51 (edited by ivota 2015-11-26 21:36:54)
Re: ver 2.6 beta 1 WIN/MAC 64 bit
ivota wrote:
problem draw SID LDSP look video.
http://www.twitch.tv/ivota_hr/v/27609353
Sorry, i need just
1.Screenshot of wrong drawing
2.Picture of true drawing from charts
3.Details
LDSP rwy05 SIRMI7D
picture 1 = old drawing SID jar a320 version 2.4b3
picture 2= chart LDSP SIRMI7D rwy05
picture 3 = SID drawing v2.6b1
picture 4 = BLUE line show correct drawing SID
ok, good info, fixed for beta 2
http://jardesign.org/forum/img/m/22/t/p1a5575rc6uv91ecr1m8mr8vcf93.jpg
53
Hi!
Error drawing SID (Navigraph AIRAC1512)
LEAL10--> [MAGA2A] MAGAL UP34 HAMRA UA34 MOS UA411 ORA -->DAOO25L
http://jardesign.org/forum/img/m/1123/t/p1a54u1jd91efd4561fjqvrd2db3.jpg
http://jardesign.org/forum/img/m/1123/t/p1a54u1jd93491ms6gbk51tshn4.jpg
http://jardesign.org/forum/img/m/1123/t/p1a54u1n371j5unt3a6cqfoou87.jpg
Hi, the navdata used by this version is a bit odd...the updates goes normally in the "custom data" folder, the folder /resources/GNS430/navdata is used only when xplane updates itself, and at the moment is fixed at 1405 AIRAC.
Please consider to use the custom data folder instead of the standard xplane folder, cause otherwise it will be necessary to update manually each time, instead of using, for example, the Navigraph software (that correctly uses the custom data folder)
cheers!
And some other little cosmetics bugs:
1- the compass light it is not working yet
2- the side lights of the cockpit are not working yet
3- in the menu page of the MCDU is still present the "flight attendant voice selector", even if it is not possible to select other voices.
hades.esp72 wrote:
Hi!
fixed for beta 2
thanks!
Vhaoooo!!!
Thanks JAR. Very fast fix.
58 (edited by hades.esp72 2015-11-27 21:05:22)
Hi!
Thanks. J.A.Romanov.
Is possible set automatically transponder on/off (on takeoff and landing) on Auto mode?.
59
hades.esp72 wrote:
Hi!
May be, if you can give doc (FCOM?) description for this feature.
Hello, Mr. Romanov
Doing some tests whit the new version, i found these problems:
- When attempting to load an approximation, loads a mismatch for instance. Example:
Trying to load RNAV Z RWY 30 from SCSE:
Data from navigraph:
APPTR,R30-Z,30,ANDAK
IF,ANDAK,-30.243633,-71.119122, ,0.0,0.0,4,9000,7500,0,0,0,1,0
TF,CRITA,-30.181986,-71.113886,0, ,0.0,0.0,0.0,0.0,2,6500,0,0,0,0,0,0
TF,TALCA,-30.120333,-71.108669,0, ,0.0,0.0,0.0,0.0,2,5600,0,0,0,0,0,0
TF,LOICA,-30.084619,-71.083761,0, ,0.0,0.0,0.0,0.0,2,5000,0,0,0,0,0,0
TF,RALES,-30.043525,-71.055133,0, ,0.0,0.0,0.0,0.0,2,4200,0,1,200,0,1,0
MDCU load the following procedure:
SID,EDRON1,30,5
CA,0,295.0,2,2500,0,0,0,0,0,0
DF,UMBUX,-30.087414,-71.286181,1, ,0.0,0.0,2,7500,0,0,0,0,0,0
TF,SE270,-30.271117,-71.291908,0, ,0.0,0.0,0.0,0.0,2,12000,0,0,0,0,0,0
TF,SE350,-30.555603,-71.300772,0, ,0.0,0.0,0.0,0.0,2,20000,0,0,0,0,0,0
TF,EDRON,-30.794808,-71.151794,0, ,0.0,0.0,0.0,0.0,2,21000,0,0,0,0,0,0
I am doing some tests, i discovered that the problem is the name of the procedure, by eliminating - cotained in the AIRAC (example: APPTR,R30-Z,30,ANDAK by APPTR,R30Z,30,ANDAK) fix the problem and the MCDU load the corresponding approach.
