Topic: ver 2.6 beta 1 WIN/MAC 64 bit
First beta, please use it if you really want take part in beta-tests
So, this is the next 320 MCDU/ND improvements - reworked flightplan path (add TMPY FPLN, GA FPLN, ND), new SASL v2.4 implemented (should fix CTD when exit X-Plane), add Saitek Throttle Quadrant support (for LG, Flaps, GSpoilers control)
——————————HOW TO INSTALL:——————————————
Download link http://jardesign.org/a320/download/inst … V2.6b1.zip
  - be sure, that you use X-Plane 10.41 (64 bit only)
If your activations are over (activation error) - use contact official support http://www.jardesign.org/ticket/kb/faq.php?cid=1
——————————IMPORTANT NAVDATA NOTES:————————————
v.2.6 use NavData from ..X:/X-PLANE 10/Resources/GNS430/navdata/ folder
and put new cycle to ..X:/X-PLANE 10/Resources/GNS430/navdata/ folder
——————       "BETA" is version for Beta-testers!!!    ———————————
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong. Please report about wrong thing, but only thing what changed in this beta - Flightplan part, MCDU work, ND work
Of particular importance will be issues:
- Drawing (wrong, sure) SID/STARS on the Nav display (please attach a screenshot of true drawing from documents and wrong drawing from your ND, specify the SID/STAR, approach, runway, name of the airport, AIRAC cycle and provider)
- Displacement of characters on the MCDU screen (attach screenshots please)
Re: ver 2.6 beta 1 WIN/MAC 64 bit
Good day.
If i reload aircraft, the custom sounds (Sound3D - Blue Sky Star Simulatios) are lost.
hades.esp72 wrote:
Good day.
I don't have that problem. It's weird.
Hello JarDesign,
I'm just testing the new beta - I'm currently entering my flight plan. One thing I noticed so far:
- The ND is immediatly available after power-up, without having to align ADIRS. In fact, I'm just checking my flight plan route via the ND and my ADIRS is still off.
Hi JAR,
Does this re-writing of the flight plans fix the flyover/flyby functionality of the fixes?
Thanks,
Kris
Killerofwar wrote:
Hello JarDesign,
Are you use Hot-Start may be?
tiger6k wrote:
Hi JAR,
Thanks,
Kris
It work like a330 now, fly-by instead of fly-over now. Why you ask, better - download and try.
tiger6k wrote:
Hi JAR,
Thanks,
Kris
Will do, thanks wink
I have downloaded the AIRAC 1512 there is the A320/ jardesign zip folder and the route is to navdata inside the A320 folder, not the xplane GNS 430.
Do I need to delete the nav data that is in the A320/navdata folder files and just leave the GNS430 default xplane files?
I am confused about that, because navigraph had created nav data exclusive for jar design planes
Thanks in advance
Thanks in advance
It was exclusive, but just like Flight Factor, JAR decided to use the GNS430 nav data, so you no longer need an exclusive download.
11 (edited by hades.esp72 2015-11-24 18:38:33)
Killerofwar wrote:
Hello JarDesign,
So do i and "TA Only", activated by default
Thanks for the update, testing at the moment - first issue I noticed is that there is still just one line for entering an AIRWAY. It should be multiline to be able to enter a few airways on this page and insert them when finished.
Thanks a lot for your work.
For the first flights with the 2.6 beta I noticed :
-ND available without the 7-10 min time for the complete alignement
-is it possible to have the green asterix for the constraints in red like in real planes
-no possibility to enter speed constraints...it is very important for the SID / STAR
-no possibility in the PERF menu to programm the climb page with selected speed (I generally insert the green dot speed)
-It would be great in the rad nav menu to perform a VOT test and to have the possibility to enter the 3 or 4 letter from the different VOR, ILS and so on...
Thanks for all
Thanks for issues! Wait more after detail testing.
In fact FF use the same Airac format what JARDesign and this is the same X-Plane NavData Format. It is usually "Airbus X Extended 1.10". Now, if you use FF and JARDesign aircrafts, you can update just this ONE NavData folder.
