Re: a320neo JARDesign ver 2.5 r1 WIN/MAC 64 bit
LIML (DEPART) 36 ML501 ABSEM TUVIB LOGDI EKDIR VERUN///
that is the first try, now i know what is going on you have to use the right SID and STAR for the airport and if you do not you will not get a working route when you do not use one of the first sid or star in the list then it usually will not work but pick the first sid and stars in the list and see what happens ... once i did this all was good and i had no issue with the area and the sid or FP...
always glad to helpthe screen shots are SID maps of LIML so you can choose which one you want to use and which runway to use with which sid...
newmind wrote:captbullett wrote:Good day,
can you post a log.txt and box.txt also your full route so I can reproduce the route and try it... and see what is going on ..
your friend,
captbullettPs, I just had an up-date for Java 8.60 build 27 So, please check your java yo make sure it is up to date.
These are the files with the flightplan...the problem appears when i insert the sid (TOVS5C and the LOG5C) and i have the "LIRN removed" message
Ok..i've tried all the allowed combination and i've discovered that the problem appears only when i insert the transition LOG5C (anyway this is a possible trans for south departure) . In all the other cases the route loads correctly without the "remove waypoint"message.
So i wonder if this could be a navigraph database file problem???
