Topic: ver 2.5 beta 3 WIN/MAC 64 bit
First beta, please use it if you really want take part in beta-tests
So, next 320 improvement.
So, the main goal of 2.5 is make it compatible with 2 external product - GHD and custom soundpack. 1-2 day and first Video with this soundpack will be ready. I try to improve some systems (hydraulic system too) to make voices sound natural. No changes of flightplan system was made - this is task for next 2.6, not now. As you know may be, X-Plane 10.40 have changed airport data format and FMCar included in a320 pack not work propertly with it. I rework c++ separate plugin, but not reworked lua (a320 included) FMCar, but just exclude it for 2.5 and for future. I prefer this way, if someone - not - sorry. And about hypoxya effect (if you have it) - that is no addon bug, but x-plane. I just tested 10.41 first build - this problem solved there.
What new for 2.5:
+Ground Handling Deluxe plugin (not included) compatible
(mean what now you should have external pwr avail when GPU connected, fuel panel should come with fueltank, doors shouls open in auto mode)
+FBW “roll” tuned for low airspeed
(based on reports from real pilots tests)
+ready for Custom 3D soundpacks
(not included, expect from 3th part developers like BLYE SKY STAR)
+ND Weather radar range extended
+new SASL base plugin included
-FMCar was excluded from a320 pack
+hydraulic system improve
Download link http://jardesign.org/a320/download/inst … V2.5b3.zip
- be sure, what you use X-Plane 10.36 (stable only, not use betas, please)
- start X-Plane 64 bit and open a320, activation window is show up
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong.
If your activations are over (activation error) - use contact email from official website http://airbus320neo.com/contact/
Please not discuss things what are not in "whats new" list. Please post your opinion direct here. When you post some, please follow some rules like this http://jardesign.org/forum/viewtopic.php?id=861