- The MCDU not read the RF(Radius to Fix) drawing an incomplete approximation (Picture 1)
http://jardesign.org/forum/img/m/527/t/p1a55d9leb134k6b0jfck6h1t9tp.png
FINAL,R30-Z,30,G,4
IF,RALES,-30.043525,-71.055133, ,0.0,0.0,2,4200,0,1,200,0,0,0
RF,PELIC,-30.001003,-71.048519,1,ARC01,317.9,3.2,2,3400,0,0,0,0,0,0
RF,SEREN,-29.967384,-71.080678,1,ARC01,294.4,3.2,2,2560,0,0,0,0,2,0
TF,RW30,-29.920292,-71.190556,0, ,0.0,0.0,295.0,6.4,1,531,0,0,0,0,3,1
TF,BARCA,-29.816667,-71.432222,0, ,0.0,0.0,0.0,0.0,2,3000,0,0,0,0,0,1
HM,BARCA,-29.816667,-71.432222,1, ,0.0,0.0,115.0,04,0,0,0,0,0,0,0,0,0
http://jardesign.org/forum/img/m/527/t/p1a55bug2g91quti8n1195l14uc8.png
If i change the RF by TF in the AIRAC, MCDU loading it properly but without the ARC
http://jardesign.org/forum/img/m/527/t/p1a55ckl791nn11l7f5g310ev1jevd.png
-When you load the flight plan, if the path is very long whitout inserting the temporary plan, path goes blank. To not miss this, is necessary to keep adding points and go inmediately inserting the temporary path.
http://jardesign.org/forum/img/m/527/t/p1a55cn16f4601ikrt9l4k21pk8g.png
- ZFW and BLOCK are somethat displaced
http://jardesign.org/forum/img/m/527/t/p1a55ct8or2l233objtap4ri2j.png
- In the SID DONTI1B from SCEL departing from the procedure indicates that you must start the turn by passing 4000 feet, so the MCDU inmediately crank the plane without passing 4000 feet.
http://jardesign.org/forum/img/m/527/t/p1a55dfu4d17091l2s1m72vfm17qvt.png
SID,DONT1B,17L,4
CA,0,175.0,2,4000,0,0,0,0,0,0
DF,SEKSU,-33.472489,-70.985972,2, ,0.0,0.0,4,9000,7500,0,0,0,0,0
TF,EL370,-33.202808,-71.091550,0, ,0.0,0.0,0.0,0.0,2,11000,0,0,0,0,0,0
TF,DONTI,-32.950097,-71.189867,0, ,0.0,0.0,0.0,0.0,2,13000,0,0,0,0,0,0
http://jardesign.org/forum/img/m/527/t/p1a55d3n7k1dmlb07jds8ai68dm.png
Everything else looks good, thank you very much for the great work and updates
61
hades.esp72 wrote:
Killerofwar wrote:
Hello JarDesign,
I'm just testing the new beta - I'm currently entering my flight plan. One thing I noticed so far:
- The ND is immediatly available after power-up, without having to align ADIRS. In fact, I'm just checking my flight plan route via the ND and my ADIRS is still off.
So do i and "TA Only", activated by default
Indicates TA only  - mode is selected or the RA function is inhibited or failed. With TA/RA selected, the message appears automatically during climb until 1100 feet AGL and on descent below 900 feet AGL when the TCAS automatically switches to the TA ONLY mode.
Ok. I'll check it. Thanks for your answer!
This weekend I'll try to fly more the plane.  Your job is well under way!
hades.esp72 wrote:
Hi!
http://jardesign.org/forum/img/m/1123/t/p1a55i18svkr0a422mctmd78e3.png
Just some graphical items:
- Dust effect on ND is nice but bad on PFD and ECAM (image 1).
- Passenger windows have a too way too low transparency. As a result, it looks like it's foggy outside while it isn't. Like to see to the same window effect like the windshield effect in the cockpit. (image 2).
http://i63.tinypic.com/vht3yp.jpg
http://i67.tinypic.com/oub0rd.jpg
64
hades.esp72 wrote:
hades.esp72 wrote:
Hi!
As I see, AUTO position just limit displayed traffic for intruders only. For now, i am done this for beta 2. Please check how correct it will work.
amavrakis wrote:
FINAL,R30-Z,30,G,4
"RF" legs was not done now. Should be add in future.
pilotalva wrote:
- When making flight plan sometimes ATC will issue straight out departure on the FMC you can choose departure runway with no SID and no transition, however the F-PLN discontinuity between the departure and the rest of the trip is impossible to remove, the only way to remove is to actually enter a SID. This is a problem when departing from airports where no SIDs are currently published
Possible do delete DISC after you insert runway w/o SID etc.
Thanks for other info, but.. you are not attached any docs, what will be useful to start discussion, cause i am not agree with many points, sorry.
67 (edited by thomas_99 2015-11-28 10:37:06)
AIRAC - Navdata cycle reader is completely broken....
So what i did:
Enter the same flight plan every time:
EDDF SID ANEKI Y163 NEKLO Y171 INKAM T725 LAMGO T721 SUL T732 GARMO STAR EDNY
Arrival: ILS 06
STAR: GARM1P
VIA: MOKOP
No Transition.
