Topic: [old] GHDeluxe v.121115 beta
This is Ground Handling Deluxe*** plugin by JARDesign v121115 distributive (Win 7/8, MAC OS 64 bit)
What new:
+Add ability to change Liveries using Menu->Plugins->GndHandling->Liveries
+Add 5 Liveries as example
Download link http://jardesign.org/gndserv/download/GHD_121115.zip
1. if need - Save your custom sets from ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
2. save your key.reg file from ..X-PLANE 10/Resources/plugins/GndHandling/
3. be sure, that you use X-Plane 10.41
4. delete old «GndHandling» from ../X-PLANE 10/Resources/plugins/
5. copy unzipped new «GndHandling» folder to ../X-PLANE 10/Resources/plugins/ folder
- If you have key.reg file from prev version
6. Paste your saved key.reg file to ..X-PLANE 10/Resources/plugins/GndHandling/
7. Paste your saved custom sets to ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
8. Your plugin is always registred
- If you perform New installation
6. start X-Plane 64 bit and load default Boeing 747
7. Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
8. activation works well with both MAC/WIN 64 bit
*** - Please note what only "Deluxe" version may work with liveries. Version always included to a330 pack not have this function.
