarks :
-alignment of the ADIRS always to fast (1 min later) ;
-magenta TOC on the ND is not exact (always 30 NM more than in the reality)
-it is very sad to not have the possibility to enter speed constraints and selected speed on the MCDU (perf page) For the SID STAR it is a big item for me
Thanks a lot for all your improvments on this fabulous plane
How about a default setting for the air conditioning knobs!!
Only 0.00 on the approach phase and not 00.00
No retard calls?
34 (edited by zippy77777 2015-12-20 11:10:38)
These are just observations in my sim this morning. The sound pack does not work when u reload the aircraft, hope you don't mind me sending posts one after the other like I have. Why also is the baro ref call automatic now, it was when you pressed the baro knob?
Not sure sound pack actually works correctly at all. I'm talking about Star Sims one.
Only constraint or airport or waypoint etc can be used singularly not altogether
36
AirFMC as still some bugs:
http://jardesign.org/forum/img/m/552/t/p1a6gj7ffp1pv1i1b1jahmq31pnb3.jpghttp://jardesign.org/forum/img/m/552/t/p1a6gjdemkd1h9un125g1oql7stf.jpg
http://jardesign.org/forum/img/m/552/t/p1a6gj7ffp138j1r45tih18jh1mbp4.jpghttp://jardesign.org/forum/img/m/552/t/p1a6gjdemk108u1ptq3q41o1q13q7g.jpg
http://jardesign.org/forum/img/m/552/t/p1a6gj7ffp11jh1rndh27bk7qe55.jpghttp://jardesign.org/forum/img/m/552/t/p1a6gjdemk1cmpl4eqoa123a16djh.jpg
Best regards,
I confirm that AirFMC display is still corrupt and interferes with cockpit FMC as well.
37
Why is it so difficult to set the baro ref??? It always hesitates and jumps either side of the figure u want!
Another nice and annoying bug:
1) start xplane & load A320 2.6 B3
2) Press "Hot Start"
3) Click on MCDU "PERF" Page
4) Click "Page up"
Result:
It won't stop clicking :-)
click click click click click.... :-)
good day,
well if you have seen the issues I have gone through with the 767 and the FF support you would not post they type of post with no log.txt and no information
click click click click click... FYI I would rather be using the JAR A#20Ne that the FF aircraft and wait for a ticket to be answered only to find out they did not understand what you were saying in the first place and a simple thing like the engines won't start!
so you click click click click click... is  Another nice and annoying bug: you are't going to get to much help without more information!
try to re-install a fresh copy of the aircraft!
4) Click "Page up"
Result:
good day,
Well, This post contains ABSOLUTELY all needed information. ALL.
You don't need more, you don't need less.
That's the simple information. Nothing more, nothing less. Just press the 4 buttons and see... that's all.
I guess you don't need more than 2 seconds to know what "click click click..." is :-)
If you had done this BEFORE writing this message, you even had not written it.
Sorry, I have installed a fresh copy for the last bug, so that will be enough fresh copies.
Hi!
Have you installed the sounds Blue Sky Star Ssimulations?
I have that problem with this add, in certain special MCDU pages; but in normal use , I have no problem.
4) Click "Page up"
Result:
Good hint, yes, I have installed the "Blue Sky Star" A320 sounds. I will try without them....
hades.esp72 wrote:
Hi!
4) Click "Page up"
Result:
well Now that I have seen two of you with the same issue could one of you try to uninstall BSS and see if it goes away and I am sorry I had an chip !
happy Holidays
B
hades.esp72 wrote:
Hi!
4) Click "Page up"
Result:
Ok, now we accumulate issues of beta 3 (most are solved) and have plan to build beta 4 (or RC) first week of January. Sure, I am still very interesting for wrong SID/STAR drawing in different airports.
45
Thanks for your continued support J.A.R.
Have a great xmas break.
Thanks Jar for your time and work.
Hmm, I deleted the BSS installation, and now I don't have click sounds at all (at the fmc) ....
happy Holidays
B
hades.esp72 wrote:
Hi!
48
Me too. I confirm that only happen with BSS.
happy Holidays
B
49
Thanks Eugeny for all the hard work. Enjoy the holidays and have a great 2016.
50
Bug:
When a route is entered, the FMC is in TEMP FPLN mode (displaying the route yellow). If there is a AIRWAY/WAYOINT mismatch, the whole temporary route is deleted, not only the just entered (incorrect) part.