This is the result with AIRAC 14.05 (the one which was included in xplane, I've never changed it)
http://jardesign.org/forum/img/m/552/t/p1a56poljte03n0a1il21r8mmfch.png
Changing the AIRAC to a newer version (1503, 1511) results in this:
http://jardesign.org/forum/img/m/552/t/p1a56q3uv91gmt1at5s4o1vjm1lcl3.png
interesting picture during flight :-) :
http://jardesign.org/forum/img/m/552/t/p1a56pochvus51f43pe5717174vc.png
This is not only on 2.6b1, but also on older versions....
Ah, and of course the same problem on A330 ...
68
I dont have any docs but a video of the real a320 , please start watching from minute 6
https://youtu.be/9fqy8uPzW90
pay special attention to the pitch part which currently is where the most problem relies
Yes, and see XPNDR too. S on ground and C in flight.
70 (edited by captbullett 2015-11-28 16:01:36)
X-plane A320Ne (this video is done in parts for Up-loading)  this is the first flight of the JAR beta 2.6.1 A320Ne the route is a VOR route from,
         //*  LEPA/LEBL : LEPA SID ESPOR W2 NEPAL STAR LEBL ///                  The MCDU worked very good and I found the improved route to work well saying that I never had any issues before but the curved arching flight plan is more natural as you do not want to bounce the PAX around ... I say good job JAR ... i hope this might help if you are having issues  you might see something that will help you out ...
your friend,
captbullett X-Plane.org
Once you click on the link just click on my name and it will take you to my channel which has all the videos
https://youtu.be/nhTyl0ZVwqo
https://youtu.be/sYXHFRyszPY
https://youtu.be/Dk9M2uT5BCU
https://youtu.be/41VJqP8rLm4
https://youtu.be/Kd1_QiaAVz8
https://youtu.be/NgBCIlUtZLM
or go to my channel ; https://www.youtube.com/channel/UCY6Y_3 … ji6Q3NMG4Q
71
Would it possible to have in a future beta :
-Predictive Wind Shear functionnality on the weather radar panel
-Better TCAS view on the ND (photo )
-constraints view with the concerning speed on the ND
http://jardesign.org/forum/img/m/1125/t/p1a57o1ebiotq19hg1gt8i8nv103.jpg
http://jardesign.org/forum/img/m/1125/t/p1a57o1ssd6651n1rcjgq81t7c5.jpg
Thanks a lot
72
Testing v2.6 from SAEZ to SCEL.
Everything was fine, but between UMKAL to LOSAN I've need to correct heading manually because A320neo lost airway to SAFEL. After the correction was made and heading was recovered, AP1 & AP2 can't follow GS for landing (SCEL).
Can't set Go Around Altitude.
73
PFD and ND lights are flashing
Video demonstration with the problem
- https://youtu.be/G8E2WoBH0bw
- https://youtu.be/rpljeUMXqLU
A320neo v2.6 Beta 1
Windows 10
X-plane 10.42r1
NavDataPro by Aerosoft AIRAC Cycle 1512 R.2
74 (edited by captbullett 2015-11-29 01:42:57)
good day,
this also goes for the A320Ne Ok this way we can better serve more people ... this is a re-post ... and when it come to navigation we need the whole route take-off runway and landing runway you plan to use then we can give you something to use ... ok...
thank-you
Hello all together,
well the A330 is released and now every day there are multiple topics poping up in the forum.
So to keep the work for Jar and Slava easy and structured, I would kindly ask all users to use a standardized bug reporting.
We used that in the alpha/ beta phase and it was quite well because you clearly could see which bug was fixed, if there is a discussion about bug and so one.
So my suggestion are:
1.Search the forum before you open a new topic. Your bug might be already reported.
If your bug is already reported:
Post your findings to this existing topic.
If your bug wasn't reported before:
2. Open a new topic
3. Choose a Topic subject which describes your bug in the most shortest form and use one of the following to identify your problem in front of your topic subject:
[sys] for bugs concerning the aircraft's systems
[fpln] for bugs concerning flight plan
[vis] for bugs concerning the outside/ inside look of the 3D objects
[other] if you can't put your bug into one of these categories
4. Describe your bug precisely as possible in the write message field.
5. Attach X-Plane Log.txt and A330 bb_log.txt.
6. If possibile add sources from FCOM, POH, AMM proving JarDesign's A330 is wrong.
And last the most important point for a fast fixing of bugs is that you please post only one bug into one topic
To my mind if we all spent the time to do our bug reporting like that way, JarDesign could easily work through the reported bugs
Best Regards
Lukas
When Entering the SID from KSNA, after choosing Runway, SID, and TRANS, the MCDU doesn't let you navigate to TMPY F-PLN.  I click the button for <F-PLN and nothing happens.  http://i.imgur.com/Ca4c5lC.png
Also, when clicking on KPDX arrival, it seems to be showing me GMN instead of the airport I selected.
http://i.imgur.com/ClwX2hp.png
http://i.imgur.com/Azt5ZGj.png
AIRAC is the following:
http://i.imgur.com/d2yDYMU.png