Thanks your work, great.
Issues:
https://youtu.be/ir5Cz-wkylk
Hi all!
After a bit of testing... Several minutes and... ND and PFD turn off..  (As if register isn't succesfully) but succesfully registered. At this moment i'm taxi out.. of course I had fuel.. (4800 kg aprox. No hot start, cold start)
TCAS position TA - TA /RA shows always 'TA only' at ND.
I hadn't enough time to install BSS sounds.. tomorrow more!
Cheers from Spain.
for the first flight the new beta work fine!
but the engine temp. are 150 and 148 degrees
an the front is still to deep thereby the pfd lateral is under the horizon on ground
in next beta is a watch in the nd comming ?
My 2 cents.  No nav aids, airports or waypoints showing.  Completely messed up the text using AirFMC. Exactly the same problems with AirFMC as the 330.
19 (edited by Acei 2015-11-24 23:57:39)
Flew EIDW to EGCC.  Noticed some discontinuities in the flight plan as you get with the A330 which I had to delete.  Then just continued past one of the waypoints without turning as defined in the plan.  Pushed and then pulled the HDG button and it turned back on course.  I've had this problem a few times in the realised version.
Also received a terrain warning when radio altimeter was showing just over 1000 feet.  100 announcement happened at 400 feet on radio altimeter.
Other things I've noticed that increased light isn't showing on the taxiway/runway when the landing lights are turned on.  The light above the CPT and FO side windows isn't working.
Its working nicely so far , I will retake serious flights on this plane to investigate further
the 320 fms seems pretty more developed than the one the 330 uses , I was wondering why you dont copy it over since theyre basically the same plane? (just bigger faster)?
I make SBCT-SBSP and the first thing which I saw:
1-when I turn on the plane the N/D show aligned without aligh the ADIRS but after I adjust the ADIRS he turn unavailable until the normal aligh.
2-When I flew the plane stay a little bit out of the green line in N/D
3-And the same problem of Acei when he said "Then just continued past one of the waypoints without turning as defined in the plan.  Pushed and then pulled the HDG button and it turned back on course.  I've had this problem a few times in the realised version."
Thanks for all
22 (edited by robson.curitibapr 2015-11-25 04:40:28)
Side column lights in the cockpit doesn't work.
HDR is on.
https://youtu.be/FRP4i-H4DiI
X-plane 10.41
Windows 10
Attachment icon bbox_log.txt 100 b, 290 downloads since 2015-11-24
23 (edited by robson.curitibapr 2015-11-25 11:45:06)
The arrival procedure does not match the letter of arrival
AIRAC Cycle 1512 v2 NavDataPro by Aerosoft
Update to X:/X-PLANE 10/Resources/GNS430/navdata/
SBRJ/SBCT
ROUTE: NAXOP UZ45 ORANA
Procedure is correct
SID: IH 1C RWY 20L
Chart: http://www.aisweb.aer.mil.br/download/? … 567f175e3a
ENRC Chart
Procedure ins't correct at Fligh Plan A320
STAR: ORANA 1
IAC: ILS W RWY 15
https://youtu.be/-pTkMOd9CLs
X-plane 10.41
Windows 10
Attachment icon bbox_log.txt 100 b, 294 downloads since 2015-11-24
Very smooth flight, LPPT-LPFR, but a couple of things to note.
1. T/C was announced by FO as T/D. When reached T/D, no heads up before hand
2. ILS Final, 2500agl,  speed suddenly decreased from 149kn to 129kn while in managed ap speed mode (149kn) then came back after hitting 129kn to 149kn. (Landing speed was calculated at 144, I added 5 for a strong crosswind)
All in all, a Lovely flight and more importantly, a big update.
SBRJ/SBCT
SID: IH 1C RWY 20L
ENRC Chart
STAR: ORANA 1
IAC: ILS W RWY 15
X-plane 10.41
Windows 10
thanks, but.. missed data..
http://jardesign.org/forum/img/m/22/t/p1a4usbh4114b3sos1at8jvb1puq3.jpg
