Captbullet, aha now I understand. Yes, my set up is that I have the G5 mouse connected by usb, and the Apple trackpad by bluetooth (of course).
This morning I had an interesting finding. I started up this beta as usual after turning the iMac back on (it is turned off during the night). After this restart, the push/pull wouldn't work any more! Only the scroll function works. I reloaded the plane, and now the push/pull works again. Hmm, strange. The pull/push now works both with the G5 mouse and the trackpad, as it did yesterday.
The problem I am struggling with at the moment is that the AP NAV mode will not engage. Is it just me or does other people have the same? I read through some text in the FCOM yesterday, and the NAV mode is supposed to engage automatically at 30 feet radio altitude after take off, and it doesn't. It continues in RWY TRK mode... The same problem occurs if I activate HDG mode (pull hdg knob), which works. When I then want to reactivate NAV (e.g. by entering "Direct To" on the MCDU), it won't activate, it is stuck in HDG mode. Anyone experiencing these autopilot problems with NAV mode?
EDIT: I am just starting to think that maybe this can have something to do with the xPlane beta 7. I just tried again with A330 beta 1, and NAV still doesn't work... Then maybe its a XP problem..
FCOM descriptions, stating that what I am doing should turn on NAV mode (unless I misunderstand):
NAV mode. FCOM 1 page 177:
RWY mode. FCOM 1 page 206:
captbullett wrote:Good day,
not beta but the mouse is different from stock like what Apple would use no? has nothing to do with the version of beta but I am talking about the mouse issue now and trying to resolve the //* Push-pull issue now // Apple does not use the version of mouse that you are using it is an add-on no? and can cause a bug no? this is just me talking out loud and problem solving ...
thank-you for your input.
this link should help with Logitech g5 and Apple https://discussions.apple.com/thread/3535241?tstart=0
Anterialis wrote:What do you mean customizations? I have a fresh install of this beta, haven't done anything to it except set quick views (fresh, not imported from previous betas).
