Topic: [old] GHDeluxe v.110915
What New:
+sound issues for some aircrafts fixed
You can install full version (new installation) or just an update from ver280815 (if you have always installed GHD)
1. If Update, please install this patch
Download link - http://jardesign.org/gndserv/download/G … _patch.zip
- Unzip pack and put mac.xpl and win.xpl files to ..X-PLANE 10/Resources/plugins/GndHandling/ folder instead old files
2. If New installation.
Download link - http://jardesign.org/gndserv/download/GHD_110915.zip
- if need - Save your custom sets from ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
- be sure, that you use X-Plane 10.36
- copy unzipped «GndHandling» folder to ../X-PLANE 10/Resources/plugins/ folder
- start X-Plane 64 bit and load default Boeing 747
- Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
