Topic: [old] GHDeluxe v.110915
What New:
+sound issues for some aircrafts fixed
You can install full version (new installation) or just an update from ver280815 (if you have always installed GHD)
1. If Update, please install this patch
Download link - http://jardesign.org/gndserv/download/G … _patch.zip
   - Unzip pack and put mac.xpl and win.xpl files to ..X-PLANE 10/Resources/plugins/GndHandling/ folder instead old files
2. If New installation.
Download link - http://jardesign.org/gndserv/download/GHD_110915.zip
  - if need - Save your custom sets from ..X-PLANE 10/Resources/plugins/GndHandling/Sets/Custom/
  - be sure, that you use X-Plane 10.36
  - start X-Plane 64 bit and load default Boeing 747
  - Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
2 (edited by petitmarseillais 2015-09-14 18:02:48)
Re: [old] GHDeluxe v.110915
Hi Jar,
i still have issue a permanent hydraulic sound with my saab.
Kind regards
petitmarseillais wrote:
Hi Jar,
Kind regards
please describe more exact!
hydraulic sound (saab) always play.
normally it plays with some events like down gear or flaps
And..? please continue!
When you remove GHD plugin from plugins folder it is not always play?
affirm Jar
without plugin,, hydraulic sounds is not continously
affirm Jar
Ok. What we will do - please contact me skype j.a.romanov, i will change set and send for you. May me dataref what described in this set do this effect.
i have updated xpx to 10.40 (beofre i were 10.36) and that continuous hydraulic sound disappeared.
your update works fine
see you
v110915 CTD Crashes to desktop on launch, Mac.
X-Plane ver10.40RC3, issues started with version 10.40RC1 the plugin loaded but the vehicles would go to their positions and then just circle around on the spot?
Now in 10.40RC3 I just crashes X-Plane?
I redownloaded the New Installation version to double check?  Still get CTD?
Log notes:
Ground Handling Plugin by JARDesign v.090915 for X-Plane 10
GndHandling: /X-Plane 10 Master/Resources/plugins/GndHandling/updlist.txt file updated.
Loaded: /X-Plane 10 Master/Resources/plugins/GndHandling/mac.xpl (jardesign.crew.ground.handling).
I have the Apple Mac crash report but can't see how to attach to this notice? SD
Still getting CTD crashes when plugin is installed?
Log notes:
You can send me Mac crash report via skype j.a.romanov
Okay I have the Apple crash report as well...  SD
Both logs are on skype...  I have the WorldTraffic plugin in there but it does not affect the crashes as I have checked...  Thanks Stephen
thanks!
Any news on this?
Dear Stephen! This is a forum. Forum - is a place for discussions. You not need discussion, you need direct support in your case. Please use direct contact for this. My skype is j.a.romanov Thank you!
InformationBravo wrote:
What a great enhancement for this plugin!  It works great - no issues.  Am I able to add liveries to the plugin menu from other textures I download?  I have placed additional obj files to the "Cars" folder and png files to a new folder in the liveries folder.  The new livery doesn't show up as an option in X-Plane in the Ground Handling -> Liveries menu.  Thanks!
Oops!  I forgot to close and restart X-Plane after creating my livery folders.  They do show up in the Ground Handling -> Liveries menu now.  Thanks for the great update - love this plugin!
